Run k3s on incus container
I am trying to install k3s in an Incus container. Creating an Incus container without security.nesting and security.priviliged set to true or not does not solve the problem.
The command I used for installing K3s is:
curl -sfL https://get.k3s.io | K3S_KUBECONFIG_MODE=“644” sh -s -
“sudo journalctl -xeu k3s.service” command produces following errors:
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949018    4325 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949303    4325 dynamic_serving_content.go:132] "Starting controller" name="serving-cert::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949421    4325 secure_serving.go:213] Serving securely on 127.0.0.1:6444
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949468    4325 tlsconfig.go:240] "Starting DynamicServingCertificateController"
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949528    4325 system_namespaces_controller.go:67] Starting system namespaces controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949621    4325 controller.go:116] Starting legacy_token_tracking_controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949632    4325 shared_informer.go:313] Waiting for caches to sync for configmaps
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949663    4325 gc_controller.go:78] Starting apiserver lease garbage collector
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949942    4325 cluster_authentication_trust_controller.go:440] Starting cluster_authentication_trust_controller controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.949951    4325 shared_informer.go:313] Waiting for caches to sync for cluster_authentication_trust_controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950016    4325 apiservice_controller.go:97] Starting APIServiceRegistrationController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950021    4325 dynamic_serving_content.go:132] "Starting controller" name="aggregator-proxy-cert::/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt::/var/lib/rancher/k3s/server/tls/client-auth-proxy.key"
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950025    4325 cache.go:32] Waiting for caches to sync for APIServiceRegistrationController controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950211    4325 aggregator.go:163] waiting for initial CRD sync...
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950229    4325 controller.go:78] Starting OpenAPI AggregationController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950262    4325 apf_controller.go:374] Starting API Priority and Fairness config controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950102    4325 controller.go:80] Starting OpenAPI V3 AggregationController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950110    4325 customresource_discovery_controller.go:289] Starting DiscoveryController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950124    4325 available_controller.go:423] Starting AvailableConditionController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950330    4325 cache.go:32] Waiting for caches to sync for AvailableConditionController controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950582    4325 crdregistration_controller.go:111] Starting crd-autoregister controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950593    4325 shared_informer.go:313] Waiting for caches to sync for crd-autoregister
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950687    4325 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950751    4325 controller.go:139] Starting OpenAPI controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950783    4325 controller.go:87] Starting OpenAPI V3 controller
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950801    4325 naming_controller.go:291] Starting NamingConditionController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950816    4325 establishing_controller.go:76] Starting EstablishingController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950837    4325 nonstructuralschema_controller.go:192] Starting NonStructuralSchemaConditionController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950855    4325 apiapproval_controller.go:186] Starting KubernetesAPIApprovalPolicyConformantConditionController
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950870    4325 crd_finalizer.go:266] Starting CRDFinalizer
Sep 27 16:08:56 debk3s k3s[4325]: I0927 16:08:56.950750    4325 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050288    4325 cache.go:39] Caches are synced for APIServiceRegistrationController controller
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050328    4325 shared_informer.go:320] Caches are synced for cluster_authentication_trust_controller
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050366    4325 handler.go:286] Adding GroupVersion helm.cattle.io v1 to ResourceManager
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050386    4325 handler.go:286] Adding GroupVersion k3s.cattle.io v1 to ResourceManager
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050452    4325 cache.go:39] Caches are synced for AvailableConditionController controller
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050657    4325 shared_informer.go:320] Caches are synced for crd-autoregister
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050694    4325 aggregator.go:165] initial CRD sync complete...
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050701    4325 autoregister_controller.go:141] Starting autoregister controller
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050707    4325 cache.go:32] Waiting for caches to sync for autoregister controller
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050713    4325 cache.go:39] Caches are synced for autoregister controller
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050296    4325 apf_controller.go:379] Running API Priority and Fairness config worker
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.059179    4325 apf_controller.go:382] Running API Priority and Fairness periodic rebalancing process
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.059280    4325 handler_discovery.go:447] Starting ResourceDiscoveryManager
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.050304    4325 shared_informer.go:320] Caches are synced for configmaps
Sep 27 16:08:57 debk3s k3s[4325]: E0927 16:08:57.066680    4325 controller.go:102] Error removing old endpoints from kubernetes service: no API server IP addresses were listed in storage, refusing to erase all endpoints for the kubernetes Service
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.073876    4325 shared_informer.go:320] Caches are synced for node_authorizer
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.077181    4325 shared_informer.go:320] Caches are synced for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.077210    4325 policy_source.go:224] refreshing policies
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.126024    4325 controller.go:615] quota admission added evaluator for: leases.coordination.k8s.io
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Password verified locally for node debk3s"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="certificate CN=debk3s signed by CN=k3s-server-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:08:57 +0000 UTC"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="certificate CN=system:node:debk3s,O=system:nodes signed by CN=k3s-client-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:08:57 +0000 UTC"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=warning msg="Host resolv.conf includes loopback or multicast nameservers - kubelet will use autogenerated resolv.conf with nameserver 8.8.8.8"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Module overlay was already loaded"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Module nf_conntrack was already loaded"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=warning msg="Failed to load kernel module br_netfilter with modprobe"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=warning msg="Failed to load kernel module iptable_nat with modprobe"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=warning msg="Failed to load kernel module iptable_filter with modprobe"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Set sysctl 'net/bridge/bridge-nf-call-iptables' to 1"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=error msg="Failed to set sysctl: open /proc/sys/net/bridge/bridge-nf-call-iptables: no such file or directory"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Set sysctl 'net/netfilter/nf_conntrack_max' to 131072"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=error msg="Failed to set sysctl: open /proc/sys/net/netfilter/nf_conntrack_max: permission denied"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Logging containerd to /var/lib/rancher/k3s/agent/containerd/containerd.log"
Sep 27 16:08:57 debk3s k3s[4325]: time="2024-09-27T16:08:57Z" level=info msg="Running containerd -c /var/lib/rancher/k3s/agent/etc/containerd/config.toml -a /run/k3s/containerd/containerd.sock --state /run/k3s/containerd --root /var/lib/rancher/k3s/agent/containerd"
Sep 27 16:08:57 debk3s k3s[4325]: I0927 16:08:57.964120    4325 storage_scheduling.go:111] all system priority classes are created successfully or already exist.
