How can I explicitly split IPv4 and IPv6 traffic with a proxy device? Is it possible that I can’t define the IPV6_V6ONLY behaviour (or just a wrong assumption)?
Fact so far (see below): Nginx seems to differentiate IP version from received traffic, which depends on the the way the proxy device is configured.
Background
I have a container serving various nginx sites, so they all serve it via:
root@container:~# cat /etc/nginx/sites-enabled/normal.site | grep listen
listen 443 ssl proxy_protocol;
listen [::]:443 ssl proxy_protocol;
listen 80 proxy_protocol;
listen [::]:80 proxy_protocol;
and a site which I want to explicitly only serve in ipv6:
root@container:~# cat /etc/nginx/sites-enabled/ipv6.site | grep listen
Any unknown site not matching a server directive gets returned 444 Empty reply from server.
And for testing purposes the following /etc/hosts file:
root@server:~# cat /etc/hosts | grep ipv
::1 ip6-localhost ip6-loopback ipv6.site
case 1: with 127.0.01
If the device config is as follows:
http:
connect: tcp:127.0.0.1:80
listen: tcp:0.0.0.0:80
proxy_protocol: "true"
type: proxy
https:
connect: tcp:127.0.0.1:443
listen: tcp:0.0.0.0:443
type: proxy
I get:
root@server:~# curl -4 ipv6.site
curl: (52) Empty reply from server
root@server:~# curl -6 ipv6.site
Additionally for this case the tcpdump:
root@server:~# tcpdump -i any port 80
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on any, link-type LINUX_SLL (Linux cooked v1), capture size 262144 bytes
13:12:34.272833 IP localhost.42706 > localhost.http: Flags [S], seq 1588935550, win 65495, options [mss 65495,sackOK,TS val 4004873144 ecr 0,nop,wscale 7], length 0
13:12:34.272860 IP localhost.http > localhost.42706: Flags [S.], seq 3736461613, ack 1588935551, win 65483, options [mss 65495,sackOK,TS val 4004873144 ecr 4004873144,nop,wscale 7], length 0
13:12:34.272882 IP localhost.42706 > localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 4004873144 ecr 4004873144], length 0
13:12:34.272962 IP localhost.42706 > localhost.http: Flags [P.], seq 1:81, ack 1, win 512, options [nop,nop,TS val 4004873144 ecr 4004873144], length 80: HTTP: GET / HTTP/1.1
13:12:34.273709 IP localhost.http > localhost.42706: Flags [F.], seq 1, ack 81, win 512, options [nop,nop,TS val 4004873145 ecr 4004873144], length 0
13:12:34.273975 IP localhost.42706 > localhost.http: Flags [F.], seq 81, ack 2, win 512, options [nop,nop,TS val 4004873145 ecr 4004873145], length 0
13:12:34.273999 IP localhost.http > localhost.42706: Flags [.], ack 82, win 512, options [nop,nop,TS val 4004873145 ecr 4004873145], length 0
13:12:46.320884 IP6 ip6-localhost.41432 > ip6-localhost.http: Flags [S], seq 670525252, win 65476, options [mss 65476,sackOK,TS val 729838226 ecr 0,nop,wscale 7], length 0
13:12:46.320908 IP6 ip6-localhost.http > ip6-localhost.41432: Flags [S.], seq 3237775875, ack 670525253, win 65464, options [mss 65476,sackOK,TS val 729838226 ecr 729838226,nop,wscale 7], length 0
13:12:46.320929 IP6 ip6-localhost.41432 > ip6-localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 729838226 ecr 729838226], length 0
13:12:46.321008 IP6 ip6-localhost.41432 > ip6-localhost.http: Flags [P.], seq 1:81, ack 1, win 512, options [nop,nop,TS val 729838226 ecr 729838226], length 80: HTTP: GET / HTTP/1.1
13:12:46.321753 IP6 ip6-localhost.http > ip6-localhost.41432: Flags [F.], seq 1, ack 81, win 512, options [nop,nop,TS val 729838227 ecr 729838226], length 0
13:12:46.322037 IP6 ip6-localhost.41432 > ip6-localhost.http: Flags [F.], seq 81, ack 2, win 512, options [nop,nop,TS val 729838227 ecr 729838227], length 0
13:12:46.322056 IP6 ip6-localhost.http > ip6-localhost.41432: Flags [.], ack 82, win 512, options [nop,nop,TS val 729838227 ecr 729838227], length 0
which shows that the first curl is effectively using IPv4 and the second one is using IPv6.
