I am trying to set up criu.enable=true
or criu_enable=true
but both are giving
sudo snap set lxd criu.enable=true
sudo snap set lxd criu_enable=true
And here is what I get
error: cannot perform the following tasks: - Run configure hook of "lxd" snap (invalid option name: "criu_enable")
My LXD version on Ubuntu 20.04 LTS
lxd --version
4.18
Config file shows follow:
sudo cat /var/snap/lxd/common/config
# This file is auto-generated, do NOT manually edit ceph_builtin=false ceph_external=false criu_enable=false daemon_debug=false daemon_group=lxd daemon_syslog=false lvm_external=false lxcfs_loadavg=false lxcfs_pidfd=false lxcfs_cfs=false openvswitch_builtin=false shiftfs_enable=auto
Look like criu_enable=false
set to false. Any idea how can I fix this? I need this for snapshot with the --stateful
options:
lxc snapshot mysql8 snap1 --stateful
Error: Unable to create a stateful snapshot. CRIU isn't installed
Hence, I am trying the sudo snap set lxd criu_enable=true
. From the /snap/lxd/current/commands/daemon.start
400
401 # Setup CRIU
402 if [ "${criu_enable:-"false"}" = "true" ]; then
403 echo "==> Enabling CRIU"
404 export PATH="${SNAP_CURRENT}/criu:${PATH}"
405 fi
What am I missing?
