I’ve run into a stange issue, where /proc/sys/net doesn’t get mounted writeable in an unprivileged lxc container. I think the corresponding error in the container log is:
lxc_utils - utils.c:safe_mount:1707 - No such file or directory - Failed to mount /usr/lib/lxc/rootfs/proc/tty onto /usr/lib/lxc/rootfs/proc/sys/net
The stange thing is, that the the problem does not occur on lxc 4.0 with nearly the same config.
My config is pretty standard an looks as following:
# common config
# userns.conf is copied from LXC version 4.0
lxc.include = /usr/share/lxc/config/userns.conf.new
lxc.log.level = 0
# other rootfs
lxc.rootfs.path = dir:/cont/openwrt_19.02_fritz4040_00
# unprivileged uid/gid mapping
lxc.idmap = u 0 65536 65536
lxc.idmap = g 0 65536 65536
# hostname + network
lxc.uts.name = openwrt_t00
lxc.net.0.type = veth
lxc.net.0.flags = up
lxc.net.0.link = br-lan
lxc.net.0.hwaddr = 4a:49:43:49:79:b9
# lxc.net.0.ipv4.address = 192.168.1.102/24
# lxc.net.0.ipv4.gateway = 192.168.1.1
The copied user config looks as following ( /usr/share/lxc/config/userns.conf.new )
# CAP_SYS_ADMIN in init-user-ns is required for cgroup.devices
lxc.cgroup.devices.deny =
lxc.cgroup.devices.allow =
# Start with a full set of capabilities in user namespaces.
lxc.cap.drop =
lxc.cap.keep =
# We can't move bind-mounts, so don't use /dev/lxc/
lxc.tty.dir =
# Setup the default mounts
lxc.mount.auto = sys:rw
The mount points in the running container are these:
root@openwrt_t00:/# cat /proc/self/mounts
/dev/sda1 / ext4 rw,relatime,data=ordered 0 0
none /dev tmpfs rw,relatime,size=492k,mode=755,uid=65536,gid=65536 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
proc /proc/sys proc ro,nosuid,nodev,noexec,relatime 0 0
proc /proc/sysrq-trigger proc ro,nosuid,nodev,noexec,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
tmpfs /dev/null tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/zero tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/full tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/urandom tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/random tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/tty tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
devpts /dev/console devpts rw,nosuid,noexec,relatime,mode=600,ptmxmode=000 0 0
devpts /dev/pts devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/ptmx devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty1 devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty2 devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty3 devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty4 devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty5 devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty6 devpts rw,relatime,gid=65541,mode=620,ptmxmode=666,max=1024 0 0
tmpfs /tmp tmpfs rw,nosuid,nodev,noatime,uid=65536,gid=65536 0 0
The Host is an Openwrt System:
$ uname -a
Linux OpenWrt 4.14.171 [..]
