I have LXD installed via Snap on Ubuntu 20.04. This morning it automatically upgraded it to version 4.3. Unfortunately I am having many problems with this new version. How do I go back to version 4.2?
Thanks!
Thanks!
What problems are you running into?
4.3 comes with a DB update so downgrading to 4.2 would require reverting the database as well, it’s possible but figuring out what’s not working may be much faster.
The performance is very sluggish when typing lxc commands. Also VMs sometimes stop. If I type lxc list it shows stopped, but in htop I see the process is still running. So I type lxc start I get an error message:-
Error: Failed to run: /snap/lxd/current/bin/lxd forklimits limit=memlock:unlimited:unlimited – /snap/lxd/15938/bin/qemu-system-aarch64 -S -name PiDebian -uuid 3ba93ea2-fa57-4e17-87d5-72a23cd9f907 -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-reboot -no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=deny,resourcecontrol=deny -readconfig /var/snap/lxd/common/lxd/logs/PiDebian/qemu.conf -pidfile /var/snap/lxd/common/lxd/logs/PiDebian/qemu.pid -D /var/snap/lxd/common/lxd/logs/PiDebian/qemu.log -chroot /var/snap/lxd/common/lxd/virtual-machines/PiDebian -smbios type=2,manufacturer=Canonical Ltd.,product=LXD -runas lxd: qemu-system-aarch64: cannot create PID file: Cannot lock pid file: Resource temporarily unavailable: exit status 1
Try lxc info --show-log PiDebian for more info
Remote: unix://
Architecture: aarch64
Created: 2020/07/02 17:49 UTC
Status: Stopped
Type: virtual-machine
Profiles: default
Pid: 2128
Resources:
Processes: 0
Snapshots:
BeforeDocker (taken at 2020/07/03 17:04 UTC) (stateless)
Log:
If “kill pid number” then I can start it again with lxc start.
Sounds like memory problems on your system, what does dmesg look like?
If rebooting is an option, I’d strongly recommend it when getting such odd errors.
I also would strongly recommend against issuing lxc start if you can see the qemu process still running as you may end up starting it twice corrupting the VM’s disk (locking should prevent it but better not risk it).
The host is a Raspberry Pi 4 with 4GB of RAM. I reboot it. Then I wait 3 mins. Then I type lxc list. This takes a while - I assume the service is started and the BTRFS file system is mounted.
Then I wait another 3 mins and type lxc start vm. The vm starts. I wait another 3 mins. Then I type lxc list and it shows as stopped. But in htop I see the 3 processes running for this VM.
I am unable to ssh into it and if I type lxc console vx then I get “Error: Instance is not running”
Here is the dmesg output (top omitted for brevity):-
[ 12.624313] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.831024] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 13.871015] br0: port 1(eth0) entered blocking state
[ 13.871026] br0: port 1(eth0) entered disabled state
[ 13.871215] device eth0 entered promiscuous mode
[ 13.875899] bcmgenet: Skipping UMAC reset
[ 13.877276] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 13.877458] bcmgenet fd580000.ethernet eth0: Link is Down
[ 18.974037] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 18.974067] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.974156] br0: port 1(eth0) entered blocking state
[ 18.974164] br0: port 1(eth0) entered listening state
[ 23.005955] br0: port 1(eth0) entered learning state
[ 38.109976] br0: port 1(eth0) entered forwarding state
[ 38.110467] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[ 186.066522] new mount options do not match the existing superblock, will be ignored
[ 190.685946] bpfilter: Loaded bpfilter_umh pid 1835
[ 190.686893] Started bpfilter
[ 191.108546] BTRFS: device label default devid 1 transid 145349 /dev/loop6
[ 191.109580] BTRFS info (device loop6): disk space caching is enabled
[ 191.109587] BTRFS info (device loop6): has skinny extents
[ 191.274889] BTRFS info (device loop6): enabling ssd optimizations
[ 342.810967] NET: Registered protocol family 40
[ 343.806145] br0: port 2(tape926ec9f) entered blocking state
[ 343.806155] br0: port 2(tape926ec9f) entered disabled state
[ 343.806416] device tape926ec9f entered promiscuous mode
[ 345.186665] br0: port 2(tape926ec9f) entered blocking state
[ 345.186675] br0: port 2(tape926ec9f) entered listening state
[ 360.416178] br0: port 2(tape926ec9f) entered learning state
[ 375.520227] br0: port 2(tape926ec9f) entered forwarding state
[ 375.520234] br0: topology change detected, sending tcn bpdu
Can you show the output of ‘lxc info vm --show-log’?
