I have an instance with two NIC’s configured:
network: ovntest
eth1:
ipv4.address: <home lan ip>
nictype: routed
parent: enp10s0
After starting the instance the routing table looks like this:
default via 169.254.0.1 dev eth1
default via 10.43.146.1 dev eth0 proto dhcp src 10.43.146.2 metric 1024
10.43.146.0/24 dev eth0 proto kernel scope link src 10.43.146.2 metric 1024
10.43.146.1 dev eth0 proto dhcp scope link src 10.43.146.2 metric 1024
10.102.89.1 via 10.43.146.1 dev eth0 proto dhcp src 10.43.146.2 metric 1024
169.254.0.1 dev eth1 scope link
Which means all “unknown” traffic will be routed through eth1. In general this is fine but if you have OVN peering configured you can’t reach the peered OVN because of the lower metric (higher priority) of eth1.
Changing the order of the NIC’s doesn’t change the behaviour nor trying to influence network settings by editing “/etc/systemd/network/eth1.network” as the NIC is created during instance start. Reviewing the network options allows to set “ipv4.gateway to none” which results into the following table:
No route at all added as it is disabled. However, adding it back manual by editing “/etc/systemd/network/eth1.network” didn’t have the desired result either.
My question is how can I influence the instance routing table to give eth0 the lower metric to reach other peered OVN networks?
