We are running LXC/LXD v2.20 and have built a baseline VM we use as our container template master. Whenever we need a new LXD compute, we simply clone this VM, change IPs/hostnames, and reboot. All good.
However, it seems all the cloned copies of the master template have the same certificate fingerprint (as in: lxc remote add <cloned_vm1> <new_IP>).
How can I regenerate the certificate fingerprint on the cloned copies? I re-ran “lxd init” and said “yes” when prompted for “Would you like LXD to be available over the network”.
Does having the same fingerprint cause issues later on?