Inside the container though everything is IPv4 now:
root@container:~# tcpdump -i any port 80
12:12:34.273075 IP localhost.42708 > localhost.http: Flags [S], seq 1834994760, win 65495, options [mss 65495,sackOK,TS val 4004873144 ecr 0,nop,wscale 7], length 0
12:12:34.273093 IP localhost.http > localhost.42708: Flags [S.], seq 3146860621, ack 1834994761, win 65483, options [mss 65495,sackOK,TS val 4004873144 ecr 4004873144,nop,wscale 7], length 0
12:12:34.273109 IP localhost.42708 > localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 4004873144 ecr 4004873144], length 0
12:12:34.273215 IP localhost.42708 > localhost.http: Flags [P.], seq 1:42, ack 1, win 512, options [nop,nop,TS val 4004873144 ecr 4004873144], length 41: HTTP
12:12:34.273628 IP localhost.42708 > localhost.http: Flags [F.], seq 122, ack 2, win 512, options [nop,nop,TS val 4004873145 ecr 4004873145], length 0
12:12:34.273643 IP localhost.http > localhost.42708: Flags [.], ack 123, win 512, options [nop,nop,TS val 4004873145 ecr 4004873145], length 0
12:12:46.321083 IP localhost.42712 > localhost.http: Flags [S], seq 3319134991, win 65495, options [mss 65495,sackOK,TS val 4004885192 ecr 0,nop,wscale 7], length 0
12:12:46.321100 IP localhost.http > localhost.42712: Flags [S.], seq 3551039829, ack 3319134992, win 65483, options [mss 65495,sackOK,TS val 4004885192 ecr 4004885192,nop,wscale 7], length 0
12:12:46.321113 IP localhost.42712 > localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 4004885192 ecr 4004885192], length 0
12:12:46.321245 IP localhost.42712 > localhost.http: Flags [P.], seq 1:30, ack 1, win 512, options [nop,nop,TS val 4004885192 ecr 4004885192], length 29: HTTP
12:12:46.321253 IP localhost.http > localhost.42712: Flags [.], ack 30, win 512, options [nop,nop,TS val 4004885192 ecr 4004885192], length 0
12:12:46.321426 IP localhost.42712 > localhost.http: Flags [P.], seq 30:110, ack 1, win 512, options [nop,nop,TS val 4004885193 ecr 4004885192], length 80: HTTP: GET / HTTP/1.1
12:12:46.321437 IP localhost.http > localhost.42712: Flags [.], ack 110, win 512, options [nop,nop,TS val 4004885193 ecr 4004885193], length 0
12:12:46.321619 IP localhost.http > localhost.42712: Flags [F.], seq 1, ack 110, win 512, options [nop,nop,TS val 4004885193 ecr 4004885193], length 0
12:12:46.321674 IP localhost.42712 > localhost.http: Flags [F.], seq 110, ack 2, win 512, options [nop,nop,TS val 4004885193 ecr 4004885193], length 0
12:12:46.321685 IP localhost.http > localhost.42712: Flags [.], ack 111, win 512, options [nop,nop,TS val 4004885193 ecr 4004885193], length 0
Since nginx received the request as localhost.http, it does not serve the request for this site
case 2: with [::1]
If I set the device config as follows:
http:
connect: tcp:[::1]:80
listen: tcp:[::]:80
type: proxy
https:
connect: tcp:[::1]:443
listen: tcp:[::]:443
type: proxy
I get:
<!DOCTYPE html>
<!DOCTYPE html>
13:06:16.182619 IP localhost.42692 > localhost.http: Flags [S], seq 1938281950, win 65495, options [mss 65495,sackOK,TS val 4004495054 ecr 0,nop,wscale 7], length 0
13:06:16.182645 IP localhost.http > localhost.42692: Flags [S.], seq 1605870375, ack 1938281951, win 65483, options [mss 65495,sackOK,TS val 4004495054 ecr 4004495054,nop,wscale 7], length 0