$ root@OpenWrt:/srv/lxc/openwrt-19.02_00# lxc-start --version
2.1.1
$ root@OpenWrt:/srv/lxc/openwrt-19.02_00# lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup v1 mount points:
/sys/fs/cgroup
Cgroup v2 mount points:
Cgroup v1 systemd controller: /usr/bin/lxc-checkconfig: line 167: printf \033[1;31m: not found
Cgroup v1 freezer controller: /usr/bin/lxc-checkconfig: line 174: printf \033[1;31m: not found
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Macvlan: enabled, loaded
Vlan: enabled, not loaded
Bridges: enabled, not loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: enabled, loaded
CONFIG_NF_NAT_IPV6: enabled, not loaded
CONFIG_IP_NF_TARGET_MASQUERADE: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loadedCONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, loaded
FUSE (for use with lxcfs): enabled, not loaded
--- Checkpoint/Restore ---
checkpoint restore: missing
CONFIG_FHANDLE: missing
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: missing
CONFIG_INET_DIAG: missing
CONFIG_PACKET_DIAG: missing
CONFIG_NETLINK_DIAG: missing
File capabilities: enabled
The full error Log:
lxc-start openwrt-19.02_00 20200522221131.136 TRACE lxc_commands - commands.c:lxc_cmd:290 - command get_init_pid tries to connect command socket
lxc-start openwrt-19.02_00 20200522221131.166 TRACE lxc_commands - commands.c:lxc_cmd:295 - command get_init_pid failed to connect command socket: Connection refused
lxc-start openwrt-19.02_00 20200522221131.206 TRACE lxc_commands - commands.c:lxc_cmd:290 - command get_cgroup tries to connect command socket
lxc-start openwrt-19.02_00 20200522221131.239 TRACE lxc_commands - commands.c:lxc_cmd:295 - command get_cgroup failed to connect command socket: Connection refused
lxc-start openwrt-19.02_00 20200522221131.273 TRACE lxc_commands - commands.c:lxc_cmd_get_cgroup_path:440 - command get_cgroup failed for container "openwrt-19.02_00": Connection refused.
lxc-start openwrt-19.02_00 20200522221131.315 TRACE lxc_commands - commands.c:lxc_cmd:290 - command get_state tries to connect command socket
lxc-start openwrt-19.02_00 20200522221131.346 TRACE lxc_commands - commands.c:lxc_cmd:295 - command get_state failed to connect command socket: Connection refused
lxc-start openwrt-19.02_00 20200522221131.379 TRACE lxc_start - start.c:lxc_init_handler:592 - unix domain socket 4 for command server is ready
lxc-start openwrt-19.02_00 20200522221131.412 TRACE lxc_start - start.c:lxc_init:607 - initialized LSM
lxc-start openwrt-19.02_00 20200522221131.444 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .reject_force_umount # comment this to allow umount -f; not recommended.
lxc-start openwrt-19.02_00 20200522221131.473 INFO lxc_seccomp - seccomp.c:parse_config_v2:594 - Adding native rule for reject_force_umount action 0(kill).
lxc-start openwrt-19.02_00 20200522221131.505 INFO lxc_seccomp - seccomp.c:do_resolve_add_rule:276 - Setting Seccomp rule to reject force umounts.
lxc-start openwrt-19.02_00 20200522221131.535 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .[all].
lxc-start openwrt-19.02_00 20200522221131.562 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .kexec_load errno 1.
lxc-start openwrt-19.02_00 20200522221131.590 INFO lxc_seccomp - seccomp.c:parse_config_v2:594 - Adding native rule for kexec_load action 327681(errno).
lxc-start openwrt-19.02_00 20200522221131.621 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .open_by_handle_at errno 1.
lxc-start openwrt-19.02_00 20200522221131.651 INFO lxc_seccomp - seccomp.c:parse_config_v2:594 - Adding native rule for open_by_handle_at action 327681(errno).
lxc-start openwrt-19.02_00 20200522221131.679 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .init_module errno 1.
lxc-start openwrt-19.02_00 20200522221131.708 INFO lxc_seccomp - seccomp.c:parse_config_v2:594 - Adding native rule for init_module action 327681(errno).
lxc-start openwrt-19.02_00 20200522221131.739 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .finit_module errno 1.
lxc-start openwrt-19.02_00 20200522221131.768 INFO lxc_seccomp - seccomp.c:parse_config_v2:594 - Adding native rule for finit_module action 327681(errno).
lxc-start openwrt-19.02_00 20200522221131.798 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .delete_module errno 1.
lxc-start openwrt-19.02_00 20200522221131.826 INFO lxc_seccomp - seccomp.c:parse_config_v2:594 - Adding native rule for delete_module action 327681(errno).