By the this happens every time, so I repeated the process and below are outputs from both:-
Remote: unix://
Status: Stopped
Profiles: default
Pid: 2057
Resources:
Processes: 0
Snapshots:
Log:
dmesg
[ 12.004747] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.731672] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 13.771397] br0: port 1(eth0) entered blocking state
[ 13.771408] br0: port 1(eth0) entered disabled state
[ 13.771592] device eth0 entered promiscuous mode
[ 13.775447] bcmgenet: Skipping UMAC reset
[ 13.776850] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 13.777029] bcmgenet fd580000.ethernet eth0: Link is Down
[ 18.878345] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 18.878375] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.878462] br0: port 1(eth0) entered blocking state
[ 18.878469] br0: port 1(eth0) entered listening state
[ 23.006271] br0: port 1(eth0) entered learning state
[ 38.110268] br0: port 1(eth0) entered forwarding state
[ 38.110722] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[ 97.691019] new mount options do not match the existing superblock, will be ignored
[ 102.155224] bpfilter: Loaded bpfilter_umh pid 1865
[ 102.155831] Started bpfilter
[ 102.585816] BTRFS: device label default devid 1 transid 145454 /dev/loop6
[ 102.587132] BTRFS info (device loop6): disk space caching is enabled
[ 102.587142] BTRFS info (device loop6): has skinny extents
[ 102.759607] BTRFS info (device loop6): enabling ssd optimizations
[ 189.020001] NET: Registered protocol family 40
[ 189.901427] br0: port 2(tapd64f3b59) entered blocking state
[ 189.901437] br0: port 2(tapd64f3b59) entered disabled state
[ 189.901636] device tapd64f3b59 entered promiscuous mode
[ 190.961590] br0: port 2(tapd64f3b59) entered blocking state
[ 190.961601] br0: port 2(tapd64f3b59) entered listening state
[ 206.042070] br0: port 2(tapd64f3b59) entered learning state
[ 221.145672] br0: port 2(tapd64f3b59) entered forwarding state
[ 221.145679] br0: topology change detected, sending tcn bpdu
lxc list
| PiAlpine | STOPPED | | | VIRTUAL-MACHINE | 0 |
| PiDebian | STOPPED | | | VIRTUAL-MACHINE | 1 |
Weird, I just tested here on my rpi4 and VMs appear to be behaving as normal.
Can you show the full ps fauxww output as well as lxc config show --expanded PiDebian?
