I have recently upgrade my incus system to 6.15 and the problem of starting vm still persist.
Here are my settings:
armbian@turing-rk1:~$ incus start test
Error: Failed to run: forklimits limit=memlock:unlimited:unlimited fd=3 fd=4 -- /opt/incus/bin/qemu-system-aarch64 -S -name test -uuid 2d605ef1-c857-46f2-b5b4-84aa8ee2844a -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=allow,resourcecontrol=deny -readconfig /run/incus/test/qemu.conf -spice unix=on,disable-ticketing=on,addr=/run/incus/test/qemu.spice -pidfile /run/incus/test/qemu.pid -D /var/log/incus/test/qemu.log -rtc base=2025-08-04T21:16:11 -smbios type=2,manufacturer=LinuxContainers,product=Incus -runas incus: : exit status 1
Try `incus info --show-log test` for more info
armbian@turing-rk1:~$ incus info --show-log test
Description:
Status: STOPPED
Type: virtual-machine
Architecture: aarch64
Created: 2025/08/05 00:10 +03
Last Used: 2025/08/05 00:11 +03
Log:
qemu-system-aarch64: Failed to put registers after init: Invalid argument
armbian@turing-rk1:~$ incus config show test --expanded
architecture: aarch64
image.architecture: arm64
image.description: Ubuntu noble arm64 (20250801_07:42)
image.os: Ubuntu
image.release: noble
image.requirements.cgroup: v2
image.serial: "20250801_07:42"
image.type: disk-kvm.img
image.variant: cloud
volatile.base_image: 2962aad138e91f4c7b147937e90fd51fe8e27a7c5a4c5d9e4b5d6b42fc143396
volatile.cloud-init.instance-id: deba9195-e461-4331-aded-5a8bfd3c0fdb
volatile.eth0.hwaddr: 10:66:6a:5b:21:9a
volatile.uuid: 2d605ef1-c857-46f2-b5b4-84aa8ee2844a
volatile.uuid.generation: 2d605ef1-c857-46f2-b5b4-84aa8ee2844a
volatile.vm.definition: virt-9.0
volatile.vm.rtc_adjustment: "0"
volatile.vm.rtc_offset: "0"
volatile.vsock_id: "3836583668"
network: incusbr0
pool: default
candlerb
(Brian Candler)
August 5, 2025, 2:24pm
2
What’s the hardware? What’s the OS on your host? Has this worked with a previous version of incus, if so which?
(Maybe workaround is to go to incus 6.0.4 LTS, but that would be a reinstall from scratch)
I found exactly the same error message here though, might be something useful to pick up from it: 24.04 beta: can't boot VMs on kvm, qemu works fine · Issue #731 · Joshua-Riek/ubuntu-rockchip · GitHub
Hi Brian, thanks for the reply.
The hardware is Turing RK1 modules and the OS Ubuntu 22.04. But tested with 24.04 and it is same. I think that there is something wrong with the cpu pinning. I have encountered the URL you shared with us and you point the right direction when I upgrade the kernel to something bigger than 6.10, problem disappears. I have tested with the stable Incus release but same error.
Here is the error message.
ubuntu@tnode2:~$ incus info --show-log test
Description:
Status: RUNNING
PID: 2188
Created: 2025/08/05 23:33 +03
Last Used: 2025/08/05 23:51 +03
Started: 2025/08/05 23:51 +03
Resources:
Processes: -1
Disk usage:
root: 5.03MiB
Network usage:
Type: broadcast
State: UP
Host interface: tapc6f82ddb
MAC address: 10:66:6a:3e:a8:8b
MTU: 1500
Bytes received: 602B
Bytes sent: 0B
Packets received: 3
Packets sent: 0
IP addresses:
inet: 10.56.164.228/24 (global)
inet6: fd42:7520:5ad9:f9ce:1266:6aff:fe3e:a88b/64 (global)
Log:
qemu-system-aarch64: Failed to put registers after reset: Invalid argument
PC=0000000000000000 X00=0000000000000000 X01=0000000000000000
X02=0000000000000000 X03=0000000000000000 X04=0000000000000000
X05=0000000000000000 X06=0000000000000000 X07=0000000000000000
X08=0000000000000000 X09=0000000000000000 X10=0000000000000000
X11=0000000000000000 X12=0000000000000000 X13=0000000000000000
X14=0000000000000000 X15=0000000000000000 X16=0000000000000000
X17=0000000000000000 X18=0000000000000000 X19=0000000000000000
X20=0000000000000000 X21=0000000000000000 X22=0000000000000000
X23=0000000000000000 X24=0000000000000000 X25=0000000000000000
X26=0000000000000000 X27=0000000000000000 X28=0000000000000000
X29=0000000000000000 X30=0000000000000000 SP=0000000000000000
PSTATE=400003c5 -Z-- EL1h
