I’m using AlmaLinux 8.10 and would like to use Incus 6.4. What is the recommended installation method?
I suspect you’re going to have to build it from source or build your own package based on the Fedora packaging.
There is ongoing work from @Conan_Kudo and others to add Incus 6.0 LTS to EPEL, but that will get you Incus 6.0.1 rather than 6.4.
Incus can also be run as a podman container: GitHub - cmspam/incus-docker: A project to run incus in docker/podman
