I can’t seem to grab the gpg key via curl or wget from my server , it just stays stuck. If I manually go to the website and copy it over I can’t do apt update to update the repo for LTS… This just started happening after a fresh install of Debian. Im following the basic instructions from GitHub but idk what else could be happening. Is the repo up ?
https://status.images.linuxcontainers.org/ doesn’t show any downtimes on the infrastructure.
Dont know if this is related but…
incus launch images:ubuntu RROAI --target RRAI
Launching RROAI
Error: Failed instance creation: Failed getting remote image info: Failed getting image: The requested image couldn’t be found
incus launch images:ubuntu RROAI --target RRAI --debug
DEBUG [2024-10-11T16:41:26-04:00] Connecting to a local Incus over a Unix socket
DEBUG [2024-10-11T16:41:26-04:00] Sending request to Incus etag= method=GET url=“http://unix.socket/1.0”
DEBUG [2024-10-11T16:41:26-04:00] Got response struct from Incus
“config”: {
“cluster.https_address”: “192.168.1.50:8443”,
“core.https_address”: “192.168.1.50:8443”
“api_extensions”: [
“storage_zfs_remove_snapshots”,
“container_host_shutdown_timeout”,
“container_stop_priority”,
“container_syscall_filtering”,
“auth_pki”,
“container_last_used_at”,
“etag”,
“patch”,
“usb_devices”,
“https_allowed_credentials”,
“image_compression_algorithm”,
“directory_manipulation”,
“container_cpu_time”,
“storage_zfs_use_refquota”,
“storage_lvm_mount_options”,
“network”,
“profile_usedby”,
“container_push”,
“container_exec_recording”,
“certificate_update”,
“container_exec_signal_handling”,
“gpu_devices”,
“container_image_properties”,
“migration_progress”,
“id_map”,
“network_firewall_filtering”,
“network_routes”,
“storage”,
“file_delete”,
“file_append”,
“network_dhcp_expiry”,
“storage_lvm_vg_rename”,
“storage_lvm_thinpool_rename”,
“network_vlan”,
“image_create_aliases”,
“container_stateless_copy”,
“container_only_migration”,
“storage_zfs_clone_copy”,
“unix_device_rename”,
“storage_lvm_use_thinpool”,
“storage_rsync_bwlimit”,
“network_vxlan_interface”,
“storage_btrfs_mount_options”,
“entity_description”,
“image_force_refresh”,
“storage_lvm_lv_resizing”,
“id_map_base”,
“file_symlinks”,
“container_push_target”,
“network_vlan_physical”,
“storage_images_delete”,
“container_edit_metadata”,
“container_snapshot_stateful_migration”,
“storage_driver_ceph”,
“storage_ceph_user_name”,
“resource_limits”,
“storage_volatile_initial_source”,
“storage_ceph_force_osd_reuse”,
“storage_block_filesystem_btrfs”,
“resources”,
“kernel_limits”,
“storage_api_volume_rename”,
“network_sriov”,
“console”,
“restrict_dev_incus”,
“migration_pre_copy”,
“infiniband”,
“dev_incus_events”,
“proxy”,
“network_dhcp_gateway”,
“file_get_symlink”,
“network_leases”,
“unix_device_hotplug”,
“storage_api_local_volume_handling”,
“operation_description”,
“clustering”,
“event_lifecycle”,
“storage_api_remote_volume_handling”,
“nvidia_runtime”,
“container_mount_propagation”,
“container_backup”,
“dev_incus_images”,
“container_local_cross_pool_handling”,
“proxy_unix”,
“proxy_udp”,
“clustering_join”,
“proxy_tcp_udp_multi_port_handling”,
“network_state”,
“proxy_unix_dac_properties”,
“container_protection_delete”,
“unix_priv_drop”,
“pprof_http”,
“proxy_haproxy_protocol”,
“network_hwaddr”,
“proxy_nat”,
“network_nat_order”,
“container_full”,
“backup_compression”,
“nvidia_runtime_config”,
“storage_api_volume_snapshots”,
“storage_unmapped”,
“projects”,
“network_vxlan_ttl”,
“container_incremental_copy”,
“usb_optional_vendorid”,
“snapshot_scheduling”,
“snapshot_schedule_aliases”,
“container_copy_project”,
“clustering_server_address”,
“clustering_image_replication”,
“container_protection_shift”,
“snapshot_expiry”,
“container_backup_override_pool”,
“snapshot_expiry_creation”,
“network_leases_location”,