lxc-start openwrt-19.02_00 20200522221131.858 TRACE lxc_start - start.c:lxc_init:613 - read seccomp policy
lxc-start openwrt-19.02_00 20200522221131.888 TRACE lxc_start - start.c:lxc_serve_state_clients:373 - set container state to STARTING
lxc-start openwrt-19.02_00 20200522221131.916 TRACE lxc_start - start.c:lxc_serve_state_clients:376 - no state clients registered
lxc-start openwrt-19.02_00 20200522221131.946 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start openwrt-19.02_00 20200522221131.114 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start openwrt-19.02_00 20200522221131.117 TRACE lxc_start - start.c:lxc_init:620 - set container state to "STARTING"
lxc-start openwrt-19.02_00 20200522221131.119 TRACE lxc_start - start.c:lxc_init:648 - set environment variables
lxc-start openwrt-19.02_00 20200522221131.122 TRACE lxc_start - start.c:lxc_init:654 - ran pre-start hooks
lxc-start openwrt-19.02_00 20200522221131.125 DEBUG lxc_start - start.c:setup_signal_fd:301 - Set SIGCHLD handler with file descriptor: 5.
lxc-start openwrt-19.02_00 20200522221131.128 TRACE lxc_start - start.c:lxc_init:665 - set up signal fd
lxc-start openwrt-19.02_00 20200522221131.131 DEBUG console - console.c:lxc_console_peer_default:459 - using "/dev/tty" as peer tty device
lxc-start openwrt-19.02_00 20200522221131.134 DEBUG console - console.c:lxc_console_sigwinch_init:151 - process 11648 created signal fd 9 to handle SIGWINCH events
lxc-start openwrt-19.02_00 20200522221131.137 DEBUG console - console.c:lxc_console_winsz:71 - set winsz dstfd:6 cols:134 rows:34
lxc-start openwrt-19.02_00 20200522221131.140 TRACE lxc_start - start.c:lxc_init:672 - created console
lxc-start openwrt-19.02_00 20200522221131.142 TRACE lxc_conf - conf.c:lxc_ttys_shift_ids:2975 - chowned console "/dev/pts/10"
lxc-start openwrt-19.02_00 20200522221131.145 TRACE lxc_start - start.c:lxc_init:678 - shifted tty ids
lxc-start openwrt-19.02_00 20200522221131.148 INFO lxc_start - start.c:lxc_init:680 - container "openwrt-19.02_00" is initialized
lxc-start openwrt-19.02_00 20200522221131.151 DEBUG storage - storage/storage.c:get_storage_by_name:231 - Detected rootfs type "dir"
lxc-start openwrt-19.02_00 20200522221131.158 INFO lxc_network - network.c:instantiate_veth:171 - Retrieved mtu 1500 from br-lan
lxc-start openwrt-19.02_00 20200522221131.173 INFO lxc_network - network.c:instantiate_veth:197 - Attached "vethPEOKB2" to bridge "br-lan"
lxc-start openwrt-19.02_00 20200522221131.178 DEBUG lxc_network - network.c:instantiate_veth:214 - Instantiated veth "vethPEOKB2/veth9FLUH6", index is "107"
lxc-start openwrt-19.02_00 20200522221131.185 INFO lxc_cgroup - cgroups/cgroup.c:cgroup_init:67 - cgroup driver cgroupfs initing for openwrt-19.02_00
lxc-start openwrt-19.02_00 20200522221131.193 INFO lxc_start - start.c:lxc_spawn:1259 - Cloned CLONE_NEWUSER.
lxc-start openwrt-19.02_00 20200522221131.197 INFO lxc_start - start.c:lxc_spawn:1259 - Cloned CLONE_NEWNS.
lxc-start openwrt-19.02_00 20200522221131.200 INFO lxc_start - start.c:lxc_spawn:1259 - Cloned CLONE_NEWPID.
lxc-start openwrt-19.02_00 20200522221131.203 INFO lxc_start - start.c:lxc_spawn:1259 - Cloned CLONE_NEWUTS.
