- Distribution: Ubuntu
- Distribution version: 18.04 and 19.04
- lxc info:
driver: lxc
driver_version: 3.1.0
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: “false”
seccomp_listener: “true”
shiftfs: “false”
uevent_injection: “true”
unpriv_fscaps: “true”
kernel_version: 5.0.0-15-generic
lxc_features:
mount_injection_file: “true”
network_gateway_device_route: “false”
network_ipvlan: “false”
network_l2proxy: “false”
seccomp_notify: “false”
project: default
server: lxd
server_clustered: true
server_name: lxd-cloud-01
server_pid: 5302
server_version: “3.13”
storage: zfs
storage_version: 0.7.12-1ubuntu5
Issue description
reverse dns on fan bridge network return host with .__internal domain instead of .lxd domain (nslookup 240.1.33.116 returns compute._internal instead of compute.lxd).
Forward dns works fine though for both compute.__internal and compute.lxd as well as just compute.
looks very slightly related to https://github.com/lxc/lxd/issues/4788 but different in that dns lookups across nodes/forward lookups are fine, just reverse lookups are returning the wrong domain.
Steps to reproduce
- two node lxd cluster
- create fan network with the attached configuration
- create an alpine container attached to this network
- run nslookup on this containers ip address will return the container_name.__internal instead of container_name.lxd.
Information to attach
- network config :
bridge.mode: fan
dns.domain: lxd
fan.underlay_subnet: 172.18.0.0/16
description: “”
type: bridge
managed: true
status: Created - output of
ps aux | grep fanbr0:
dnsmasq --strict-order --bind-interfaces --pid-file=/var/snap/lxd/common/lxd/networks/fanbr0/dnsmasq.pid --except-interface=lo --interface=fanbr0 --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=240.1.33.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/fanbr0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/fanbr0/dnsmasq.hosts --dhcp-range 240.1.33.2,240.1.33.254 -s __internal -S /__internal/ -S /lxd/240.1.33.1#1053 --dhcp-option=15,lxd --conf-file=/var/snap/lxd/common/lxd/networks/fanbr0/dnsmasq.raw -u lxd - output of
ps aux | grep forkdns
/snap/lxd/current/bin/lxd forkdns 240.1.33.1:1053 lxd 240.1.33.1 240.0.116.1
Anybody run into this before?
