Routing a network through specific interface ip alias
I have two public IPV4 defined on a single network interface. I created a default Incus network bridge called ad0. I need all egress traffic from the containers added to that network to come specifically from one of the public IP.
What is the recommended way of doing so ?
I don’t think it’s possible with incus managed network:
I think you should create an unmanaged bridge using a vlan pointing to one of the public IP, then attach containers to it.
No hanks. I want to keep my Incus managed bridge.
I found how to do it :
incus network set gkbr0 ipv4.nat.address=[redacted IPV4]
incus network set gkbr0 ipv6.nat.address=[redacted IPV6]
It was in the documentation …
ipv4.nat.address: The source address used for outbound traffic from the bridge