lxc-start openwrt-19.02_00 20200522221131.207 INFO lxc_start - start.c:lxc_spawn:1259 - Cloned CLONE_NEWIPC.
lxc-start openwrt-19.02_00 20200522221131.211 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2601 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start openwrt-19.02_00 20200522221131.215 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2601 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start openwrt-19.02_00 20200522221131.219 DEBUG lxc_conf - conf.c:lxc_map_ids:2689 - Functional newuidmap and newgidmap binary found.
lxc-start openwrt-19.02_00 20200522221131.231 TRACE lxc_conf - conf.c:lxc_map_ids:2745 - newuidmap wrote mapping "newuidmap 11661 0 65536 65536"
lxc-start openwrt-19.02_00 20200522221131.241 TRACE lxc_conf - conf.c:lxc_map_ids:2745 - newgidmap wrote mapping "newgidmap 11661 0 65536 65536"
lxc-start openwrt-19.02_00 20200522221131.248 INFO lxc_start - start.c:do_start:848 - Unshared CLONE_NEWNET.
lxc-start openwrt-19.02_00 20200522221131.272 TRACE lxc_conf - conf.c:userns_exec_1:3822 - establishing uid mapping for "11688" in new user namespace: nsuid 0 - hostid 65536 - range 65536
lxc-start openwrt-19.02_00 20200522221131.276 TRACE lxc_conf - conf.c:userns_exec_1:3822 - establishing uid mapping for "11688" in new user namespace: nsuid 65536 - hostid 0 - range 1
lxc-start openwrt-19.02_00 20200522221131.282 TRACE lxc_conf - conf.c:userns_exec_1:3822 - establishing gid mapping for "11688" in new user namespace: nsuid 0 - hostid 65536 - range 65536
lxc-start openwrt-19.02_00 20200522221131.287 TRACE lxc_conf - conf.c:userns_exec_1:3822 - establishing gid mapping for "11688" in new user namespace: nsuid 65536 - hostid 0 - range 1
lxc-start openwrt-19.02_00 20200522221131.292 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2601 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start openwrt-19.02_00 20200522221131.296 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2601 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start openwrt-19.02_00 20200522221131.300 DEBUG lxc_conf - conf.c:lxc_map_ids:2689 - Functional newuidmap and newgidmap binary found.
lxc-start openwrt-19.02_00 20200522221131.310 TRACE lxc_conf - conf.c:lxc_map_ids:2745 - newuidmap wrote mapping "newuidmap 11688 0 65536 65536 65536 0 1"
lxc-start openwrt-19.02_00 20200522221131.324 TRACE lxc_conf - conf.c:lxc_map_ids:2745 - newgidmap wrote mapping "newgidmap 11688 0 65536 65536 65536 0 1"
lxc-start openwrt-19.02_00 20200522221131.327 TRACE lxc_conf - conf.c:run_userns_fn:3582 - calling function "chown_cgroup_wrapper"
lxc-start openwrt-19.02_00 20200522221131.389 DEBUG lxc_network - network.c:lxc_network_move_created_netdev_priv:2445 - Moved network device "veth9FLUH6"/"(null)" to network namespace of 11661
lxc-start openwrt-19.02_00 20200522221131.393 NOTICE lxc_utils - utils.c:lxc_switch_uid_gid:2073 - Switched to gid 0.
lxc-start openwrt-19.02_00 20200522221131.398 NOTICE lxc_utils - utils.c:lxc_switch_uid_gid:2079 - Switched to uid 0.
lxc-start openwrt-19.02_00 20200522221131.401 NOTICE lxc_utils - utils.c:lxc_setgroups:2091 - Dropped additional groups.
lxc-start openwrt-19.02_00 20200522221131.406 INFO lxc_start - start.c:do_start:925 - Unshared CLONE_NEWCGROUP.
