I’m having a problem where one of my OVN networks can not reach the outside world.
It can:
- Reach other instances within the network on different hosts.
- It can reach it’s own gateway
It can’t reach anything past the gateway.
lxc network info external-services --target=labhost-02 --project external-services
MAC address: 00:16:3e:8b:a9:bf
MTU: 1442
State: up
Type: broadcast
IP addresses:
inet 192.168.51.1/24 (link)
inet6 fd42:c416:702d:be56::1/64 (link)
Network usage:
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
OVN:
Chassis: LABHOST-02.thelabs.online
IP Routes
ip route
default via 192.168.51.1 dev eth0 proto dhcp src 192.168.51.2 metric 100
10.0.0.0/24 dev wg0 proto kernel scope link src 10.0.0.1
192.168.20.2 via 192.168.51.1 dev eth0 proto dhcp src 192.168.51.2 metric 100
192.168.20.3 via 192.168.51.1 dev eth0 proto dhcp src 192.168.51.2 metric 100
192.168.51.0/24 dev eth0 proto kernel scope link src 192.168.51.2 metric 100
192.168.51.1 dev eth0 proto dhcp scope link src 192.168.51.2 metric 100
The Network
bridge.mtu: "1442"
dns.zone.forward: lxd.external-services.thelabs.online
dns.zone.reverse.ipv4: 51.168.192.in-addr.arpa
ipv4.address: 192.168.51.1/24
ipv4.nat: "false"
ipv6.address: fd42:c416:702d:be56::1/64
ipv6.nat: "true"
network: UPLINK
volatile.network.ipv4.address: 192.168.20.31
volatile.network.ipv6.address: 2600:8802:b00:1602:216:3eff:fe8b:a9bf
type: ovn
- /1.0/instances/fair-pangolin?project=external-services
- /1.0/instances/vpn-server?project=external-services
managed: true
status: Created
locations:
- labhost-01
- labhost-02
- labhost-03
What are some common troubleshooting tips for trying to troubleshoot ovn and lxd?
Thank you