architecture: aarch64
image.architecture: arm64
image.description: Debian buster arm64 (20200702_06:12)
image.os: Debian
image.release: buster
image.serial: “20200702_06:12”
image.type: disk-kvm.img
limits.cpu: “2”
limits.memory: 512MB
security.secureboot: “false”
volatile.base_image: 1369ef99062ecf5cb50475194d04f58c7c6bf62b1c04f4cc91794fb26832157a
volatile.eth0.host_name: tap2a1e692a
volatile.eth0.hwaddr: 00:16:3e:6b:02:42
volatile.vm.uuid: 3ba93ea2-fa57-4e17-87d5-72a23cd9f907
nictype: bridged
parent: br0
pool: default
ps fauxww
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 2 0.0 0.0 0 0 ? S 19:38 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [rcu_gp]
root 4 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [rcu_par_gp]
root 7 0.3 0.0 0 0 ? I 19:38 0:03 \_ [kworker/u8:0-btrfs-endio-write]
root 8 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [mm_percpu_wq]
root 9 0.3 0.0 0 0 ? S 19:38 0:03 \_ [ksoftirqd/0]
root 10 0.0 0.0 0 0 ? I 19:38 0:00 \_ [rcu_sched]
root 11 0.0 0.0 0 0 ? S 19:38 0:00 \_ [migration/0]
root 12 0.0 0.0 0 0 ? S 19:38 0:00 \_ [idle_inject/0]
root 14 0.0 0.0 0 0 ? S 19:38 0:00 \_ [cpuhp/0]
root 15 0.0 0.0 0 0 ? S 19:38 0:00 \_ [cpuhp/1]
root 16 0.0 0.0 0 0 ? S 19:38 0:00 \_ [idle_inject/1]
root 17 0.0 0.0 0 0 ? S 19:38 0:00 \_ [migration/1]
root 18 0.2 0.0 0 0 ? S 19:38 0:02 \_ [ksoftirqd/1]
root 21 0.0 0.0 0 0 ? S 19:38 0:00 \_ [cpuhp/2]
root 22 0.0 0.0 0 0 ? S 19:38 0:00 \_ [idle_inject/2]
root 23 0.0 0.0 0 0 ? S 19:38 0:00 \_ [migration/2]
root 24 0.4 0.0 0 0 ? S 19:38 0:03 \_ [ksoftirqd/2]
root 27 0.0 0.0 0 0 ? S 19:38 0:00 \_ [cpuhp/3]
root 28 0.0 0.0 0 0 ? S 19:38 0:00 \_ [idle_inject/3]
root 29 0.0 0.0 0 0 ? S 19:38 0:00 \_ [migration/3]
root 30 0.1 0.0 0 0 ? S 19:38 0:01 \_ [ksoftirqd/3]
root 33 0.0 0.0 0 0 ? S 19:38 0:00 \_ [kdevtmpfs]
root 34 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [netns]
root 35 0.0 0.0 0 0 ? S 19:38 0:00 \_ [rcu_tasks_kthre]
root 36 0.0 0.0 0 0 ? S 19:38 0:00 \_ [kauditd]
root 37 0.0 0.0 0 0 ? S 19:38 0:00 \_ [khungtaskd]
root 38 0.0 0.0 0 0 ? S 19:38 0:00 \_ [oom_reaper]
root 39 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [writeback]
root 40 0.0 0.0 0 0 ? S 19:38 0:00 \_ [kcompactd0]
root 41 0.0 0.0 0 0 ? SN 19:38 0:00 \_ [ksmd]
root 43 0.1 0.0 0 0 ? I 19:38 0:01 \_ [kworker/u8:1-btrfs-endio-write]
root 136 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [kintegrityd]
root 137 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [kblockd]
root 138 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [blkcg_punt_bio]
root 139 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [tpm_dev_wq]
root 140 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [ata_sff]
root 141 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [md]
root 142 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [edac-poller]
root 143 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [devfreq_wq]
root 144 0.0 0.0 0 0 ? S 19:38 0:00 \_ [watchdogd]
root 145 0.0 0.0 0 0 ? I 19:38 0:00 \_ [kworker/1:1-events]
root 147 0.8 0.0 0 0 ? S 19:38 0:06 \_ [kswapd0]
root 148 0.0 0.0 0 0 ? S 19:38 0:00 \_ [ecryptfs-kthrea]
root 151 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [kthrotld]
root 152 0.0 0.0 0 0 ? S 19:38 0:00 \_ [irq/42-aerdrv]
root 154 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [DWC Notificatio]
root 155 0.0 0.0 0 0 ? I 19:38 0:00 \_ [kworker/2:2-mm_percpu_wq]