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Waiting for cloud-controller-manager privileges to become available"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Creating k3s-supervisor event broadcaster"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Kube API server is now running"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="ETCD server is now running"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="k3s is up and running"
Sep 27 16:08:58 debk3s systemd[1]: Started k3s.service - Lightweight Kubernetes.
░░ Subject: A start job for unit k3s.service has finished successfully
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit k3s.service has finished successfully.
░░ The job identifier is 1157.
Sep 27 16:08:58 debk3s k3s[4325]: W0927 16:08:58.394491    4325 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Applying CRD addons.k3s.cattle.io"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Applying CRD etcdsnapshotfiles.k3s.cattle.io"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Applying CRD helmcharts.helm.cattle.io"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Applying CRD helmchartconfigs.helm.cattle.io"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-25.0.3+up25.0.0.tgz"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-crd-25.0.3+up25.0.0.tgz"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/local-storage.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-delegator.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-apiservice.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-deployment.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-service.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/ccm.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/aggregated-metrics-reader.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-reader.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/resource-reader.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/rolebindings.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/runtimes.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/traefik.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/coredns.yaml"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Starting dynamiclistener CN filter node controller"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Tunnel server egress proxy mode: agent"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Starting k3s.cattle.io/v1, Kind=Addon controller"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Creating deploy event broadcaster"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.596716    4325 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.643490    4325 controller.go:615] quota admission added evaluator for: rolebindings.rbac.authorization.k8s.io
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.648179    4325 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="AppliedManifest" message="Applied manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.651591    4325 controller.go:615] quota admission added evaluator for: addons.k3s.cattle.io
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.661319    4325 event.go:389] "Event occurred" object="kube-system/coredns" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/coredns.yaml\""
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Creating helm-controller event broadcaster"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Starting /v1, Kind=Node controller"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.705388    4325 controller.go:615] quota admission added evaluator for: deployments.apps
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Waiting for control-plane node debk3s startup: nodes \"debk3s\" not found"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="containerd is now running"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Cluster dns configmap already exists"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Creating k3s-cert-monitor event broadcaster"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Connecting to proxy" url="wss://127.0.0.1:6443/v1-k3s/connect"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Running kubelet --address=0.0.0.0 --allowed-unsafe-sysctls=net.ipv4.ip_forward,net.ipv6.conf.all.forwarding --anonymous-auth=false --authentication-token-webhook=true --authorization-mode=Webhook --cgroup-driver=systemd --client-ca-file=/var/lib/rancher/k3s/agent/client-ca.crt --cloud-provider=external --cluster-dns=10.43.0.10 --cluster-domain=cluster.local --container-runtime-endpoint=unix:///run/k3s/containerd/containerd.sock --containerd=/run/k3s/containerd/containerd.sock --eviction-hard=imagefs.available<5%,nodefs.available<5% --eviction-minimum-reclaim=imagefs.available=10%,nodefs.available=10% --fail-swap-on=false --feature-gates=CloudDualStackNodeIPs=true --healthz-bind-address=127.0.0.1 --hostname-override=debk3s --kubeconfig=/var/lib/rancher/k3s/agent/kubelet.kubeconfig --node-ip=10.174.47.117,fd42:f085:b67c:18d1:216:3eff:fee7:36c3 --node-labels= --pod-manifest-path=/var/lib/rancher/k3s/agent/pod-manifests --read-only-port=0 --resolv-conf=/var/lib/rancher/k3s/agent/etc/resolv.conf --serialize-image-pulls=false --tls-cert-file=/var/lib/rancher/k3s/agent/serving-kubelet.crt --tls-private-key-file=/var/lib/rancher/k3s/agent/serving-kubelet.key"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Handling backend connection request [debk3s]"
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=info msg="Remotedialer connected to proxy" url="wss://127.0.0.1:6443/v1-k3s/connect"
Sep 27 16:08:58 debk3s k3s[4325]: Flag --containerd has been deprecated, This is a cadvisor flag that was mistakenly registered with the Kubelet. Due to legacy concerns, it will follow the standard CLI deprecation timeline before being removed.