lxc-start openwrt-19.02_00 20200522221131.410 DEBUG storage - storage/storage.c:get_storage_by_name:231 - Detected rootfs type "dir"
lxc-start openwrt-19.02_00 20200522221131.414 TRACE dir - storage/dir.c:dir_mount:184 - Mounted "/cont/openwrt_19.02_fritz4040_00" on "/usr/lib/lxc/rootfs"
lxc-start openwrt-19.02_00 20200522221131.418 DEBUG lxc_conf - conf.c:lxc_setup_rootfs:1320 - Mounted rootfs "dir:/cont/openwrt_19.02_fritz4040_00" onto "/usr/lib/lxc/rootfs" with options "(null)".
lxc-start openwrt-19.02_00 20200522221131.421 INFO lxc_conf - conf.c:setup_utsname:769 - 'openwrt_t00' hostname has been setup
lxc-start openwrt-19.02_00 20200522221131.498 DEBUG lxc_network - network.c:setup_hw_addr:2711 - Mac address "4a:49:43:49:79:b9" on "eth0" has been setup
lxc-start openwrt-19.02_00 20200522221131.527 DEBUG lxc_network - network.c:lxc_setup_netdev_in_child_namespaces:2969 - Network device "eth0" has been setup
lxc-start openwrt-19.02_00 20200522221131.533 INFO lxc_network - network.c:lxc_setup_network_in_child_namespaces:2997 - network has been setup
lxc-start openwrt-19.02_00 20200522221131.538 TRACE lxc_network - network.c:lxc_network_send_name_and_ifindex_to_parent:3078 - Sent network device names and ifindeces to parent
lxc-start openwrt-19.02_00 20200522221131.542 INFO lxc_conf - conf.c:mount_autodev:1150 - Preparing "/dev"
lxc-start openwrt-19.02_00 20200522221131.546 INFO lxc_conf - conf.c:mount_autodev:1172 - Mounted tmpfs on "/usr/lib/lxc/rootfs/dev"
lxc-start openwrt-19.02_00 20200522221131.572 INFO lxc_conf - conf.c:mount_autodev:1189 - Prepared "/dev"
lxc-start openwrt-19.02_00 20200522221131.576 INFO lxc_conf - conf.c:lxc_mount_auto_mounts:709 - Mount source or target for /usr/lib/lxc/rootfs/proc/sys/net on /usr/lib/lxc/rootfs/proc/tty doesn't exist. Skipping.
lxc-start openwrt-19.02_00 20200522221131.580 ERROR lxc_utils - utils.c:safe_mount:1707 - No such file or directory - Failed to mount /usr/lib/lxc/rootfs/proc/tty onto /usr/lib/lxc/rootfs/proc/sys/net
lxc-start openwrt-19.02_00 20200522221131.584 INFO lxc_conf - conf.c:lxc_mount_auto_mounts:709 - Mount source or target for /usr/lib/lxc/rootfs/proc/tty on /usr/lib/lxc/rootfs/proc/sys/net doesn't exist. Skipping.