root 156 0.0 0.0 0 0 ? S< 19:38 0:00 \_ [vchiq-slot/0]
root 157 0.0 0.0 0 0 ? S< 19:38 0:00 \_ [vchiq-recy/0]
root 158 0.0 0.0 0 0 ? S< 19:38 0:00 \_ [vchiq-sync/0]
root 159 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [ipv6_addrconf]
root 170 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [kstrp]
root 174 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [kworker/u9:0]
root 179 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [cryptd]
root 242 0.0 0.0 0 0 ? I 19:38 0:00 \_ [kworker/0:2-events]
root 243 0.0 0.0 0 0 ? S 19:38 0:00 \_ [spi0]
root 244 0.0 0.0 0 0 ? S 19:38 0:00 \_ [irq/28-brcmstb_]
root 245 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [sdhci]
root 246 0.0 0.0 0 0 ? S 19:38 0:00 \_ [irq/27-mmc0]
root 247 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [charger_manager]
root 270 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [mmc_complete]
root 272 0.2 0.0 0 0 ? D< 19:38 0:02 \_ [kworker/0:1H+kblockd]
root 274 0.1 0.0 0 0 ? I< 19:38 0:00 \_ [kworker/3:1H-kblockd]
root 300 0.2 0.0 0 0 ? I< 19:38 0:02 \_ [kworker/2:1H-kblockd]
root 304 0.2 0.0 0 0 ? I< 19:38 0:02 \_ [kworker/1:1H-kblockd]
root 305 0.0 0.0 0 0 ? I< 19:38 0:00 \_ [kworker/1:2H-kblockd]
root 588 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [raid5wq]
root 645 0.0 0.0 0 0 ? D 19:39 0:00 \_ [jbd2/mmcblk0p2-]
root 646 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [ext4-rsv-conver]
root 742 0.0 0.0 0 0 ? I 19:39 0:00 \_ [kworker/3:2-events]
root 779 0.0 0.0 0 0 ? S 19:39 0:00 \_ [vchiq-keep/0]
root 780 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [SMIO]
root 836 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [cfg80211]
root 900 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [brcmf_wq/mmc1:0]
root 901 0.0 0.0 0 0 ? S 19:39 0:00 \_ [brcmf_wdog/mmc1]
root 1085 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [kaluad]
root 1086 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [kmpath_rdacd]
root 1087 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [kmpathd]
root 1088 0.0 0.0 0 0 ? I< 19:39 0:00 \_ [kmpath_handlerd]
root 1099 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [loop0]
root 1104 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [loop1]
root 1106 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [loop2]
root 1108 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [loop3]
root 1109 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [loop4]
root 1110 0.0 0.0 0 0 ? S< 19:39 0:00 \_ [loop5]
root 1766 0.2 0.0 0 0 ? I 19:44 0:01 \_ [kworker/u8:2-btrfs-endio-write]
root 1767 0.0 0.0 0 0 ? D 19:44 0:00 \_ [kworker/0:0+events_freezable]
root 1776 0.0 0.0 0 0 ? I 19:44 0:00 \_ [kworker/2:0-events]
root 1794 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [kworker/3:0H-kblockd]
root 1795 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [kworker/0:0H-kblockd]
root 1960 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [kworker/1:0H-kblockd]
root 1995 0.0 0.0 0 0 ? I 19:44 0:00 \_ [kworker/3:0-events]
root 2007 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [kworker/2:0H-kblockd]
root 2054 0.0 0.0 0 0 ? I 19:44 0:00 \_ [kworker/1:0-mm_percpu_wq]
root 2159 0.2 0.0 0 0 ? I 19:44 0:01 \_ [kworker/u8:3-flush-btrfs-1]
root 2164 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [dio/mmcblk0p2]