Sep 27 16:08:58 debk3s k3s[4325]: W0927 16:08:58.745195    4325 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:08:58 debk3s k3s[4325]: W0927 16:08:58.745669    4325 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.747850    4325 server.go:479] "Kubelet version" kubeletVersion="v1.30.5+k3s1"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.747878    4325 server.go:481] "Golang settings" GOGC="" GOMAXPROCS="" GOTRACEBACK=""
Sep 27 16:08:58 debk3s k3s[4325]: W0927 16:08:58.747925    4325 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:08:58 debk3s k3s[4325]: W0927 16:08:58.748003    4325 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.752126    4325 serving.go:387] Generated self-signed cert in-memory
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.755888    4325 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/agent/client-ca.crt"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.760367    4325 event.go:389] "Event occurred" object="kube-system/coredns" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="AppliedManifest" message="Applied manifest at \"/var/lib/rancher/k3s/server/manifests/coredns.yaml\""
Sep 27 16:08:58 debk3s k3s[4325]: W0927 16:08:58.774967    4325 fs.go:216] stat failed on /dev/sdb2 with error: no such file or directory
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.786175    4325 event.go:389] "Event occurred" object="kube-system/local-storage" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/local-storage.yaml\""
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.796168    4325 server.go:737] "--cgroups-per-qos enabled, but --cgroup-root was not specified.  defaulting to /"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.796203    4325 server.go:805] "NoSwap is set due to memorySwapBehavior not specified" memorySwapBehavior="" FailSwapOn=false
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.796744    4325 container_manager_linux.go:265] "Container manager verified user specified cgroup-root exists" cgroupRoot=[]
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.796833    4325 container_manager_linux.go:270] "Creating Container Manager object based on Node Config" nodeConfig={"NodeName":"debk3s","RuntimeCgroupsName":"","SystemCgroupsName":"","KubeletCgroupsName":"","KubeletOOMScoreAdj":-999,"ContainerRuntime":"","CgroupsPerQOS":true,"CgroupRoot":"/","CgroupDriver":"systemd","KubeletRootDir":"/var/lib/kubelet","ProtectKernelDefaults":false,"KubeReservedCgroupName":"","SystemReservedCgroupName":"","ReservedSystemCPUs":{},"EnforceNodeAllocatable":{"pods":{}},"KubeReserved":null,"SystemReserved":null,"HardEvictionThresholds":[{"Signal":"imagefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null},{"Signal":"nodefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null}],"QOSReserved":{},"CPUManagerPolicy":"none","CPUManagerPolicyOptions":null,"TopologyManagerScope":"container","CPUManagerReconcilePeriod":10000000000,"ExperimentalMemoryManagerPolicy":"None","ExperimentalMemoryManagerReservedMemory":null,"PodPidsLimit":-1,"EnforceCPULimits":true,"CPUCFSQuotaPeriod":100000000,"TopologyManagerPolicy":"none","TopologyManagerPolicyOptions":null}
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797209    4325 topology_manager.go:138] "Creating topology manager with none policy"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797314    4325 container_manager_linux.go:301] "Creating device plugin manager"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797363    4325 state_mem.go:36] "Initialized new in-memory state store"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797463    4325 kubelet.go:401] "Attempting to sync node with API server"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797479    4325 kubelet.go:302] "Adding static pod path" path="/var/lib/rancher/k3s/agent/pod-manifests"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797505    4325 kubelet.go:313] "Adding apiserver pod source"
Sep 27 16:08:58 debk3s k3s[4325]: I0927 16:08:58.797517    4325 apiserver.go:42] "Waiting for node sync before watching apiserver pods"
Sep 27 16:08:58 debk3s k3s[4325]: Error: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory
Sep 27 16:08:58 debk3s k3s[4325]: time="2024-09-27T16:08:58Z" level=error msg="kubelet exited: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory"
Sep 27 16:08:58 debk3s systemd[1]: k3s.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit k3s.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Sep 27 16:08:58 debk3s systemd[1]: k3s.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit k3s.service has entered the 'failed' state with result 'exit-code'.
Sep 27 16:08:58 debk3s systemd[1]: k3s.service: Consumed 4.817s CPU time.
░░ Subject: Resources consumed by unit runtime
░░ The unit k3s.service completed and consumed the indicated resources.
Sep 27 16:09:04 debk3s systemd[1]: k3s.service: Scheduled restart job, restart counter is at 15.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit k3s.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Sep 27 16:09:04 debk3s systemd[1]: Stopped k3s.service - Lightweight Kubernetes.
░░ Subject: A stop job for unit k3s.service has finished
░░ A stop job for unit k3s.service has finished.
░░ The job identifier is 1214 and the job result is done.
Sep 27 16:09:04 debk3s systemd[1]: k3s.service: Consumed 4.817s CPU time.
Sep 27 16:09:04 debk3s systemd[1]: Starting k3s.service - Lightweight Kubernetes...
