Rootfull docker inside unprivileged LXD container
Is it possible to run docker inside unprivileged LXD container?
The motivations comes from the fact the projects like Nextcloud are providing docker images. These images can be easily kept upto date automatically using tools like watchtower. The upstream provided images are possibly more reliable than the distro provided builds. My LXD containers need manual intervention to update unlike docker/watchtower.
Thanks
Take a look at Running Docker inside of a LXD container - YouTube it may help you
Hi!
You can use Docker in a unprivileged container
But, you have to use Nested containers
Example
lxc launch ubuntu:22.04 nextcloud -c security.nesting=true
Or to change an existing container:
lxc config set nextcloud security.nesting true
Regards.
https://ubuntu.com/blog/nested-containers-in-lxd
PS: You can also use Docker in a privileged container :slight_smile:
You dont need to use a privileged container, see
https://www.youtube.com/watch?v=_fCSSEyiGro