root 2168 0.0 0.0 0 0 ? I 19:44 0:00 \_ [kworker/0:3-mm_percpu_wq]
root 2186 0.0 0.0 1912 416 ? S 19:44 0:00 \_ bpfilter_umh
root 2199 0.0 0.0 0 0 ? I 19:44 0:00 \_ [kworker/2:3-events]
root 2214 3.6 0.0 0 0 ? D< 19:44 0:16 \_ [loop6]
root 2215 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-worker]
root 2216 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-worker-hi]
root 2217 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-delalloc]
root 2218 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-flush_del]
root 2219 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-cache]
root 2220 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-submit]
root 2221 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-fixup]
root 2222 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-endio]
root 2223 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-endio-met]
root 2224 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-endio-met]
root 2225 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-endio-rai]
root 2226 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-endio-rep]
root 2227 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-rmw]
root 2228 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-endio-wri]
root 2229 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-freespace]
root 2230 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-delayed-m]
root 2231 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-readahead]
root 2232 0.0 0.0 0 0 ? I< 19:44 0:00 \_ [btrfs-qgroup-re]
root 2234 0.0 0.0 0 0 ? S 19:44 0:00 \_ [btrfs-cleaner]
root 2235 0.1 0.0 0 0 ? S 19:44 0:00 \_ [btrfs-transacti]
root 2272 0.3 0.0 0 0 ? I 19:44 0:01 \_ [kworker/u8:4-btrfs-freespace-write]
root 2273 0.6 0.0 0 0 ? I 19:44 0:02 \_ [kworker/u8:5-btrfs-endio-write]
root 2274 0.1 0.0 0 0 ? D 19:46 0:00 \_ [kworker/u8:6+flush-179:0]
root 2275 0.2 0.0 0 0 ? I 19:46 0:00 \_ [kworker/u8:7-btrfs-endio-meta]
root 2276 0.1 0.0 0 0 ? I 19:46 0:00 \_ [kworker/u8:8-btrfs-endio-write]
root 2277 0.0 0.0 0 0 ? I 19:46 0:00 \_ [kworker/u8:9-btrfs-endio-meta]
root 2278 0.4 0.0 0 0 ? D 19:46 0:01 \_ [kworker/u8:10+btrfs-submit]
root 2279 0.0 0.0 0 0 ? I 19:46 0:00 \_ [kworker/u8:11-btrfs-endio-meta]
root 2280 0.0 0.0 0 0 ? I 19:46 0:00 \_ [kworker/u8:12-btrfs-endio-write]
root 2281 0.4 0.0 0 0 ? D 19:46 0:01 \_ [kworker/u8:13+events_unbound]
root 2468 0.4 0.0 0 0 ? I 19:48 0:01 \_ [kworker/u8:14-btrfs-endio-write]
root 2470 0.0 0.0 0 0 ? I 19:48 0:00 \_ [kworker/u8:15]
root 2477 0.0 0.0 0 0 ? S 19:48 0:00 \_ [vhost-2473]
root 2482 0.0 0.0 0 0 ? S 19:48 0:00 \_ [vhost-2473]
root 2506 0.0 0.0 0 0 ? I< 19:49 0:00 \_ [kworker/0:2H-kblockd]
root 2518 0.0 0.0 0 0 ? I< 19:50 0:00 \_ [kworker/2:2H-kblockd]
root 2520 0.0 0.0 0 0 ? I< 19:50 0:00 \_ [kworker/3:2H-kblockd]
root 2569 0.0 0.0 0 0 ? I 19:51 0:00 \_ [kworker/3:1-mm_percpu_wq]
root 2570 0.0 0.0 0 0 ? I 19:51 0:00 \_ [kworker/1:2-events]
root 2572 0.0 0.0 0 0 ? I 19:52 0:00 \_ [kworker/0:1-events]
root 1 0.3 0.2 167660 10396 ? Ss 19:38 0:03 /sbin/init fixrtc splash
root 720 0.0 0.1 67620 6996 ? S<s 19:39 0:00 /lib/systemd/systemd-journald
root 744 0.0 0.1 20084 4792 ? Ss 19:39 0:00 /lib/systemd/systemd-udevd
root 1089 0.0 0.4 280224 16604 ? SLsl 19:39 0:00 /sbin/multipathd -d -s
systemd+ 1130 0.0 0.1 90124 6444 ? Ssl 19:39 0:00 /lib/systemd/systemd-timesyncd
systemd+ 1177 0.0 0.1 18256 6900 ? Ss 19:39 0:00 /lib/systemd/systemd-networkd