░░ Subject: A start job for unit k3s.service has begun execution
░░ A start job for unit k3s.service has begun execution.
░░ The job identifier is 1214.
Sep 27 16:09:04 debk3s sh[4356]: + /usr/bin/systemctl is-enabled --quiet nm-cloud-setup.service
Sep 27 16:09:04 debk3s (modprobe)[4358]: k3s.service: Executable /sbin/modprobe missing, skipping: No such file or directory
░░ Subject: Process /sbin/modprobe could not be executed
░░ The process /sbin/modprobe could not be executed and failed.
░░ The error number returned by this process is 2.
Sep 27 16:09:04 debk3s (modprobe)[4359]: k3s.service: Executable /sbin/modprobe missing, skipping: No such file or directory
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Starting k3s v1.30.5+k3s1 (9b586704)"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Configuring sqlite3 database connection pooling: maxIdleConns=2, maxOpenConns=0, connMaxLifetime=0s"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Configuring database table schema and indexes, this may take a moment..."
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Database tables and indexes are up to date"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Kine available at unix://kine.sock"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Reconciling bootstrap data between datastore and disk"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Running kube-apiserver --advertise-port=6443 --allow-privileged=true --anonymous-auth=false --api-audiences=https://kubernetes.default.svc.cluster.local,k3s --authorization-mode=Node,RBAC --bind-address=127.0.0.1 --cert-dir=/var/lib/rancher/k3s/server/tls/temporary-certs --client-ca-file=/var/lib/rancher/k3s/server/tls/client-ca.crt --egress-selector-config-file=/var/lib/rancher/k3s/server/etc/egress-selector-config.yaml --enable-admission-plugins=NodeRestriction --enable-aggregator-routing=true --enable-bootstrap-token-auth=true --etcd-servers=unix://kine.sock --kubelet-certificate-authority=/var/lib/rancher/k3s/server/tls/server-ca.crt --kubelet-client-certificate=/var/lib/rancher/k3s/server/tls/client-kube-apiserver.crt --kubelet-client-key=/var/lib/rancher/k3s/server/tls/client-kube-apiserver.key --kubelet-preferred-address-types=InternalIP,ExternalIP,Hostname --profiling=false --proxy-client-cert-file=/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt --proxy-client-key-file=/var/lib/rancher/k3s/server/tls/client-auth-proxy.key --requestheader-allowed-names=system:auth-proxy --requestheader-client-ca-file=/var/lib/rancher/k3s/server/tls/request-header-ca.crt --requestheader-extra-headers-prefix=X-Remote-Extra- --requestheader-group-headers=X-Remote-Group --requestheader-username-headers=X-Remote-User --secure-port=6444 --service-account-issuer=https://kubernetes.default.svc.cluster.local --service-account-key-file=/var/lib/rancher/k3s/server/tls/service.key --service-account-signing-key-file=/var/lib/rancher/k3s/server/tls/service.current.key --service-cluster-ip-range=10.43.0.0/16 --service-node-port-range=30000-32767 --storage-backend=etcd3 --tls-cert-file=/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt --tls-cipher-suites=TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305,TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305 --tls-private-key-file=/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Running kube-scheduler --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --bind-address=127.0.0.1 --kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --leader-elect=false --profiling=false --secure-port=10259"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Waiting for API server to become available"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Running kube-controller-manager --allocate-node-cidrs=true --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --bind-address=127.0.0.1 --cluster-cidr=10.42.0.0/16 --cluster-signing-kube-apiserver-client-cert-file=/var/lib/rancher/k3s/server/tls/client-ca.nochain.crt --cluster-signing-kube-apiserver-client-key-file=/var/lib/rancher/k3s/server/tls/client-ca.key --cluster-signing-kubelet-client-cert-file=/var/lib/rancher/k3s/server/tls/client-ca.nochain.crt --cluster-signing-kubelet-client-key-file=/var/lib/rancher/k3s/server/tls/client-ca.key --cluster-signing-kubelet-serving-cert-file=/var/lib/rancher/k3s/server/tls/server-ca.nochain.crt --cluster-signing-kubelet-serving-key-file=/var/lib/rancher/k3s/server/tls/server-ca.key --cluster-signing-legacy-unknown-cert-file=/var/lib/rancher/k3s/server/tls/server-ca.nochain.crt --cluster-signing-legacy-unknown-key-file=/var/lib/rancher/k3s/server/tls/server-ca.key --configure-cloud-routes=false --controllers=*,tokencleaner,-service,-route,-cloud-node-lifecycle --kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --leader-elect=false --profiling=false --root-ca-file=/var/lib/rancher/k3s/server/tls/server-ca.crt --secure-port=10257 --service-account-private-key-file=/var/lib/rancher/k3s/server/tls/service.current.key --service-cluster-ip-range=10.43.0.0/16 --use-service-account-credentials=true"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.377192    4360 options.go:221] external host was not specified, using 10.174.47.117
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Running cloud-controller-manager --allocate-node-cidrs=true --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --bind-address=127.0.0.1 --cloud-config=/var/lib/rancher/k3s/server/etc/cloud-config.yaml --cloud-provider=k3s --cluster-cidr=10.42.0.0/16 --configure-cloud-routes=false --controllers=*,-route --feature-gates=CloudDualStackNodeIPs=true --kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --leader-elect=false --leader-elect-resource-name=k3s-cloud-controller-manager --node-status-update-frequency=1m0s --profiling=false"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.377783    4360 server.go:156] Version: v1.30.5+k3s1
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.377804    4360 server.go:158] "Golang settings" GOGC="" GOMAXPROCS="" GOTRACEBACK=""
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Server node token is available at /var/lib/rancher/k3s/server/token"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="To join server node to cluster: k3s server -s https://10.174.47.117:6443 -t ${SERVER_NODE_TOKEN}"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Agent node token is available at /var/lib/rancher/k3s/server/agent-token"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="To join agent node to cluster: k3s agent -s https://10.174.47.117:6443 -t ${AGENT_NODE_TOKEN}"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Wrote kubeconfig /etc/rancher/k3s/k3s.yaml"
