I rebooted my system and dont see any incus containers.
The system log shows this prior to reboot.
# journalctl --since "2024-10-17 21:00:00"|grep incus
Oct 17 22:07:17 tvbox systemd[1]: var-lib-incus-storage\x2dpools-pool1-images-67116b02f98564230887588368f1d1ff91749d617100bd7d5bdea247a03ba832.mount: Deactivated successfully.
Oct 17 22:07:19 tvbox incusd[890010]: time="2024-10-17T22:07:19+05:30" level=error msg="Failed to update the image" err="Failed getting remote image info: Failed getting image: The requested image couldn't be found" fingerprint=6b4a1d3ad551e1f62ad9fde737e2978663f00fa6376a2fef030ed36633918fc8
Oct 17 22:07:30 tvbox incusd[890010]: time="2024-10-17T22:07:30+05:30" level=error msg="Failed to update the image" err="Failed getting remote image info: Failed getting image: The requested image couldn't be found" fingerprint=acb8f742bfffa41f924939857b470b1ee6b55314e7219c65a7e982e0319ef3c5
Oct 17 22:07:31 tvbox incusd[890010]: time="2024-10-17T22:07:31+05:30" level=error msg="Failed to update the image" err="Failed getting remote image info: Failed getting image: The requested image couldn't be found" fingerprint=c533845b5db1747674ee915cbb20df6eb47c953bb7caf1fec5b35ae9ccf98c18
Oct 17 22:40:35 tvbox systemd[1]: incus.service: Stopping timed out. Terminating.
Oct 17 22:40:35 tvbox incusd[890010]: time="2024-10-17T22:40:35+05:30" level=warning msg="Ignoring signal, shutdown already in progress" signal=terminated
Oct 17 22:40:35 tvbox systemd[1]: incus.service: Control process exited, code=killed, status=15/TERM
Oct 17 22:41:05 tvbox systemd[1]: incus.service: State 'stop-sigterm' timed out. Killing.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Killing process 890010 (incusd) with signal SIGKILL.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Main process exited, code=killed, status=9/KILL
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Failed with result 'timeout'.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Unit process 890200 (dnsmasq) remains running after unit stopped.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Unit process 1096567 (incusd) remains running after unit stopped.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Unit process 2967195 (incusd) remains running after unit stopped.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Unit process 514292 (incusd) remains running after unit stopped.
Oct 17 22:41:05 tvbox systemd[1]: incus.service: Consumed 33min 1.715s CPU time, 521.9M memory peak.
Oct 17 22:41:06 tvbox systemd[1]: incus.socket: Deactivated successfully.
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/guestapi...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/shmounts...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/dbserver...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/docker1...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/icecast...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/mqtt...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/mythvm...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/openhab...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/proxy...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/rssh...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/default/containers/voip2...
Oct 17 22:41:07 tvbox systemd[1]: Unmounting /var/lib/incus/storage-pools/pool1/containers/esphome...
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-guestapi.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/guestapi.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-shmounts.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/shmounts.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-dbserver.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/dbserver.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-docker1.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/docker1.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-icecast.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/icecast.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-mqtt.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/mqtt.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-mythvm.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/mythvm.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-openhab.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/openhab.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-proxy.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/proxy.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-rssh.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/rssh.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-default-containers-voip2.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/default/containers/voip2.
Oct 17 22:41:11 tvbox systemd[1]: var-lib-incus-storage\x2dpools-pool1-containers-esphome.mount: Deactivated successfully.
Oct 17 22:41:11 tvbox systemd[1]: Unmounted /var/lib/incus/storage-pools/pool1/containers/esphome.
Oct 17 22:41:12 tvbox systemd[1]: Unmounting var-lib-incus.mount...
Oct 17 22:41:12 tvbox umount[408863]: umount: /var/lib/incus: target is busy.
Oct 17 22:41:12 tvbox systemd[1]: var-lib-incus.mount: Mount process exited, code=exited, status=32/n/a
Oct 17 22:41:12 tvbox systemd[1]: Failed unmounting var-lib-incus.mount.
Oct 17 22:46:40 tvbox incusd[9609]: time="2024-10-17T22:46:40+05:30" level=warning msg="AppArmor support has been disabled because of lack of kernel support"
Oct 17 22:46:40 tvbox incusd[9609]: time="2024-10-17T22:46:40+05:30" level=warning msg=" - AppArmor support has been disabled, Disabled because of lack of kernel support"
Oct 17 22:46:40 tvbox incusd[9609]: time="2024-10-17T22:46:40+05:30" level=error msg="Failed writing error for HTTP response" err="write unix /var/lib/incus/unix.socket->@: write: broken pipe" url=/1.0 writeErr="write unix /var/lib/incus/unix.socket->@: write: broken pipe"
Oct 17 22:46:50 tvbox incusd[9609]: time="2024-10-17T22:46:50+05:30" level=warning msg="Failed to update instance types: Get \"https://images.linuxcontainers.org/meta/instance-types/aws.yaml\": net/http: TLS handshake timeout"
Oct 17 22:46:50 tvbox incusd[9609]: time="2024-10-17T22:46:50+05:30" level=error msg="Failed updating instance types" err="Get \"https://images.linuxcontainers.org/meta/instance-types/aws.yaml\": net/http: TLS handshake timeout"
If i try to list incus containers i get,
# incus list
# tree /var/lib/incus --du -hs
[ 24M] /var/lib/incus
βββ [ 8] backups
β βββ [ 2] custom
β βββ [ 2] instances
βββ [ 2] containers
βββ [ 2] containers-snapshots
βββ [ 24M] database
β βββ [ 24M] global
β β βββ [ 64] 0000000000000001-0000000000000001
β β βββ [ 32] metadata1
β β βββ [8.0M] open-1
β β βββ [8.0M] open-2
β β βββ [8.0M] open-3
β βββ [ 48K] local.db
βββ [ 2] devices
βββ [ 2] disks
βββ [ 60] guestapi
β βββ [ 0] sock
βββ [ 2] images
βββ [ 2] networks
βββ [ 14] security
β βββ [ 8] apparmor
β β βββ [ 2] cache
β β βββ [ 2] profiles
β βββ [ 2] seccomp
βββ [ 745] server.crt
βββ [ 288] server.key
βββ [ 40] shmounts
βββ [ 2] storage-pools
βββ [ 0] unix.socket
βββ [ 2] virtual-machines
βββ [ 2] virtual-machines-snapshots
72M used in 22 directories, 10 files
The zfs dataset are still present.
rpool/lxd 29.1G 222G 96K legacy
rpool/lxd/buckets 96K 222G 96K legacy
rpool/lxd/containers 23.3G 222G 96K legacy
rpool/lxd/containers/dbserver 1.28G 222G 723M legacy
rpool/lxd/containers/docker1 3.59G 222G 3.27G legacy
rpool/lxd/containers/icecast 860M 222G 837M legacy
rpool/lxd/containers/mqtt 3.84M 222G 9.75M legacy
rpool/lxd/containers/mythvm 2.90G 222G 2.37G legacy
rpool/lxd/containers/openhab 2.63G 222G 1.80G legacy
rpool/lxd/containers/proxy 5.96G 222G 4.83G legacy
rpool/lxd/containers/rssh 7.64M 222G 14.0M legacy
rpool/lxd/containers/voip2 6.07G 222G 5.25G legacy
How do i get my containers back?
