$ snap list lxd
lxd 5.13-cea5ee2 24758 latest/stable canonical✓ -
I guess I haven’t created a new instance terribly recently, but have used it heavily in the past and haven’t changed any of its configuration. I just tried to create one today and it doesn’t work:
We migrated to core22 for the latest track.
As part of that we had to drop some versions of ZFS which are no longer buildable on current distros, this includes the version of ZFS coming with stock Ubuntu 18.04 (0.7).
Other than upgrading to Ubuntu 20.04 or later, you can also fix this issue by switching over to the HWE kernel which will get you a supported ZFS version (0.8).
We must have made that change a couple of months ago now, I believe for the latest track, the switch happened at the same time we rolled out LXD 5.12 in mid-March.
As far as alternative tracks, yes, there are some options but as LXD doesn’t support downgrading, they’re unlikely to be really viable options.
Alright, thank you. I’ll survive without it for now. I know I need to upgrade, but I’d like to do it on my time instead of having my tools automatically break, you know?