Sep 27 16:09:04 debk3s k3s[4360]: time="2024-09-27T16:09:04Z" level=info msg="Run: k3s kubectl"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.390457    4360 shared_informer.go:313] Waiting for caches to sync for node_authorizer
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.396162    4360 shared_informer.go:313] Waiting for caches to sync for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.399424    4360 plugins.go:157] Loaded 12 mutating admission controller(s) successfully in the following order: NamespaceLifecycle,LimitRanger,ServiceAccount,NodeRestriction,TaintNodesByCondition,Priority,DefaultTolerationSeconds,DefaultStorageClass,StorageObjectInUseProtection,RuntimeClass,DefaultIngressClass,MutatingAdmissionWebhook.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.399442    4360 plugins.go:160] Loaded 13 validating admission controller(s) successfully in the following order: LimitRanger,ServiceAccount,PodSecurity,Priority,PersistentVolumeClaimResize,RuntimeClass,CertificateApproval,CertificateSigning,ClusterTrustBundleAttest,CertificateSubjectRestriction,ValidatingAdmissionPolicy,ValidatingAdmissionWebhook,ResourceQuota.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.399647    4360 instance.go:299] Using reconciler: lease
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.414549    4360 handler.go:286] Adding GroupVersion apiextensions.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.414575    4360 genericapiserver.go:733] Skipping API apiextensions.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.462769    4360 handler.go:286] Adding GroupVersion  v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.462956    4360 instance.go:696] API group "internal.apiserver.k8s.io" is not enabled, skipping.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.500342    4360 instance.go:696] API group "storagemigration.k8s.io" is not enabled, skipping.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.542408    4360 instance.go:696] API group "resource.k8s.io" is not enabled, skipping.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.569433    4360 handler.go:286] Adding GroupVersion authentication.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.569604    4360 genericapiserver.go:733] Skipping API authentication.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.569670    4360 genericapiserver.go:733] Skipping API authentication.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.570147    4360 handler.go:286] Adding GroupVersion authorization.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.570234    4360 genericapiserver.go:733] Skipping API authorization.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.571015    4360 handler.go:286] Adding GroupVersion autoscaling v2 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.571742    4360 handler.go:286] Adding GroupVersion autoscaling v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.571753    4360 genericapiserver.go:733] Skipping API autoscaling/v2beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.571759    4360 genericapiserver.go:733] Skipping API autoscaling/v2beta2 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.573032    4360 handler.go:286] Adding GroupVersion batch v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.573043    4360 genericapiserver.go:733] Skipping API batch/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.573854    4360 handler.go:286] Adding GroupVersion certificates.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.573865    4360 genericapiserver.go:733] Skipping API certificates.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.573871    4360 genericapiserver.go:733] Skipping API certificates.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.574392    4360 handler.go:286] Adding GroupVersion coordination.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.574406    4360 genericapiserver.go:733] Skipping API coordination.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.574464    4360 genericapiserver.go:733] Skipping API discovery.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.575041    4360 handler.go:286] Adding GroupVersion discovery.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.576626    4360 handler.go:286] Adding GroupVersion networking.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.576643    4360 genericapiserver.go:733] Skipping API networking.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.576650    4360 genericapiserver.go:733] Skipping API networking.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.577140    4360 handler.go:286] Adding GroupVersion node.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.577154    4360 genericapiserver.go:733] Skipping API node.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.577163    4360 genericapiserver.go:733] Skipping API node.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.578059    4360 handler.go:286] Adding GroupVersion policy v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.578076    4360 genericapiserver.go:733] Skipping API policy/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.579872    4360 handler.go:286] Adding GroupVersion rbac.authorization.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.579896    4360 genericapiserver.go:733] Skipping API rbac.authorization.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.579905    4360 genericapiserver.go:733] Skipping API rbac.authorization.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.580355    4360 handler.go:286] Adding GroupVersion scheduling.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.580369    4360 genericapiserver.go:733] Skipping API scheduling.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.580376    4360 genericapiserver.go:733] Skipping API scheduling.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.582360    4360 handler.go:286] Adding GroupVersion storage.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.582373    4360 genericapiserver.go:733] Skipping API storage.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.582380    4360 genericapiserver.go:733] Skipping API storage.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.583582    4360 handler.go:286] Adding GroupVersion flowcontrol.apiserver.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.584791    4360 handler.go:286] Adding GroupVersion flowcontrol.apiserver.k8s.io v1beta3 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.584805    4360 genericapiserver.go:733] Skipping API flowcontrol.apiserver.k8s.io/v1beta2 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.584812    4360 genericapiserver.go:733] Skipping API flowcontrol.apiserver.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.588295    4360 handler.go:286] Adding GroupVersion apps v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.588318    4360 genericapiserver.go:733] Skipping API apps/v1beta2 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.588326    4360 genericapiserver.go:733] Skipping API apps/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.590053    4360 handler.go:286] Adding GroupVersion admissionregistration.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.590066    4360 genericapiserver.go:733] Skipping API admissionregistration.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.590073    4360 genericapiserver.go:733] Skipping API admissionregistration.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.590582    4360 handler.go:286] Adding GroupVersion events.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.590594    4360 genericapiserver.go:733] Skipping API events.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.593808    4360 handler.go:286] Adding GroupVersion apiregistration.k8s.io v1 to ResourceManager
