Hello everyone,
Simplestreams are one method to distribute LXD images. It’s directory structure however does not seem to be publicly documented. I’ve found the lxd-image-server project on Github that provides an overview of the directory structure used by Simplestreams. A live-example can be traversed on Canonical’s own image server. The available images and their location are specified in images.json and index.json.
The used directory structure seems to look like this:
/ # root directory
|- images # images folder
| `- ubuntu # environment
| `- xenial # release
| `- amd64 # architecture
| `- default # box type
| `- 20180716_12:00 # version 1
| |- lxd.tar.xz # index and templates
| `- rootfs.squashfs # rootfs of container
`- streams
`- v1
|- index.json # index of products
`- images.json # info with versions of products
images.json seems to just point to a location in the directory tree. Do images always have to be stored below the path /images/?
Or is it also possible to create additional subtrees like /images2/ and /images3/ to store images? In my scenario I plan to maintain the structure of the subtrees below /image*/ in regards to the release, processor architecture etc.
