I’ve searched and I can’t seem to find a way to get this done. Environment: Ubuntu 18.04, lxd/lxd 3.0.0 that were installed originally and currently using aptitude. I created a storage pool using dir type that pointed to a directory on a ZFS pool because of redundancy in case of drive failure. Those drives are fine, it was the system drive that had the problems; been replaced. I was able to get the /var/lib/lxd directory copied. Putting that on the new system didn’t help. When I try to do "lxd import " it fails with the usual error of ‘Error: The container “mail” does not seem to exist on any storage pool’. I haven’t been able to figure out how to get the new installation of lxd to point the storage pool definition to the directory on the zfs pool. If I can get that working, then I’m going to try to import the containers.
Hi Stephane,
Thanks for responding. Another question: When I used the command lxc storage create data2dir dir source=/data/lxd_containers2 (I think I have the syntax messed up, but I’m sure you get the idea), how does that link from /var/lib/lxd/storage-pools/data2dir (which is just an empty directory on the original system) to the directory I provide? Because the volume is a ZFS pool, I’m not able to use the mount command.
I noticed this in the lxd.log file:
t=2020-08-13T11:44:18-0500 lvl=info msg=“Initializing local database”
t=2020-08-13T11:44:18-0500 lvl=eror msg=“Failed to start the daemon: Both legacy and new local database files exists”
t=2020-08-13T11:44:18-0500 lvl=info msg=“Starting shutdown sequence”
t=2020-08-13T11:44:18-0500 lvl=info msg=“Saving simplestreams cache”
t=2020-08-13T11:44:18-0500 lvl=info msg=“Saved simplestreams cache”
I cleaned out and reset lxd. Using the mount command above I was able to do lxd import ; I have a few of them. When I started a container, I noticed there was no IP address. Dawned on me that I forgot to do lxd init, so I did that, got the bridge working, connected containers to the bridge using “lxc config device add mail eth0 nic nictype=bridged parent=lxdbr0 name=eth0”. I thought a reboot would be in order to make sure everything is working correctly. The process for lxd is running, but not much else for lxd; no bridge either. Here is the error when I try to start stuff:
/etc/init.d/lxd start
[…] Starting lxd (via systemctl): lxd.serviceJob for lxd.service failed because the control process exited with error code.
See “systemctl status lxd.service” and “journalctl -xe” for details.
failed!
root@filesrv2:~# systemctl status lxd.service
● lxd.service - LXD - main daemon
Loaded: loaded (/lib/systemd/system/lxd.service; indirect; vendor preset: enabled)
Active: activating (start-post) since Thu 2020-08-13 23:46:50 CDT; 2min 23s ago
Docs: man:lxd(1)
Process: 6991 ExecStartPre=/usr/lib/x86_64-linux-gnu/lxc/lxc-apparmor-load (code=exited, status=0/SUCCESS)
Main PID: 7008 (lxd); Control PID: 7009 (lxd)
Tasks: 19
CGroup: /system.slice/lxd.service
├─7008 /usr/lib/lxd/lxd --group lxd --logfile=/var/log/lxd/lxd.log
└─7009 /usr/lib/lxd/lxd waitready --timeout=600
Aug 13 23:46:50 filesrv2 lxd[7008]: t=2020-08-13T23:46:50-0500 lvl=warn msg=“CGroup memory swap accounting is disabled, swap limits will be ignored.”
Aug 13 23:46:50 filesrv2 systemd[1]: lxd.service: Service hold-off time over, scheduling restart.
Aug 13 23:46:50 filesrv2 systemd[1]: lxd.service: Scheduled restart job, restart counter is at 2.
Aug 13 23:46:50 filesrv2 systemd[1]: Stopped LXD - main daemon.
Aug 13 23:46:50 filesrv2 systemd[1]: Starting LXD - main daemon…
Aug 13 23:48:17 filesrv2 lxd[7008]: t=2020-08-13T23:48:17-0500 lvl=warn msg="Failed connecting to global database (attempt 6): failed to create dqlite
Aug 13 23:48:30 filesrv2 lxd[7008]: t=2020-08-13T23:48:30-0500 lvl=warn msg="Failed connecting to global database (attempt 7): failed to create dqlite
Aug 13 23:48:43 filesrv2 lxd[7008]: t=2020-08-13T23:48:43-0500 lvl=warn msg="Failed connecting to global database (attempt 8): failed to create dqlite
Aug 13 23:48:56 filesrv2 lxd[7008]: t=2020-08-13T23:48:56-0500 lvl=warn msg="Failed connecting to global database (attempt 9): failed to create dqlite
Aug 13 23:49:08 filesrv2 lxd[7008]: t=2020-08-13T23:49:08-0500 lvl=warn msg="Failed connecting to global database (attempt 10): failed to create dqlit
I thought I’d try something. I removed the lxd and lxd-client. Then I installed lxd using snap. Newer version. I did the lxd init. The lxdbr0 bridge was up. Rebooted to make sure everything was fine. It took a while for the bridge to come up, but finally did.
Would it be better to continue with version 4 under snap or go back to version 3 under apt? In either case, I still need to get my existing containers running reliably.
Getting some errors. I was looking up the syntax of the mount after it failed, just in case and I came across the nsenter command to show the pid; it failed to eventhough the pid does actually exist and everything appears to be running, unless I’m missing something.
Hi Stephane,
I didn’t even know nsenter created a shell. But you were correct, I was unknowingly doing that. Thank You VERY much for your assistance. I am running again!!!
As soon as I can figure it out, I’ll mark this thread resolved.
