I’m trying to migrate from LXD to Incus 6.0.0 bundled with Ubuntu 24.04. Accessing a remote fails
$ incus image ls images:
Error: Failed parsing stream: Get "https://images.linuxcontainers.org/streams/v1/index.json": remote error: tls: handshake failure
$ incus launch images:ubuntu/focal
Launching the instance
Error: Failed instance creation: Failed getting remote image info: Failed getting image: Failed parsing stream: Get "https://images.linuxcontainers.org/streams/v1/index.json": remote error: tls: handshake failure
Incus monitor does not provide any additional information, the relevant entry looks like
metadata:
class: task
created_at: "2024-10-11T16:05:57.068650024+03:00"
description: Creating instance
err: 'Failed getting remote image info: Failed getting image: Failed parsing stream:
tls: handshake failure'
may_cancel: false
metadata: null
resources:
containers:
- /1.0/instances/national-gnat
instances:
status: Failure
status_code: 400
updated_at: "2024-10-11T16:05:57.068650024+03:00"
project: default
timestamp: "2024-10-11T16:05:57.700527465+03:00"
type: operation
I am behind a corporate proxy, however LXD works here out of the box. I tried setting core.proxy_http/proxy_https with the same result.