systemd+ 1183 0.0 0.3 24080 12144 ? Ss 19:39 0:00 /lib/systemd/systemd-resolved
root 1221 0.0 0.1 237620 6804 ? Ssl 19:39 0:00 /usr/lib/accountsservice/accounts-daemon
message+ 1222 0.0 0.1 8188 4204 ? Ss 19:39 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 1225 0.0 0.0 80924 2996 ? Ssl 19:39 0:00 /usr/sbin/irqbalance --foreground
root 1226 0.0 0.4 29076 16676 ? Ss 19:39 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
syslog 1228 0.0 0.1 221160 4436 ? Ssl 19:39 0:00 /usr/sbin/rsyslogd -n -iNONE
root 1229 0.5 0.6 1139376 24980 ? Ssl 19:39 0:04 /usr/lib/snapd/snapd
root 1231 0.0 0.1 16620 6772 ? Ss 19:39 0:00 /lib/systemd/systemd-logind
root 1232 0.0 0.1 12356 4656 ? Ss 19:39 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root 1250 0.0 0.0 8328 2512 ? Ss 19:39 0:00 /usr/sbin/cron -f
root 1268 0.0 0.4 107784 19064 ? Ssl 19:39 0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
daemon 1270 0.0 0.0 3584 1824 ? Ss 19:39 0:00 /usr/sbin/atd -f
root 1274 0.0 0.0 6828 1884 ttyS0 Ss+ 19:39 0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyS0 vt220
root 1276 0.0 0.0 5304 1412 tty1 Ss+ 19:39 0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
root 1284 0.0 0.1 12184 6532 ? Ss 19:39 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root 1768 0.0 0.1 15460 7708 ? Ss 19:44 0:00 \_ sshd: wolfgang [priv]
wolfgang 1887 0.0 0.1 15332 4828 ? S 19:44 0:00 | \_ sshd: wolfgang@pts/0
wolfgang 1890 0.0 0.1 9916 4944 pts/0 Ss 19:44 0:00 | \_ -bash
wolfgang 2573 0.5 0.0 10508 3132 pts/0 R+ 19:52 0:00 | \_ ps fauxww
root 1835 0.0 0.2 15460 7772 ? Ss 19:44 0:00 \_ sshd: wolfgang [priv]
wolfgang 1950 0.0 0.1 15332 4876 ? S 19:44 0:00 \_ sshd: wolfgang@pts/1
wolfgang 1951 0.0 0.1 9916 4716 pts/1 Ss 19:44 0:00 \_ -bash
wolfgang 1961 2.0 0.0 7308 3228 pts/1 S+ 19:44 0:09 \_ htop
root 1288 0.0 0.1 232916 6176 ? Ssl 19:39 0:00 /usr/lib/policykit-1/polkitd --no-debug
wolfgang 1771 0.1 0.2 19564 10160 ? Ss 19:44 0:00 /lib/systemd/systemd --user
wolfgang 1772 0.0 0.1 169732 5088 ? S 19:44 0:00 \_ (sd-pam)
root 2001 0.0 0.0 1912 1308 ? Ss 19:44 0:00 /bin/sh /snap/lxd/15938/commands/daemon.start
root 2137 9.9 4.4 1879776 171312 ? Sl 19:44 0:45 \_ lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
root 2514 77.7 0.4 455120 19056 ? Sl 19:49 1:58 \_ qemu-img dd -f qcow2 -O raw bs=8192 if=/var/snap/lxd/common/lxd/images/82c207779f6beda3ff7d716cd566ee21c44624d336705b3ab8d97a7dd6dcdf8f.rootfs of=/var/snap/lxd/common/lxd/storage-pools/default/images/82c207779f6beda3ff7d716cd566ee21c44624d336705b3ab8d97a7dd6dcdf8f/root.img
root 2126 0.0 0.0 85148 1132 ? Sl 19:44 0:00 lxcfs /var/snap/lxd/common/var/lib/lxcfs -p /var/snap/lxd/common/lxcfs.pid
lxd 2473 11.3 10.8 1467840 420780 ? Sl 19:48 0:27 /snap/lxd/15938/bin/qemu-system-aarch64 -S -name PiDebian -uuid 3ba93ea2-fa57-4e17-87d5-72a23cd9f907 -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-reboot -no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=deny,resourcecontrol=deny -readconfig /var/snap/lxd/common/lxd/logs/PiDebian/qemu.conf -pidfile /var/snap/lxd/common/lxd/logs/PiDebian/qemu.pid -D /var/snap/lxd/common/lxd/logs/PiDebian/qemu.log -chroot /var/snap/lxd/common/lxd/virtual-machines/PiDebian -smbios type=2,manufacturer=Canonical Ltd.,product=LXD -runas lxd
That’s pretty weird…
Can you show cat /var/snap/lxd/common/lxd/logs/PiDebian/qemu.log.