Sep 27 16:09:04 debk3s k3s[4360]: W0927 16:09:04.593829    4360 genericapiserver.go:733] Skipping API apiregistration.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946132    4360 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946137    4360 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946408    4360 dynamic_serving_content.go:132] "Starting controller" name="serving-cert::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946579    4360 secure_serving.go:213] Serving securely on 127.0.0.1:6444
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946631    4360 tlsconfig.go:240] "Starting DynamicServingCertificateController"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946802    4360 cluster_authentication_trust_controller.go:440] Starting cluster_authentication_trust_controller controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946814    4360 shared_informer.go:313] Waiting for caches to sync for cluster_authentication_trust_controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946898    4360 controller.go:116] Starting legacy_token_tracking_controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946907    4360 shared_informer.go:313] Waiting for caches to sync for configmaps
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946953    4360 customresource_discovery_controller.go:289] Starting DiscoveryController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946972    4360 controller.go:78] Starting OpenAPI AggregationController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.946995    4360 controller.go:80] Starting OpenAPI V3 AggregationController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947022    4360 system_namespaces_controller.go:67] Starting system namespaces controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947062    4360 gc_controller.go:78] Starting apiserver lease garbage collector
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947083    4360 dynamic_serving_content.go:132] "Starting controller" name="aggregator-proxy-cert::/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt::/var/lib/rancher/k3s/server/tls/client-auth-proxy.key"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947184    4360 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947259    4360 apf_controller.go:374] Starting API Priority and Fairness config controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947326    4360 aggregator.go:163] waiting for initial CRD sync...
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947346    4360 apiservice_controller.go:97] Starting APIServiceRegistrationController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947356    4360 cache.go:32] Waiting for caches to sync for APIServiceRegistrationController controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947377    4360 available_controller.go:423] Starting AvailableConditionController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947385    4360 cache.go:32] Waiting for caches to sync for AvailableConditionController controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947439    4360 controller.go:139] Starting OpenAPI controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947465    4360 controller.go:87] Starting OpenAPI V3 controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947481    4360 naming_controller.go:291] Starting NamingConditionController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947499    4360 establishing_controller.go:76] Starting EstablishingController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947521    4360 nonstructuralschema_controller.go:192] Starting NonStructuralSchemaConditionController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947534    4360 crdregistration_controller.go:111] Starting crd-autoregister controller
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947544    4360 shared_informer.go:313] Waiting for caches to sync for crd-autoregister
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947556    4360 crd_finalizer.go:266] Starting CRDFinalizer
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947538    4360 apiapproval_controller.go:186] Starting KubernetesAPIApprovalPolicyConformantConditionController
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.947260    4360 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:09:04 debk3s k3s[4360]: I0927 16:09:04.990703    4360 shared_informer.go:320] Caches are synced for node_authorizer
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.047153    4360 handler.go:286] Adding GroupVersion k3s.cattle.io v1 to ResourceManager
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.047250    4360 shared_informer.go:320] Caches are synced for cluster_authentication_trust_controller
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.047392    4360 shared_informer.go:320] Caches are synced for configmaps
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.047592    4360 cache.go:39] Caches are synced for APIServiceRegistrationController controller
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.047906    4360 handler.go:286] Adding GroupVersion helm.cattle.io v1 to ResourceManager
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.048088    4360 apf_controller.go:379] Running API Priority and Fairness config worker
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.048098    4360 apf_controller.go:382] Running API Priority and Fairness periodic rebalancing process
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.048830    4360 shared_informer.go:320] Caches are synced for crd-autoregister
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.049838    4360 aggregator.go:165] initial CRD sync complete...