“resources_cpu_socket”,
“resources_gpu”,
“resources_numa”,
“kernel_features”,
“id_map_current”,
“event_location”,
“storage_api_remote_volume_snapshots”,
“network_nat_address”,
“container_nic_routes”,
“cluster_internal_copy”,
“seccomp_notify”,
“lxc_features”,
“container_nic_ipvlan”,
“network_vlan_sriov”,
“storage_cephfs”,
“container_nic_ipfilter”,
“resources_v2”,
“container_exec_user_group_cwd”,
“container_syscall_intercept”,
“container_disk_shift”,
“storage_shifted”,
“resources_infiniband”,
“daemon_storage”,
“instances”,
“image_types”,
“resources_disk_sata”,
“clustering_roles”,
“images_expiry”,
“resources_network_firmware”,
“backup_compression_algorithm”,
“ceph_data_pool_name”,
“container_syscall_intercept_mount”,
“compression_squashfs”,
“container_raw_mount”,
“container_nic_routed”,
“container_syscall_intercept_mount_fuse”,
“container_disk_ceph”,
“virtual-machines”,
“image_profiles”,
“clustering_architecture”,
“resources_disk_id”,
“storage_lvm_stripes”,
“vm_boot_priority”,
“unix_hotplug_devices”,
“api_filtering”,
“instance_nic_network”,
“clustering_sizing”,
“firewall_driver”,
“projects_limits”,
“container_syscall_intercept_hugetlbfs”,
“limits_hugepages”,
“container_nic_routed_gateway”,
“projects_restrictions”,
“custom_volume_snapshot_expiry”,
“volume_snapshot_scheduling”,
“trust_ca_certificates”,
“snapshot_disk_usage”,
“clustering_edit_roles”,
“container_nic_routed_host_address”,
“container_nic_ipvlan_gateway”,
“resources_usb_pci”,
“resources_cpu_threads_numa”,
“resources_cpu_core_die”,
“api_os”,
“container_nic_routed_host_table”,
“container_nic_ipvlan_host_table”,
“container_nic_ipvlan_mode”,
“resources_system”,
“images_push_relay”,
“network_dns_search”,
“container_nic_routed_limits”,
“instance_nic_bridged_vlan”,
“network_state_bond_bridge”,
“usedby_consistency”,
“custom_block_volumes”,
“clustering_failure_domains”,
“resources_gpu_mdev”,
“console_vga_type”,
“projects_limits_disk”,
“network_type_macvlan”,
“network_type_sriov”,
“container_syscall_intercept_bpf_devices”,
“network_type_ovn”,
“projects_networks”,
“projects_networks_restricted_uplinks”,
“custom_volume_backup”,
“backup_override_name”,
“storage_rsync_compression”,
“network_type_physical”,
“network_ovn_external_subnets”,
“network_ovn_nat”,
“network_ovn_external_routes_remove”,
“tpm_device_type”,
“storage_zfs_clone_copy_rebase”,
“gpu_mdev”,
“resources_pci_iommu”,
“resources_network_usb”,
“resources_disk_address”,
“network_physical_ovn_ingress_mode”,
“network_ovn_dhcp”,
“network_physical_routes_anycast”,
“projects_limits_instances”,
“network_state_vlan”,
“instance_nic_bridged_port_isolation”,
“instance_bulk_state_change”,
“network_gvrp”,
“instance_pool_move”,
“gpu_sriov”,
“pci_device_type”,
“storage_volume_state”,
“network_acl”,
“migration_stateful”,
“disk_state_quota”,
“storage_ceph_features”,
“projects_compression”,
“projects_images_remote_cache_expiry”,
“certificate_project”,
“network_ovn_acl”,
“projects_images_auto_update”,
“projects_restricted_cluster_target”,
“images_default_architecture”,
“network_ovn_acl_defaults”,
“gpu_mig”,
“project_usage”,
“network_bridge_acl”,
“warnings”,
“projects_restricted_backups_and_snapshots”,
“clustering_join_token”,
“clustering_description”,
“server_trusted_proxy”,
“clustering_update_cert”,
“storage_api_project”,
“server_instance_driver_operational”,
“server_supported_storage_drivers”,
“event_lifecycle_requestor_address”,
“resources_gpu_usb”,
“clustering_evacuation”,
“network_ovn_nat_address”,
“network_bgp”,
“network_forward”,
“custom_volume_refresh”,
“network_counters_errors_dropped”,
“metrics”,
“image_source_project”,
“clustering_config”,
“network_peer”,
“linux_sysctl”,
“network_dns”,
“ovn_nic_acceleration”,
“certificate_self_renewal”,
“instance_project_move”,
“storage_volume_project_move”,
“cloud_init”,
