Hi.
I tried the lxd-p2c test. test is well done
[Test env] : ubun 20.04 SRV (KVM)-lxd-p2c-> test (container)
There are two questions.
- I know that one of the biggest differences between VM and Container is that Container uses only user space and vm uses user / kerenel space.
When vm (physical server) is changed to container, how do i execute the command that needs to use kernel? (i.e. lvcreate)
- How do I migrate vm (or physical server) to vm?
Thank you.