Also, run lxc monitor --type=logging --pretty in a separate terminal and then in your main one, run lxc info PiDebian then provide the output from both, maybe that will shed some light on what’s going on there.
The qemu.log file is empty with a size of 0 bytes:-
root@PiLXD:/var/snap/lxd/common/lxd/logs/PiDebian# ls -al
total 16
drwx------ 2 root root 4096 Jul 3 19:48 .
drwx------ 19 root root 4096 Jul 3 19:44 …
-rw-r----- 1 root root 3459 Jul 3 19:48 qemu.conf
-rw-r----- 1 root root 0 Jul 3 19:48 qemu.log
srwxr-x— 1 root root 0 Jul 3 19:48 qemu.monitor
-rw------- 1 root root 5 Jul 3 19:48 qemu.pid
srwxr-x— 1 root root 0 Jul 3 19:48 qemu.spice
lxc info PiDebian
Remote: unix://
Status: Stopped
Profiles: default
Pid: 2473
Resources:
Processes: 0
Snapshots:
To start your first instance, try: lxc launch ubuntu:18.04
DBUG[07-03|20:08:32] New event listener: 51966818-aec3-40cc-9147-01881d9c97b3
DBUG[07-03|20:08:50] Handling ip=@ method=GET url=/1.0 user=
DBUG[07-03|20:08:50] Handling method=GET url=/1.0/instances/PiDebian user= ip=@
DBUG[07-03|20:08:50] Handling ip=@ method=GET url=/1.0/instances/PiDebian/state user=
DBUG[07-03|20:08:50] Handling ip=@ method=GET url="/1.0/instances/PiDebian/snapshots?recursion=1" user=
DBUG[07-03|20:08:50] GetInstanceUsage started pool=default project=default driver=btrfs instance=PiDebian/BeforeDocker
DBUG[07-03|20:08:50] GetInstanceUsage finished driver=btrfs instance=PiDebian/BeforeDocker pool=default project=default
By the way my 3 other VMs boot fine. So only this VM (Debian) is causing this problem.
That’s pretty weird. Does a new VM also work properly?
For that Debian VM, can you try: nc -v -U /var/snap/lxd/common/lxd/logs/PiDebian/qemu.monitor
nc -v -U /var/snap/lxd/common/lxd/logs/PiDebian/qemu.monitor yields no output
Another weird thing. If I reboot the Pi 4, start one of those other 3 VMs first. Then wait a minute and then boot the Debian VM then it boots fine.
That is very weird…
The nc -U call not returning anything hints that LXD is probably connected to qemu, that or qemu is completely unresponsive, it’s kinda hard to tell…
If you want to try to debug it further when it’s stuck, you can run that nc -v -U from above and then reload LXD with systemctl reload snap.lxd.daemon. That will disconnect LXD from QMP and should connect you instead.
You’ll see something like:
{"QMP": {"version": {"qemu": {"micro": 0, "minor": 0, "major": 5}, "package": "v5.0.0-dirty"}, "capabilities": ["oob"]}}
At which point you can enter:
{"execute":"qmp_capabilities"}
{"execute":"query-status"}
On a properly working qemu, that would get you:
{"return": {"status": "running", "singlestep": false, "running": true}}
I’m assuming you’ve also already tried pinging the IP address of that VM to see if it’s responsive even when LXD shows it stopped?
Just now I tried pinging it and no response. It is still running in htop though. It is idling with not much cpu usage but it is still using the full 512MB of memory.