13:06:16.182667 IP localhost.42692 > localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 4004495054 ecr 4004495054], length 0
13:06:16.182754 IP localhost.42692 > localhost.http: Flags [P.], seq 1:81, ack 1, win 512, options [nop,nop,TS val 4004495054 ecr 4004495054], length 80: HTTP: GET / HTTP/1.1
13:06:16.183555 IP localhost.http > localhost.42692: Flags [P.], seq 1:1150, ack 81, win 512, options [nop,nop,TS val 4004495055 ecr 4004495054], length 1149: HTTP: HTTP/1.1 200 OK
13:06:16.183584 IP localhost.42692 > localhost.http: Flags [.], ack 1150, win 504, options [nop,nop,TS val 4004495055 ecr 4004495055], length 0
13:06:16.183803 IP localhost.42692 > localhost.http: Flags [F.], seq 81, ack 1150, win 512, options [nop,nop,TS val 4004495055 ecr 4004495055], length 0
13:06:16.183988 IP localhost.http > localhost.42692: Flags [F.], seq 1150, ack 82, win 512, options [nop,nop,TS val 4004495055 ecr 4004495055], length 0
13:06:16.184004 IP localhost.42692 > localhost.http: Flags [.], ack 1151, win 512, options [nop,nop,TS val 4004495055 ecr 4004495055], length 0
13:06:20.950320 IP6 ip6-localhost.41418 > ip6-localhost.http: Flags [S], seq 3251368108, win 65476, options [mss 65476,sackOK,TS val 729452856 ecr 0,nop,wscale 7], length 0
13:06:20.950341 IP6 ip6-localhost.http > ip6-localhost.41418: Flags [S.], seq 1666642826, ack 3251368109, win 65464, options [mss 65476,sackOK,TS val 729452856 ecr 729452856,nop,wscale 7], length 0
13:06:20.950358 IP6 ip6-localhost.41418 > ip6-localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 0
13:06:20.950421 IP6 ip6-localhost.41418 > ip6-localhost.http: Flags [P.], seq 1:81, ack 1, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 80: HTTP: GET / HTTP/1.1
13:06:20.951276 IP6 ip6-localhost.http > ip6-localhost.41418: Flags [P.], seq 1:1150, ack 81, win 512, options [nop,nop,TS val 729452857 ecr 729452856], length 1149: HTTP: HTTP/1.1 200 OK
13:06:20.951302 IP6 ip6-localhost.41418 > ip6-localhost.http: Flags [.], ack 1150, win 504, options [nop,nop,TS val 729452857 ecr 729452857], length 0
13:06:20.951488 IP6 ip6-localhost.41418 > ip6-localhost.http: Flags [F.], seq 81, ack 1150, win 512, options [nop,nop,TS val 729452857 ecr 729452857], length 0
13:06:20.951574 IP6 ip6-localhost.http > ip6-localhost.41418: Flags [F.], seq 1150, ack 82, win 512, options [nop,nop,TS val 729452857 ecr 729452857], length 0
13:06:20.951585 IP6 ip6-localhost.41418 > ip6-localhost.http: Flags [.], ack 1151, win 512, options [nop,nop,TS val 729452857 ecr 729452857], length 0
Inside the container though everything is IPv6 now:
12:06:16.182881 IP6 ip6-localhost.41416 > ip6-localhost.http: Flags [S], seq 1799105677, win 65476, options [mss 65476,sackOK,TS val 729448088 ecr 0,nop,wscale 7], length 0
12:06:16.182898 IP6 ip6-localhost.http > ip6-localhost.41416: Flags [S.], seq 262452753, ack 1799105678, win 65464, options [mss 65476,sackOK,TS val 729448088 ecr 729448088,nop,wscale 7], length 0
12:06:16.182912 IP6 ip6-localhost.41416 > ip6-localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 729448088 ecr 729448088], length 0
12:06:16.183044 IP6 ip6-localhost.41416 > ip6-localhost.http: Flags [P.], seq 1:42, ack 1, win 512, options [nop,nop,TS val 729448088 ecr 729448088], length 41: HTTP