lxc-start openwrt-19.02_00 20200522221131.589 TRACE lxc_conf - conf.c:make_anonymous_mount_file:2257 - Created anonymous mount file
lxc-start openwrt-19.02_00 20200522221131.593 INFO lxc_conf - conf.c:mount_entry:1851 - Failed to mount "/sys/fs/fuse/connections" on "/usr/lib/lxc/rootfs/sys/fs/fuse/connections" (optional): No such file or directory
lxc-start openwrt-19.02_00 20200522221131.597 INFO lxc_conf - conf.c:mount_file_entries:2213 - Set up mount entries
lxc-start openwrt-19.02_00 20200522221131.600 INFO lxc_conf - conf.c:lxc_fill_autodev:1225 - Populating "/dev"
lxc-start openwrt-19.02_00 20200522221131.604 DEBUG lxc_conf - conf.c:lxc_fill_autodev:1269 - Bind mounted "/dev/null" onto "/usr/lib/lxc/rootfs/dev/null"
lxc-start openwrt-19.02_00 20200522221131.607 DEBUG lxc_conf - conf.c:lxc_fill_autodev:1269 - Bind mounted "/dev/zero" onto "/usr/lib/lxc/rootfs/dev/zero"
lxc-start openwrt-19.02_00 20200522221131.611 DEBUG lxc_conf - conf.c:lxc_fill_autodev:1269 - Bind mounted "/dev/full" onto "/usr/lib/lxc/rootfs/dev/full"
lxc-start openwrt-19.02_00 20200522221131.614 DEBUG lxc_conf - conf.c:lxc_fill_autodev:1269 - Bind mounted "/dev/urandom" onto "/usr/lib/lxc/rootfs/dev/urandom"
lxc-start openwrt-19.02_00 20200522221131.618 DEBUG lxc_conf - conf.c:lxc_fill_autodev:1269 - Bind mounted "/dev/random" onto "/usr/lib/lxc/rootfs/dev/random"
lxc-start openwrt-19.02_00 20200522221131.621 DEBUG lxc_conf - conf.c:lxc_fill_autodev:1269 - Bind mounted "/dev/tty" onto "/usr/lib/lxc/rootfs/dev/tty"
lxc-start openwrt-19.02_00 20200522221131.624 INFO lxc_conf - conf.c:lxc_fill_autodev:1276 - Populated "/dev"
lxc-start openwrt-19.02_00 20200522221131.628 DEBUG lxc_conf - conf.c:lxc_setup_dev_console:1604 - mounted pts device "/dev/pts/10" onto "/usr/lib/lxc/rootfs/dev/console"
lxc-start openwrt-19.02_00 20200522221131.631 INFO lxc_utils - utils.c:lxc_mount_proc_if_needed:1758 - I am 1, /proc/self points to "1"
lxc-start openwrt-19.02_00 20200522221131.679 DEBUG lxc_conf - conf.c:setup_rootfs_pivot_root:1128 - pivot_root syscall to '/usr/lib/lxc/rootfs' successful
lxc-start openwrt-19.02_00 20200522221131.692 DEBUG lxc_conf - conf.c:setup_pivot_root:1437 - finished pivot root
lxc-start openwrt-19.02_00 20200522221131.696 DEBUG lxc_conf - conf.c:lxc_setup_devpts:1482 - mount new devpts instance with options "newinstance,ptmxmode=0666,mode=0620,gid=5,max=1024"
lxc-start openwrt-19.02_00 20200522221131.701 DEBUG lxc_conf - conf.c:lxc_setup_devpts:1502 - created dummy "/dev/ptmx" file as bind mount target
lxc-start openwrt-19.02_00 20200522221131.705 DEBUG lxc_conf - conf.c:lxc_setup_devpts:1507 - bind mounted "/dev/pts/ptmx" to "/dev/ptmx"
lxc-start openwrt-19.02_00 20200522221131.709 DEBUG lxc_conf - conf.c:lxc_allocate_ttys:965 - allocated pty "/dev/pts/0" with master fd 11 and slave fd 14
lxc-start openwrt-19.02_00 20200522221131.713 DEBUG lxc_conf - conf.c:lxc_allocate_ttys:965 - allocated pty "/dev/pts/1" with master fd 15 and slave fd 16
lxc-start openwrt-19.02_00 20200522221131.716 DEBUG lxc_conf - conf.c:lxc_allocate_ttys:965 - allocated pty "/dev/pts/2" with master fd 17 and slave fd 18
lxc-start openwrt-19.02_00 20200522221131.735 DEBUG lxc_conf - conf.c:lxc_allocate_ttys:965 - allocated pty "/dev/pts/3" with master fd 19 and slave fd 20
lxc-start openwrt-19.02_00 20200522221131.739 DEBUG lxc_conf - conf.c:lxc_allocate_ttys:965 - allocated pty "/dev/pts/4" with master fd 21 and slave fd 22
lxc-start openwrt-19.02_00 20200522221131.742 DEBUG lxc_conf - conf.c:lxc_allocate_ttys:965 - allocated pty "/dev/pts/5" with master fd 23 and slave fd 24
