I don’t appear to be able to install LXD via snap in my LXD instances…
[root@avmanager-shards ~]# snap install lxd
error: system does not fully support snapd: cannot mount squashfs image using “squashfs”:
mount: /tmp/sanity-mountpoint-688416304: mount failed: Operation not permitted.
Does anyone know where I can find a lxd-client package for the RHEL derivative distros?
If you just need the client, we have static builds of it available at Actions · lxc/lxd · GitHub (requires Github login).
As for the snap, the issue likely is that you’re on too old a snapd version that it’s missing its built-in copy of squashfuse. You could check for a native package of squashfuse that you could install in your container which should sort that out.
You could also try doing snap install snapd to get a newer version of snapd, but I suspect this may hit the same error.
