With the new kernel in RH 8.7 we cannot start our LXC containers anymore (on RH 6.x,7.x and 8.6 everything worked ok)
When I start a test container with : lxc-start -n lxcgcc -o debug -l debug
I can see in the debug that it goes wrong after trying to mount the rootfs
lxc-start lxcgcc 20230317154527.486 DEBUG conf - …/src/lxc/conf.c:lxc_mount_rootfs:1439 - Mounted rootfs “/usr/test/lxc/containers/lxcgcc/rootfs” onto “/usr/test/lxc/lib64/lxc/rootfs” with options “(null)”
lxc-start lxcgcc 20230317154527.486 ERROR conf - …/src/lxc/conf.c:lxc_setup_rootfs_prepare_root:3993 - Failed to setup rootfs for
lxc-start lxcgcc 20230317154527.486 ERROR conf - …/src/lxc/conf.c:lxc_setup:4368 - Failed to setup rootfs
lxc-start lxcgcc 20230317154527.486 ERROR start - …/src/lxc/start.c:do_start:1272 - Failed to setup container “lxcgcc”
/usr/test is a separated filesystem:
/dev/mapper/vgusrtest-lvusrtest on /usr/test type xfs (rw,noatime,seclabel,attr2,inode64,logbufs=8,logbsize=32k,sunit=512,swidth=4096,noquota)
RH8.7: Linux nlsaptstrh87 4.18.0-425.3.1.el8.x86_64 #1 SMP Fri Sep 30 11:45:06 EDT 2022 x86_64 x86_64 x86_64 GNU/Linux
The rootfs exists and also the lib64/lxc/rootfs,
if we change the kernel back to RH8.6, it starts the container correctly…
Same results with new stable builds of 4.012 and 5.02
Anybody any ideas ?
