Hi, experiencing this odd behavior and i cannot wrap my Head around it.
With disabled ufw https is fast. With enabled ufw it lags by a lot while http remains fast.
Experimenting with the routed profile with just one additional IP on a hetzner bare bone Server.
my lxd host configs:
root@test ~ # uname -a
Linux test 5.4.0-139-generic #156-Ubuntu SMP Fri Jan 20 17:27:18 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
root@test ~ # cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.5 LTS"
root@test ~ # lxd --version
5.10
root@test ~ # cat /etc/network/interfaces
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto enp2s0
iface enp2s0 inet static
address 213.239.210.243
netmask 255.255.255.224
gateway 213.239.210.225
pointtopoint 213.239.210.225
dns-nameserver 185.12.64.1 185.12.64.2 8.8.8.8 8.8.4.4
root@test ~ # ip a
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 44:8a:5b:5d:d5:32 brd ff:ff:ff:ff:ff:ff
inet 213.239.210.243/27 brd 213.239.210.255 scope global enp2s0
3: lxdbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:16:3e:00:c8:17 brd ff:ff:ff:ff:ff:ff
inet 10.126.175.1/24 scope global lxdbr0
5: mail@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 5a:25:f6:c6:9e:62 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 169.254.0.1/32 scope global mail
root@test ~ # ip r
default via 213.239.210.225 dev enp2s0 onlink
10.126.175.0/24 dev lxdbr0 proto kernel scope link src 10.126.175.1 linkdown
213.239.210.224/27 dev enp2s0 proto kernel scope link src 213.239.210.243
213.239.211.94 dev mail scope link
root@test ~ # lxc network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| enp2s0 | physical | NO | | | | 2 | |
| lxdbr0 | bridge | YES | 10.126.175.1/24 | none | | 1 | CREATED |
root@test ~ # cat /etc/sysctl.conf
net.ipv4.conf.enp2s0.forwarding=1
root@test ~ # lxc profile show routed
user.network-config: |
version: 2
ethernets:
addresses:
- 213.239.211.94/32
nameservers:
addresses:
- 185.12.64.1
- 185.12.64.2
- 8.8.8.8
search: []
routes:
- to: 0.0.0.0/0
via: 169.254.0.1
on-link: true
description: Routed LXD profile
host_name: mail
ipv4.address: 213.239.211.94
nictype: routed
parent: enp2s0
- /1.0/instances/mail
root@test ~ # lxc list
| mail | RUNNING | 213.239.211.94 (eth0) | | CONTAINER | 0 |
root@test ~ # lxc info | grep firewall:
firewall: xtables
root@test ~ # grep -Ev ^'(#|$)' /etc/default/ufw
IPV6=no
DEFAULT_INPUT_POLICY="DROP"
DEFAULT_OUTPUT_POLICY="ACCEPT"
DEFAULT_FORWARD_POLICY="DROP"
DEFAULT_APPLICATION_POLICY="SKIP"
MANAGE_BUILTINS=no
IPT_SYSCTL=/etc/ufw/sysctl.conf
IPT_MODULES=""
root@test ~ # ufw status numbered
Status: active
To Action From
[ 1] 22/tcp ALLOW IN Anywhere
[ 2] 213.239.211.94 80 on mail ALLOW FWD Anywhere on enp2s0
[ 3] 213.239.211.94 8080 on mail ALLOW FWD Anywhere on enp2s0
[ 4] 213.239.211.94 443 on mail ALLOW FWD Anywhere on enp2s0
Inside container,
root@test ~ # lxc shell mail
root@mail:~# ip r
default via 169.254.0.1 dev eth0
default via 169.254.0.1 dev eth0 proto static onlink
169.254.0.1 dev eth0 scope link
root@mail:~# ip a
4: eth0@if5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:c8:ce:45 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 213.239.211.94/32 scope global eth0
Now when the firewall is enabled the https connection to port 8080 takes much longer then without ufw while the http connection to port 80 is instant, which is voodoo witchcraft to me.
What am i missing?