“network_dns_nat”,
“database_leader”,
“instance_all_projects”,
“clustering_groups”,
“ceph_rbd_du”,
“instance_get_full”,
“qemu_metrics”,
“gpu_mig_uuid”,
“event_project”,
“clustering_evacuation_live”,
“instance_allow_inconsistent_copy”,
“network_state_ovn”,
“storage_volume_api_filtering”,
“image_restrictions”,
“storage_zfs_export”,
“network_dns_records”,
“storage_zfs_reserve_space”,
“network_acl_log”,
“storage_zfs_blocksize”,
“metrics_cpu_seconds”,
“instance_snapshot_never”,
“certificate_token”,
“instance_nic_routed_neighbor_probe”,
“event_hub”,
“agent_nic_config”,
“projects_restricted_intercept”,
“metrics_authentication”,
“images_target_project”,
“images_all_projects”,
“cluster_migration_inconsistent_copy”,
“cluster_ovn_chassis”,
“container_syscall_intercept_sched_setscheduler”,
“storage_lvm_thinpool_metadata_size”,
“storage_volume_state_total”,
“instance_file_head”,
“instances_nic_host_name”,
“image_copy_profile”,
“container_syscall_intercept_sysinfo”,
“clustering_evacuation_mode”,
“resources_pci_vpd”,
“qemu_raw_conf”,
“storage_cephfs_fscache”,
“network_load_balancer”,
“vsock_api”,
“instance_ready_state”,
“network_bgp_holdtime”,
“storage_volumes_all_projects”,
“metrics_memory_oom_total”,
“storage_buckets”,
“storage_buckets_create_credentials”,
“metrics_cpu_effective_total”,
“projects_networks_restricted_access”,
“storage_buckets_local”,
“loki”,
“acme”,
“internal_metrics”,
“cluster_join_token_expiry”,
“remote_token_expiry”,
“init_preseed”,
“storage_volumes_created_at”,
“cpu_hotplug”,
“projects_networks_zones”,
“network_txqueuelen”,
“cluster_member_state”,
“instances_placement_scriptlet”,
“storage_pool_source_wipe”,
“zfs_block_mode”,
“instance_generation_id”,
“disk_io_cache”,
“amd_sev”,
“storage_pool_loop_resize”,
“migration_vm_live”,
“ovn_nic_nesting”,
“oidc”,
“network_ovn_l3only”,
“ovn_nic_acceleration_vdpa”,
“cluster_healing”,
“instances_state_total”,
“auth_user”,
“security_csm”,
“instances_rebuild”,
“numa_cpu_placement”,
“custom_volume_iso”,
“network_allocations”,
“zfs_delegate”,
“storage_api_remote_volume_snapshot_copy”,
“operations_get_query_all_projects”,
“metadata_configuration”,
“syslog_socket”,
“event_lifecycle_name_and_project”,
“instances_nic_limits_priority”,
“disk_initial_volume_configuration”,
“operation_wait”,
“image_restriction_privileged”,
“cluster_internal_custom_volume_copy”,
“disk_io_bus”,
“storage_cephfs_create_missing”,
“instance_move_config”,
“ovn_ssl_config”,
“certificate_description”,
“disk_io_bus_virtio_blk”,
“loki_config_instance”,
“instance_create_start”,
“clustering_evacuation_stop_options”,
“boot_host_shutdown_action”,
“agent_config_drive”,
“network_state_ovn_lr”,
“image_template_permissions”,
“storage_bucket_backup”,
“storage_lvm_cluster”,
“shared_custom_block_volumes”,
“auth_tls_jwt”,
“oidc_claim”,
“device_usb_serial”,
“numa_cpu_balanced”,
“image_restriction_nesting”,
“network_integrations”,
“instance_memory_swap_bytes”,
“network_bridge_external_create”,
“network_zones_all_projects”,
“storage_zfs_vdev”,
“container_migration_stateful”,
“profiles_all_projects”,
“instances_scriptlet_get_instances”,
“instances_scriptlet_get_cluster_members”,
“instances_scriptlet_get_project”,
“network_acl_stateless”,
“instance_state_started_at”,
“networks_all_projects”,
“network_acls_all_projects”,
“storage_buckets_all_projects”,
“resources_load”,
“instance_access”,
“project_access”,
“projects_force_delete”,
“resources_cpu_flags”,
“disk_io_bus_cache_filesystem”,
“instance_oci”,
“clustering_groups_config”,
“instances_lxcfs_per_instance”,
“clustering_groups_vm_cpu_definition”,
“disk_volume_subpath”,
“projects_limits_disk_pool”,
“network_ovn_isolated”,
“qemu_raw_qmp”,
“network_load_balancer_health_check”,
“oidc_scopes”,
“network_integrations_peer_name”,
“qemu_scriptlet”,
“instance_auto_restart”,
