incus file edit vm5/etc/hosts
Error: exec: “mvim”: executable file not found in $PATH
Hello, and welcome to the Incus community support forum!
When you run a command like the following, Incus makes a copy of the file to the host, launches whichever editor is defined in $EDITOR
on the host with argument that copy of the file, and when you save it, Incus sends back the file to the instance.
incus file edit myinstance/file/in/instance.txt
By default on Debian or Ubuntu hosts, the editor is pico
. What’s your Linux distribution?
If you want to edit the file with gedit
(the GUI text editor for GNOME), you would run the following:
export EDITOR=gedit
You could also try exporting vim or nano. I am sure at least one of those is installed.
You could also try installing mvim.
I figured out what mvim is and why I did not know what it was.