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.049941    4360 autoregister_controller.go:141] Starting autoregister controller
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.050026    4360 cache.go:32] Waiting for caches to sync for autoregister controller
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.050165    4360 cache.go:39] Caches are synced for autoregister controller
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.050686    4360 cache.go:39] Caches are synced for AvailableConditionController controller
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.057343    4360 handler_discovery.go:447] Starting ResourceDiscoveryManager
Sep 27 16:09:05 debk3s k3s[4360]: E0927 16:09:05.063985    4360 controller.go:102] Error removing old endpoints from kubernetes service: no API server IP addresses were listed in storage, refusing to erase all endpoints for the kubernetes Service
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.096284    4360 shared_informer.go:320] Caches are synced for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.096323    4360 policy_source.go:224] refreshing policies
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.133153    4360 controller.go:615] quota admission added evaluator for: leases.coordination.k8s.io
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Password verified locally for node debk3s"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="certificate CN=debk3s signed by CN=k3s-server-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:09:05 +0000 UTC"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="certificate CN=system:node:debk3s,O=system:nodes signed by CN=k3s-client-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:09:05 +0000 UTC"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=warning msg="Host resolv.conf includes loopback or multicast nameservers - kubelet will use autogenerated resolv.conf with nameserver 8.8.8.8"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Module overlay was already loaded"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Module nf_conntrack was already loaded"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=warning msg="Failed to load kernel module br_netfilter with modprobe"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=warning msg="Failed to load kernel module iptable_nat with modprobe"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=warning msg="Failed to load kernel module iptable_filter with modprobe"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Set sysctl 'net/bridge/bridge-nf-call-iptables' to 1"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=error msg="Failed to set sysctl: open /proc/sys/net/bridge/bridge-nf-call-iptables: no such file or directory"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Set sysctl 'net/netfilter/nf_conntrack_max' to 131072"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=error msg="Failed to set sysctl: open /proc/sys/net/netfilter/nf_conntrack_max: permission denied"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Logging containerd to /var/lib/rancher/k3s/agent/containerd/containerd.log"
Sep 27 16:09:05 debk3s k3s[4360]: time="2024-09-27T16:09:05Z" level=info msg="Running containerd -c /var/lib/rancher/k3s/agent/etc/containerd/config.toml -a /run/k3s/containerd/containerd.sock --state /run/k3s/containerd --root /var/lib/rancher/k3s/agent/containerd"
Sep 27 16:09:05 debk3s k3s[4360]: I0927 16:09:05.964933    4360 storage_scheduling.go:111] all system priority classes are created successfully or already exist.
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Kube API server is now running"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="ETCD server is now running"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="k3s is up and running"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Waiting for cloud-controller-manager privileges to become available"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Creating k3s-supervisor event broadcaster"
Sep 27 16:09:06 debk3s systemd[1]: Started k3s.service - Lightweight Kubernetes.
Sep 27 16:09:06 debk3s k3s[4360]: W0927 16:09:06.408616    4360 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Applying CRD addons.k3s.cattle.io"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Applying CRD etcdsnapshotfiles.k3s.cattle.io"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Applying CRD helmcharts.helm.cattle.io"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Applying CRD helmchartconfigs.helm.cattle.io"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-25.0.3+up25.0.0.tgz"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-crd-25.0.3+up25.0.0.tgz"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/coredns.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/aggregated-metrics-reader.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-deployment.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-service.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/resource-reader.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/traefik.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/ccm.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/local-storage.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-delegator.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-reader.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-apiservice.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/rolebindings.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/runtimes.yaml"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Starting dynamiclistener CN filter node controller"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Tunnel server egress proxy mode: agent"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Starting k3s.cattle.io/v1, Kind=Addon controller"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Creating deploy event broadcaster"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.618167    4360 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.677651    4360 controller.go:615] quota admission added evaluator for: rolebindings.rbac.authorization.k8s.io
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.679347    4360 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="AppliedManifest" message="Applied manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.681004    4360 controller.go:615] quota admission added evaluator for: addons.k3s.cattle.io
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.688597    4360 event.go:389] "Event occurred" object="kube-system/coredns" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/coredns.yaml\""
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="containerd is now running"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Creating k3s-cert-monitor event broadcaster"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Connecting to proxy" url="wss://127.0.0.1:6443/v1-k3s/connect"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Running kubelet --address=0.0.0.0 --allowed-unsafe-sysctls=net.ipv4.ip_forward,net.ipv6.conf.all.forwarding --anonymous-auth=false --authentication-token-webhook=true --authorization-mode=Webhook --cgroup-driver=systemd --client-ca-file=/var/lib/rancher/k3s/agent/client-ca.crt --cloud-provider=external --cluster-dns=10.43.0.10 --cluster-domain=cluster.local --container-runtime-endpoint=unix:///run/k3s/containerd/containerd.sock --containerd=/run/k3s/containerd/containerd.sock --eviction-hard=imagefs.available<5%,nodefs.available<5% --eviction-minimum-reclaim=imagefs.available=10%,nodefs.available=10% --fail-swap-on=false --feature-gates=CloudDualStackNodeIPs=true --healthz-bind-address=127.0.0.1 --hostname-override=debk3s --kubeconfig=/var/lib/rancher/k3s/agent/kubelet.kubeconfig --node-ip=10.174.47.117,fd42:f085:b67c:18d1:216:3eff:fee7:36c3 --node-labels= --pod-manifest-path=/var/lib/rancher/k3s/agent/pod-manifests --read-only-port=0 --resolv-conf=/var/lib/rancher/k3s/agent/etc/resolv.conf --serialize-image-pulls=false --tls-cert-file=/var/lib/rancher/k3s/agent/serving-kubelet.crt --tls-private-key-file=/var/lib/rancher/k3s/agent/serving-kubelet.key"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Handling backend connection request [debk3s]"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Remotedialer connected to proxy" url="wss://127.0.0.1:6443/v1-k3s/connect"
Sep 27 16:09:06 debk3s k3s[4360]: Flag --containerd has been deprecated, This is a cadvisor flag that was mistakenly registered with the Kubelet. Due to legacy concerns, it will follow the standard CLI deprecation timeline before being removed.