lxc-start openwrt-19.02_00 20200522221131.745 INFO lxc_conf - conf.c:lxc_allocate_ttys:985 - finished allocating 6 pts devices
lxc-start openwrt-19.02_00 20200522221131.748 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1028 - Send pty "/dev/pts/0" with master fd 11 and slave fd 14 to parent
lxc-start openwrt-19.02_00 20200522221131.752 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1028 - Send pty "/dev/pts/1" with master fd 15 and slave fd 16 to parent
lxc-start openwrt-19.02_00 20200522221131.756 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1028 - Send pty "/dev/pts/2" with master fd 17 and slave fd 18 to parent
lxc-start openwrt-19.02_00 20200522221131.761 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1028 - Send pty "/dev/pts/3" with master fd 19 and slave fd 20 to parent
lxc-start openwrt-19.02_00 20200522221131.764 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1028 - Send pty "/dev/pts/4" with master fd 21 and slave fd 22 to parent
lxc-start openwrt-19.02_00 20200522221131.769 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1028 - Send pty "/dev/pts/5" with master fd 23 and slave fd 24 to parent
lxc-start openwrt-19.02_00 20200522221131.773 TRACE lxc_conf - conf.c:lxc_send_ttys_to_parent:1035 - Sent 6 ttys to parent
lxc-start openwrt-19.02_00 20200522221131.777 DEBUG lxc_conf - conf.c:lxc_setup_ttys:922 - Bind mounted "/dev/pts/0" onto "/dev/tty1"
lxc-start openwrt-19.02_00 20200522221131.781 DEBUG lxc_conf - conf.c:lxc_setup_ttys:922 - Bind mounted "/dev/pts/1" onto "/dev/tty2"
lxc-start openwrt-19.02_00 20200522221131.785 DEBUG lxc_conf - conf.c:lxc_setup_ttys:922 - Bind mounted "/dev/pts/2" onto "/dev/tty3"
lxc-start openwrt-19.02_00 20200522221131.790 DEBUG lxc_conf - conf.c:lxc_setup_ttys:922 - Bind mounted "/dev/pts/3" onto "/dev/tty4"
lxc-start openwrt-19.02_00 20200522221131.794 DEBUG lxc_conf - conf.c:lxc_setup_ttys:922 - Bind mounted "/dev/pts/4" onto "/dev/tty5"
lxc-start openwrt-19.02_00 20200522221131.797 DEBUG lxc_conf - conf.c:lxc_setup_ttys:922 - Bind mounted "/dev/pts/5" onto "/dev/tty6"
lxc-start openwrt-19.02_00 20200522221131.800 INFO lxc_conf - conf.c:lxc_setup_ttys:931 - Finished setting up 6 /dev/tty<N> device(s)
lxc-start openwrt-19.02_00 20200522221131.803 DEBUG lxc_conf - conf.c:setup_caps:2378 - capabilities have been setup
lxc-start openwrt-19.02_00 20200522221131.806 NOTICE lxc_conf - conf.c:lxc_setup:3283 - Container "openwrt-19.02_00" is set up
# pseudo filter code start
# filter for arch arm (1073741864)
if ($arch == 1073741864)
# filter for syscall "finit_module" (379) [priority: 65535]
if ($syscall == 379)
action ERRNO(1);
# filter for syscall "open_by_handle_at" (371) [priority: 65535]
if ($syscall == 371)
action ERRNO(1);
# filter for syscall "kexec_load" (347) [priority: 65535]
if ($syscall == 347)
action ERRNO(1);
# filter for syscall "delete_module" (129) [priority: 65535]
if ($syscall == 129)
action ERRNO(1);
# filter for syscall "init_module" (128) [priority: 65535]
if ($syscall == 128)
action ERRNO(1);
# filter for syscall "umount2" (52) [priority: 65534]
if ($syscall == 52)
if ($a1 & 0x00000001 == 1)
action ERRNO(13);
# default action
action ALLOW;
# invalid architecture action
action KILL;
# pseudo filter code end
lxc-start openwrt-19.02_00 20200522221131.815 TRACE lxc_start - start.c:lxc_spawn:1348 - Set up cgroup device limits
lxc-start openwrt-19.02_00 20200522221131.818 NOTICE lxc_start - start.c:start:1532 - Exec'ing "/sbin/init".