“storage_lvm_metadatasize”,
“ovn_nic_promiscuous”,
“ovn_nic_ip_address_none”,
“instances_state_os_info”,
“network_load_balancer_state”,
“instance_nic_macvlan_mode”,
“storage_lvm_cluster_create”,
“network_ovn_external_interfaces”
“api_status”: “stable”,
“api_version”: “1.0”,
“auth”: “trusted”,
“public”: false,
“auth_methods”: [
“tls”
“auth_user_name”: “root”,
“auth_user_method”: “unix”,
“environment”: {
“addresses”: [
“192.168.1.50:8443”
“architectures”: [
“x86_64”,
“i686”
“certificate”: “-----BEGIN CERTIFICATE-----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\nNEonMiZpR6oR3x+N0VFDn7MVT16gbm05slBLHa+ksg==\n-----END CERTIFICATE-----\n”,
“certificate_fingerprint”: “a8292eed3cf7f600f2ef2b48e8d2565ec1e9f89b1bc6e5cdec39cbe469b4117c”,
“driver”: “lxc | qemu”,
“driver_version”: “6.0.2 | 9.0.2”,
“firewall”: “nftables”,
“kernel”: “Linux”,
“kernel_architecture”: “x86_64”,
“kernel_features”: {
“idmapped_mounts”: “true”,
“netnsid_getifaddrs”: “true”,
“seccomp_listener”: “true”,
“seccomp_listener_continue”: “true”,
“uevent_injection”: “true”,
“unpriv_binfmt”: “false”,
“unpriv_fscaps”: “true”
“kernel_version”: “6.5.0-44-generic”,
“lxc_features”: {
“cgroup2”: “true”,
“core_scheduling”: “true”,
“devpts_fd”: “true”,
“idmapped_mounts_v2”: “true”,
“mount_injection_file”: “true”,
“network_gateway_device_route”: “true”,
“network_ipvlan”: “true”,
“network_l2proxy”: “true”,
“network_phys_macvlan_mtu”: “true”,
“network_veth_router”: “true”,
“pidfd”: “true”,
“seccomp_allow_deny_syntax”: “true”,
“seccomp_notify”: “true”,
“seccomp_proxy_send_notify_fd”: “true”
“os_name”: “Ubuntu”,
“os_version”: “22.04”,
“project”: “default”,
“server”: “incus”,
“server_clustered”: true,
“server_event_mode”: “full-mesh”,
“server_name”: “RRAI”,
“server_pid”: 1110077,
“server_version”: “6.6”,
“storage”: “dir | zfs”,
“storage_version”: “1 | 2.1.5-1ubuntu6~22.04.4”,
“storage_supported_drivers”: [
“Name”: “dir”,
“Version”: “1”,
“Remote”: false
“Name”: “zfs”,
“Version”: “2.1.5-1ubuntu6~22.04.4”,
“Remote”: false
Launching RROAI
DEBUG [2024-10-11T16:41:26-04:00] Connecting to a remote simplestreams server URL=“https://images.linuxcontainers.org”
DEBUG [2024-10-11T16:41:26-04:00] Connected to the websocket: ws://unix.socket/1.0/events?target=RRAI
DEBUG [2024-10-11T16:41:26-04:00] Sending request to Incus etag= method=POST url=“http://unix.socket/1.0/instances?target=RRAI”
“architecture”: “”,
“config”: {},
“devices”: {},
“ephemeral”: false,
“profiles”: null,
“stateful”: false,
“description”: “”,
“name”: “RROAI”,
“source”: {
“type”: “image”,
“certificate”: “”,
“alias”: “ubuntu”,
“server”: “https://images.linuxcontainers.org”,
“protocol”: “simplestreams”,
“mode”: “pull”,
“allow_inconsistent”: false
“instance_type”: “”,
“type”: “container”,
“start”: true
DEBUG [2024-10-11T16:41:26-04:00] Got operation from Incus
The important part of the message, the last part, says that the requested image could not be found.
But if you run the following, you get many results. But you get results because in this case, the ubuntu
part is used as a filter among available images.
$ incus image list images:ubuntu
So, when is a string a filter and when is it an exact match? In the following, this ain’t an exact match. images:ubuntu
is not a specific image.
$ incus image info images:ubuntu
Error: Failed getting image: The requested image couldn't be found
But this is an exact match.
$ incus image info images:ubuntu/24.04
Fingerprint: 36162a137ac5cc9d4179443b197861a58c3f6ce7b6626f41f28db6e06a6a38b4
When you specify an image in Incus, it is important to be specific in order to avoid surprises. If you were to type images:ubuntu
and expect that the system would assume that you want to select the current LTS version of Ubuntu, whichever version that is, would add uncertainty.
