Problems with AppArmor in a Debian 10 container, running on a Ubuntu 18.04 host with LXD 3.0.3
I am trying to make AppArmor work inside a Debian 10 container, which is running on a Ubuntu 18.04 host with LXD 3.0.3.
I have create the vm05 Debian10 CT and enabled security nesting:
$ lxc config show vm05 --expanded|fgrep nest
    security.nesting: "true"
However, after installing apparmor userland tools & profiles and rebooting vm05, it doesn’t load any AppArmor profiles:
root@vm05:~# cat /etc/debian_version
10.4
root@vm05:~# dpkg -l|fgrep apparm
ii  apparmor                          2.13.2-10                                                      amd64        user-space parser utility for AppArmor
ii  apparmor-profiles                 2.13.2-10                                                      all          experimental profiles for AppArmor security policies
ii  libapparmor1:amd64                2.13.2-10                                                      amd64        changehat AppArmor library
root@vm05:~#
root@vm05:~# apparmor_status
apparmor module is loaded.
0 profiles are loaded.
0 profiles are in enforce mode.
0 profiles are in complain mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
root@vm05:~#
There are several profiles in /etc/apparmor.d/
Any hints about troubleshooting this?
Thanks in advance, K.
Strangely, AppArmor profiles seem to load on a Debian 9 (instead of 10) container, on the same Ubuntu 18.04 host running LXD 3.0.3. But without having enabled security.nesting.
$ lxc config show vm01 --expanded|fgrep nest
And when logging inside the container:
root@vm01:~# apparmor_status
35 profiles are loaded.
2 profiles are in enforce mode.
   /usr/bin/freshclam
   /usr/sbin/named
33 profiles are in complain mode.
   /usr/lib/dovecot/anvil
   /usr/lib/dovecot/auth
   /usr/lib/dovecot/config
   /usr/lib/dovecot/deliver
   /usr/lib/dovecot/dict
   /usr/lib/dovecot/dovecot-auth
   /usr/lib/dovecot/dovecot-lda
   /usr/lib/dovecot/dovecot-lda///usr/sbin/sendmail
   /usr/lib/dovecot/imap
   /usr/lib/dovecot/imap-login
   /usr/lib/dovecot/lmtp
   /usr/lib/dovecot/log
   /usr/lib/dovecot/managesieve
   /usr/lib/dovecot/managesieve-login
   /usr/lib/dovecot/pop3
   /usr/lib/dovecot/pop3-login
   /usr/lib/dovecot/ssl-params
   /usr/sbin/avahi-daemon
   /usr/sbin/dnsmasq
   /usr/sbin/dnsmasq//libvirt_leaseshelper
   /usr/sbin/dovecot
   /usr/sbin/identd
   /usr/sbin/mdnsd
   /usr/sbin/nmbd
   /usr/sbin/nscd
   /usr/sbin/smbd
   /usr/sbin/smbldap-useradd
   /usr/sbin/smbldap-useradd///etc/init.d/nscd
   /usr/{sbin/traceroute,bin/traceroute.db}
   klogd
   ping
   syslog-ng
   syslogd
5 processes have profiles defined.
1 processes are in enforce mode.
   /usr/bin/freshclam (314)
4 processes are in complain mode.
   /usr/lib/dovecot/anvil (370)
   /usr/lib/dovecot/config (373)
   /usr/lib/dovecot/log (371)
   /usr/sbin/dovecot (368)
root@vm01:~# dpkg -l|fgrep apparm
ii  apparmor                         2.11.0-3+deb9u2                                               amd64        user-space parser utility for AppArmor
ii  apparmor-profiles                2.11.0-3+deb9u2                                               all          profiles for AppArmor Security policies
ii  libapparmor-perl                 2.11.0-3+deb9u2                                               amd64        AppArmor library Perl bindings
ii  libapparmor1:amd64               2.11.0-3+deb9u2                                               amd64        changehat AppArmor library
root@vm01:~# cat /etc/debian_version
9.12
root@vm01:~#
So, should I enable security.nesting in order to use AppArmor in Debian containers running under LXD?
security.nesting isn’t required for apparmor to work.
