I’m having an issue while trying to create an unprivileged container with lxd. The rootfs of the created container is still owned by root and not by the uid/gid that i expected.
Version :
lxc --version
4.19
Configuration :
bat /etc/sub*
│ File: /etc/subgid
1 │ sysadmin:100000:6553
2 │ root:1000000:65536
│ File: /etc/subuid
1 │ sysadmin:100000:65536
bat /etc/lxc/*
│ File: /etc/lxc/default.conf <EMPTY>
│ File: /etc/lxc/lxc.conf <EMPTY>
│ File: /etc/lxc/lxc-usernet <EMPTY>
When i try to create a container it works fine :
lxc launch images:alpine/edge toto
Creating toto
Starting toto
The idmap of the container seems coherent with the subuid / subgid declared :
lxc config show toto |grep idmap
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":65536}]'
However when i look at the rootfs it is not the owner / group i was expecting :
sudo stat /var/lib/lxd/storage-pools/default/containers/toto
File: /var/lib/lxd/storage-pools/default/containers/toto
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: fd01h/64769d Inode: 917510 Links: 4
Access: (0100/d--x------) Uid: (1000000/ UNKNOWN) Gid: ( 0/ root)
Access: 2021-10-09 17:33:47.503552141 +0200
Modify: 2021-10-09 17:33:47.639558388 +0200
Change: 2021-10-09 17:33:47.681560317 +0200
Birth: 2021-10-09 17:33:47.503552141 +0200
sudo stat /var/lib/lxd/storage-pools/default/containers/toto/rootfs
File: /var/lib/lxd/storage-pools/default/containers/toto/rootfs
Device: fd01h/64769d Inode: 917526 Links: 19
Access: (0755/drwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2021-10-08 15:01:42.000000000 +0200
Modify: 2021-10-08 15:01:42.000000000 +0200
Change: 2021-10-09 17:33:47.628557882 +0200
Birth: 2021-10-09 17:33:47.509552416 +0200
What is particularly strange is that the path /var/lib/lxd/storage-pools/default/containers/toto is owned by the “correct” uid but not the correct group, and the rootfs itself is owned by root.
Is it a misconfiguration on my part ? Or something that i misunderstood about the expected behaviour ?
Thank you in advance for your responses.