ubuntu@tnode2:~$ incus info --resources
System:
Product: Turing Machines RK1
Serial: 7d04ab8abd9337b0
Type: physical
Chassis:
Motherboard:
Load:
Processes: 347
Average: 1.07 0.90 0.46
CPUs:
Socket 0:
Caches:
- Level 1 (type: Data): 32KiB
- Level 1 (type: Instruction): 32KiB
- Level 2 (type: Unified): 128KiB
- Level 3 (type: Unified): 3MiB
Cores:
- Core 0
Frequency: 1800Mhz
Threads:
- 0 (id: 0, online: true, NUMA node: 0)
- Core 1
Frequency: 1800Mhz
Threads:
- 0 (id: 1, online: true, NUMA node: 0)
- Core 2
Frequency: 1800Mhz
Threads:
- 0 (id: 2, online: true, NUMA node: 0)
- Core 3
Frequency: 1800Mhz
Threads:
- 0 (id: 3, online: true, NUMA node: 0)
Frequency: 1800Mhz (min: 408Mhz, max: 1800Mhz)
Socket 1:
Caches:
- Level 1 (type: Data): 64KiB
- Level 1 (type: Instruction): 64KiB
- Level 2 (type: Unified): 512KiB
Cores:
- Core 0
Frequency: 2256Mhz
Threads:
- 0 (id: 4, online: true, NUMA node: 0)
- Core 1
Frequency: 2256Mhz
Threads:
- 0 (id: 5, online: true, NUMA node: 0)
Frequency: 2256Mhz (min: 408Mhz, max: 2256Mhz)
Socket 2:
Caches:
Cores:
- Core 0
Frequency: 2304Mhz
Threads:
- 0 (id: 6, online: true, NUMA node: 0)
- Core 1
Frequency: 2304Mhz
Threads:
- 0 (id: 7, online: true, NUMA node: 0)
Frequency: 2304Mhz (min: 408Mhz, max: 2304Mhz)
Memory:
Free: 30.47GiB
Used: 576.55MiB
Total: 31.03GiB
GPUs:
Card 0:
NUMA node: 0
Driver: rockchip-drm (5.10.0-1012-rockchip)
DRM:
Card: card0 (226:0)
Control: controlD64 (226:0)
Render: renderD128 (226:128)
Card 1:
NUMA node: 0
Driver: RKNPU (5.10.0-1012-rockchip)
DRM:
Card: card1 (226:1)
Render: renderD129 (226:129)
NIC:
NUMA node: 0
Driver: rk_gmac-dwmac (5.10.0-1012-rockchip)
Ports:
- Port 0 (ethernet)
Address: 5e:34:15:cf:db:74
Supported modes: 10baseT/Half, 10baseT/Full, 100baseT/Half, 100baseT/Full, 1000baseT/Full
Supported ports: twisted pair, media-independent
Port type: twisted pair
Transceiver type: external
Auto negotiation: true
Link detected: true
Link speed: 1000Mbit/s (full duplex)
Disks:
Disk 0:
NUMA node: 0
Device: 179:0
Type: mmc
Read-Only: false
Removable: false
Partitions:
- Partition 1
Device: 179:1
Read-Only: false
- Partition 2
Device: 179:2
Read-Only: false
Disk 1:
NUMA node: 0
Device: 179:32
Type: block
Read-Only: true
Removable: false
Disk 2:
NUMA node: 0
Device: 179:64
Type: block
Read-Only: true
Removable: false
Disk 3:
NUMA node: 0
Device: 259:0
Model: Longline SSD
Type: nvme
WWN: eui.00000000000000000000010000000000
Read-Only: false
Removable: false
Partitions:
- Partition 1
Device: 259:1
Read-Only: false
- Partition 9
Device: 259:2
Read-Only: false
Disk 4:
NUMA node: 0
Device: 8:0
Model: WDC WD20EARX-00P
Type: scsi
Read-Only: false
Removable: false
Disk 5:
NUMA node: 0
Device: 8:16
Type: scsi
Read-Only: false
Removable: false
Disk 6:
NUMA node: 0
Device: 8:32
Model: CT500BX500SSD1
Type: scsi
Read-Only: false
Removable: false
PCI devices:
Device 0:
Address: 0000:00:00.0
Vendor: Rockchip Electronics Co., Ltd
Vendor ID: 1d87
Product:
Product ID: 3588
NUMA node: 0
IOMMU group: 0
Driver: pcieport
Device 1:
Address: 0000:01:00.0
Vendor: Silicon Motion, Inc.
Vendor ID: 126f
Product: SM2263EN/SM2263XT SSD Controller
Product ID: 2263
NUMA node: 0
IOMMU group: 0
Driver: nvme
Device 2:
Address: 0001:30:00.0
Vendor ID: 1d87
Product:
Product ID: 3588
NUMA node: 0
IOMMU group: 0
Driver: pcieport
Device 3:
Address: 0001:31:00.0
Vendor: ASMedia Technology Inc.
Vendor ID: 1b21
Product:
Product ID: 1064
NUMA node: 0
IOMMU group: 0
Driver: ahci
candlerb
(Brian Candler)
August 6, 2025, 9:27am
4
Maybe that’s the answer then: install a newer kernel. e.g. linux-image-generic-hwe-24.04 (which for Ubuntu 24.04 on x86_64 is 6.14.0), or linux-image-generic-6.11, linux-image-generic-6.14
You are absolutely right, but there is a handicap here when I install a newer kernel version the NPU driver are gone. In this platform I have little experience so I’m stuck.
Regards.
candlerb
(Brian Candler)
August 6, 2025, 1:14pm
6
One to take up with the board vendor then?