lxc-start openwrt-19.02_00 20200522221131.839 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:252 - index: 0
lxc-start openwrt-19.02_00 20200522221131.842 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:253 - ifindex: 107
lxc-start openwrt-19.02_00 20200522221131.845 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:256 - type: veth
lxc-start openwrt-19.02_00 20200522221131.851 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:262 - veth1 : vethPEOKB2
lxc-start openwrt-19.02_00 20200522221131.855 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:265 - host side ifindex for veth device: 108
lxc-start openwrt-19.02_00 20200522221131.859 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:302 - flags: up
lxc-start openwrt-19.02_00 20200522221131.863 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:304 - link: br-lan
lxc-start openwrt-19.02_00 20200522221131.867 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:306 - name: eth0
lxc-start openwrt-19.02_00 20200522221131.872 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:308 - hwaddr: 4a:49:43:49:79:b9
lxc-start openwrt-19.02_00 20200522221131.876 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:317 - ipv4 gateway auto: false
lxc-start openwrt-19.02_00 20200522221131.879 TRACE lxc_confile_utils - confile_utils.c:lxc_log_configured_netdevs:333 - ipv6 gateway auto: false
lxc-start openwrt-19.02_00 20200522221131.882 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1114 - Received pty with master fd 20 and slave fd 21 from parent
lxc-start openwrt-19.02_00 20200522221131.885 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1114 - Received pty with master fd 22 and slave fd 23 from parent
lxc-start openwrt-19.02_00 20200522221131.888 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1114 - Received pty with master fd 24 and slave fd 25 from parent
lxc-start openwrt-19.02_00 20200522221131.892 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1114 - Received pty with master fd 26 and slave fd 27 from parent
lxc-start openwrt-19.02_00 20200522221131.895 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1114 - Received pty with master fd 28 and slave fd 29 from parent
lxc-start openwrt-19.02_00 20200522221131.898 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1114 - Received pty with master fd 30 and slave fd 31 from parent
lxc-start openwrt-19.02_00 20200522221131.901 TRACE lxc_start - start.c:lxc_recv_ttys_from_child:1120 - Received 6 ttys from child
lxc-start openwrt-19.02_00 20200522221131.904 NOTICE lxc_start - start.c:post_start:1543 - Started "/sbin/init" with pid "11661".
lxc-start openwrt-19.02_00 20200522221131.907 TRACE lxc_start - start.c:lxc_serve_state_clients:373 - set container state to RUNNING
lxc-start openwrt-19.02_00 20200522221131.910 TRACE lxc_start - start.c:lxc_serve_state_clients:376 - no state clients registered
lxc-start openwrt-19.02_00 20200522221131.914 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start openwrt-19.02_00 20200522221131.918 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start openwrt-19.02_00 20200522221131.921 TRACE lxc_start - start.c:lxc_poll:504 - lxc mainloop is ready
lxc-start openwrt-19.02_00 20200522221131.925 NOTICE lxc_start - start.c:signal_handler:350 - Received SIGCHLD from pid 11669 instead of container init 11661.
lxc-start openwrt-19.02_00 20200523125637.779 DEBUG console - console.c:lxc_console_winsz:71 - set winsz dstfd:6 cols:168
somehow can’t get the formatting prettier
