First, LXD clustering looks amazing. Thanks so much for building this.
Question: The most I can find about which node in a cluster a container is placed on is that it’s done via “auto load-balancing”. Can you share some more details about how this is decided? What is the selection algorithm?
Glad that you like it. The algorithm is pretty simplistic at this point: pick the node with the least number of containers on it (running or stopped, that does not matter). If there is more than one candidate node, pick the first one.