12:06:16.183495 IP6 ip6-localhost.http > ip6-localhost.41416: Flags [P.], seq 1:1150, ack 122, win 512, options [nop,nop,TS val 729448089 ecr 729448088], length 1149: HTTP: HTTP/1.1 200 OK
12:06:16.183507 IP6 ip6-localhost.41416 > ip6-localhost.http: Flags [.], ack 1150, win 504, options [nop,nop,TS val 729448089 ecr 729448089], length 0
12:06:16.183895 IP6 ip6-localhost.41416 > ip6-localhost.http: Flags [F.], seq 122, ack 1150, win 512, options [nop,nop,TS val 729448089 ecr 729448089], length 0
12:06:16.183942 IP6 ip6-localhost.http > ip6-localhost.41416: Flags [F.], seq 1150, ack 123, win 512, options [nop,nop,TS val 729448089 ecr 729448089], length 0
12:06:16.183955 IP6 ip6-localhost.41416 > ip6-localhost.http: Flags [.], ack 1151, win 512, options [nop,nop,TS val 729448089 ecr 729448089], length 0
12:06:20.950613 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [S], seq 1603331564, win 65476, options [mss 65476,sackOK,TS val 729452856 ecr 0,nop,wscale 7], length 0
12:06:20.950628 IP6 ip6-localhost.http > ip6-localhost.41420: Flags [S.], seq 2934414596, ack 1603331565, win 65464, options [mss 65476,sackOK,TS val 729452856 ecr 729452856,nop,wscale 7], length 0
12:06:20.950642 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [.], ack 1, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 0
12:06:20.950751 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [P.], seq 1:30, ack 1, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 29: HTTP
12:06:20.950762 IP6 ip6-localhost.http > ip6-localhost.41420: Flags [.], ack 30, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 0
12:06:20.950969 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [P.], seq 30:110, ack 1, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 80: HTTP: GET / HTTP/1.1
12:06:20.950981 IP6 ip6-localhost.http > ip6-localhost.41420: Flags [.], ack 110, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 0
12:06:20.951235 IP6 ip6-localhost.http > ip6-localhost.41420: Flags [P.], seq 1:1150, ack 110, win 512, options [nop,nop,TS val 729452856 ecr 729452856], length 1149: HTTP: HTTP/1.1 200 OK
12:06:20.951242 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [.], ack 1150, win 504, options [nop,nop,TS val 729452856 ecr 729452856], length 0
12:06:20.951535 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [F.], seq 110, ack 1150, win 512, options [nop,nop,TS val 729452857 ecr 729452856], length 0
12:06:20.951562 IP6 ip6-localhost.http > ip6-localhost.41420: Flags [F.], seq 1150, ack 111, win 512, options [nop,nop,TS val 729452857 ecr 729452857], length 0
12:06:20.951573 IP6 ip6-localhost.41420 > ip6-localhost.http: Flags [.], ack 1151, win 512, options [nop,nop,TS val 729452857 ecr 729452857], length 0
Since nginx received the request as ip-localhost.http, it serves the request for this site for both IPv4 and IPv6
case 3: defining both
If i try to set the device config as follows:
http-4:
type: proxy
https-4:
type: proxy
http-6:
listen: tcp:[::]:80
type: proxy
https-6:
type: proxy
I get the error:
Config parsing error: Failed to start device "http-6": Error occurred when starting proxy device: Error: Failed to listen on [::]:80: listen tcp 0.0.0.0:80: bind: address already in use
Press enter to open the editor again or ctrl+c to abort change
Maybe related:
