System: Ubuntu 22.04.2 LTS
LXD version: 5.12 from snap
fresh installation of Ubuntu 22.04.2
steps:
>> sudo snap install lxd
lxd 5.12-c63881f from Canonical✓ installed
>> sudo lxd init --auto
Error: Failed to create local member network "lxdbr0" in project "default":
The DNS and DHCP service exited prematurely:
Process exited with non-zero value 2
("dnsmasq: failed to create listening socket for fc33:85e4:42be:a32f::1: Address already in use")
I think issue is that port 53 is occupied by named (dns) on the fresh Ubuntu install.
If it disable
the named
service than the commands works but it causes DNS problems later
What’s best way to handle the issue?
