I removed CEPH from some servers in a LXD cluster, and I want to remove the corresponding storage pool in LXD (I’ll migrate to Incus after cleaning some things on these LXD hosts, like storage, and networks).
When I run lxc storage delete pool, I get :
Error: Failed checking the existence of the ceph "pool" osd pool while attempting to delete it because of an internal error: Failed to run: ceph --name client.admin --cluster ceph osd pool get pool size: exit status 1 (Error initializing cluster client: ObjectNotFound('RADOS object not found (error calling conf_read_file)'))
It is normal, because of ceph has been removed from the host.
But, how can I remove the storage pool from the LXD database ?
I tried systemctl reload snap.lxd.daemon, but nothing better.
