Hello, I want to run wireshark on a container, but i got trouble.
What should i do to connect to display?
Depending on what you’re trying to do, using tshark maybe easier.
thank you, but it’s just a test, i want to know what should i do to run a GUI app on container. Do i need to install vnc4server? Or maybe there’s a simpler solution.
Have a look at
thank you for your help