Most likely it’s the apparmor init script in that version of Debian which is mis-detecting the ability to load apparmor profiles.
I remember back in the day where we rolled out apparmor namespacing, the apparmor init scripts in Ubuntu required some changes. I don’t know how much of that made it upstream or how widely that is tested on other distros.
Hi Stéphane,
Thanks a lot for your quick reply. I have tried setting security.nesting to both “true” and “false” but it didn’t make any difference to the loading of AppArmor profiles on the vm05 Debian 10 CT:
$ lxc config set vm05 security.nesting false
  security.nesting: "false"
Btw if a parameter like security.nesting is unset, does it get its value from LXD’s “default” profile ? (I assume the default for nesting is “false”)
Anyway, I was hoping that Debian 10 (which has enabled AppArmor by default) would be fully supported under LXD … Should I make a regular bug report about this issue at Debian, or do you have a better way?
Thanks again, K.
I’d recommend trying to manually load a profile in with apparmor_parser, if that works, then the problem is with the distro init scripts.
So it seems to be due to the init scripts:
root@vm05:~# apparmor_parser -r /etc/apparmor.d/usr.sbin.named
1 profiles are loaded.
1 profiles are in enforce mode.
   /usr/sbin/named
1 processes have profiles defined.
1 processes are unconfined but have a profile defined.
   /usr/sbin/named (653)
root@vm05:~#
But Debian 10 loads AppArmor profiles fine when run as a VM (under KVM, VMware etc) or on bare metal. This problem only happens when Debian 10 runs under LXD.
By the way, I had enabled security.nesting for CT vm05, because it was needed in order to run MariaDB 10.4 under Debian 10.
Yeah, but apparmor at least in Ubuntu needed tweaks to its init scripts to properly trigger inside a container that uses apparmor namespacing.
The behavior you seem to run into suggests that this logic is missing or broken in Debian.
Thank you for your feedback, I will try to file a bug report at Debian.
But given that Debian 10 Buster has been around for a year and that AppArmor is now enabled by default, I am frankly a little surprised to be the first person to report this issue and a little anxious about using LXD+Debian in production …
Apparently Debian10 explicitly disables AppArmor when running in container:
root@vm05:~# systemctl status apparmor.service
● apparmor.service - Load AppArmor profiles
   Loaded: loaded (/lib/systemd/system/apparmor.service; enabled; vendor preset: enabled)
   Active: active (exited) since Wed 2020-07-15 21:38:19 EEST; 1h 58min ago
     Docs: man:apparmor(7)
           https ://gitlab .com/apparmor/apparmor/wikis/home/
  Process: 46 ExecStart=/lib/apparmor/apparmor.systemd reload (code=exited, status=0/SUCCESS)
 Main PID: 46 (code=exited, status=0/SUCCESS)
Jul 15 21:38:19 vm05 systemd[1]: Starting Load AppArmor profiles...
Jul 15 21:38:19 vm05 apparmor.systemd[46]: Not starting AppArmor in container
Jul 15 21:38:19 vm05 systemd[1]: Started Load AppArmor profiles.
root@vm05:~#
root@vm05:~# systemd-detect-virt --container
lxc
root@vm05:~#
So Debian10’s /etc/init.d/apparmor explicitly disables loading AppArmor profiles inside a container, unless is_container_with_internal_policy() is true.
I have contacted the Debian AppArmor maintainers about this issue, flagging it as a regression (since it worked on Debian9 but broke on Debian10).
Good news, after reporting the aforementioned bug to the Debian AppArmor maintainers, I received a patch which solved the issue and will be included in Debian 10.6.
If anyone else who wants to use AppArmor in a Debian 10 container running on a LXD/LXC host would also like to test it, please check https://alioth-lists.debian.net/pipermail/pkg-apparmor-team/2020-August/003302.html