Sep 27 16:09:06 debk3s k3s[4360]: W0927 16:09:06.713606    4360 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:06 debk3s k3s[4360]: W0927 16:09:06.713851    4360 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.716643    4360 server.go:479] "Kubelet version" kubeletVersion="v1.30.5+k3s1"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.716677    4360 server.go:481] "Golang settings" GOGC="" GOMAXPROCS="" GOTRACEBACK=""
Sep 27 16:09:06 debk3s k3s[4360]: W0927 16:09:06.716721    4360 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:06 debk3s k3s[4360]: W0927 16:09:06.716793    4360 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.718542    4360 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/agent/client-ca.crt"
Sep 27 16:09:06 debk3s k3s[4360]: W0927 16:09:06.726166    4360 fs.go:216] stat failed on /dev/sdb2 with error: no such file or directory
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Creating helm-controller event broadcaster"
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=info msg="Starting /v1, Kind=Node controller"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.741795    4360 server.go:737] "--cgroups-per-qos enabled, but --cgroup-root was not specified.  defaulting to /"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.741833    4360 server.go:805] "NoSwap is set due to memorySwapBehavior not specified" memorySwapBehavior="" FailSwapOn=false
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742246    4360 container_manager_linux.go:265] "Container manager verified user specified cgroup-root exists" cgroupRoot=[]
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742276    4360 container_manager_linux.go:270] "Creating Container Manager object based on Node Config" nodeConfig={"NodeName":"debk3s","RuntimeCgroupsName":"","SystemCgroupsName":"","KubeletCgroupsName":"","KubeletOOMScoreAdj":-999,"ContainerRuntime":"","CgroupsPerQOS":true,"CgroupRoot":"/","CgroupDriver":"systemd","KubeletRootDir":"/var/lib/kubelet","ProtectKernelDefaults":false,"KubeReservedCgroupName":"","SystemReservedCgroupName":"","ReservedSystemCPUs":{},"EnforceNodeAllocatable":{"pods":{}},"KubeReserved":null,"SystemReserved":null,"HardEvictionThresholds":[{"Signal":"nodefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null},{"Signal":"imagefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null}],"QOSReserved":{},"CPUManagerPolicy":"none","CPUManagerPolicyOptions":null,"TopologyManagerScope":"container","CPUManagerReconcilePeriod":10000000000,"ExperimentalMemoryManagerPolicy":"None","ExperimentalMemoryManagerReservedMemory":null,"PodPidsLimit":-1,"EnforceCPULimits":true,"CPUCFSQuotaPeriod":100000000,"TopologyManagerPolicy":"none","TopologyManagerPolicyOptions":null}
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742512    4360 topology_manager.go:138] "Creating topology manager with none policy"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742528    4360 container_manager_linux.go:301] "Creating device plugin manager"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742567    4360 state_mem.go:36] "Initialized new in-memory state store"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742657    4360 kubelet.go:401] "Attempting to sync node with API server"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742671    4360 kubelet.go:302] "Adding static pod path" path="/var/lib/rancher/k3s/agent/pod-manifests"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742696    4360 kubelet.go:313] "Adding apiserver pod source"
Sep 27 16:09:06 debk3s k3s[4360]: I0927 16:09:06.742707    4360 apiserver.go:42] "Waiting for node sync before watching apiserver pods"
Sep 27 16:09:06 debk3s k3s[4360]: Error: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory
Sep 27 16:09:06 debk3s k3s[4360]: time="2024-09-27T16:09:06Z" level=error msg="kubelet exited: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory"
Sep 27 16:09:06 debk3s systemd[1]: k3s.service: Main process exited, code=exited, status=1/FAILURE
Sep 27 16:09:06 debk3s systemd[1]: k3s.service: Failed with result 'exit-code'.
Sep 27 16:09:06 debk3s systemd[1]: k3s.service: Consumed 4.570s CPU time.
Sep 27 16:09:12 debk3s systemd[1]: k3s.service: Scheduled restart job, restart counter is at 16.
Sep 27 16:09:12 debk3s systemd[1]: Stopped k3s.service - Lightweight Kubernetes.
░░ The job identifier is 1271 and the job result is done.
Sep 27 16:09:12 debk3s systemd[1]: k3s.service: Consumed 4.570s CPU time.
Sep 27 16:09:12 debk3s systemd[1]: Starting k3s.service - Lightweight Kubernetes...
░░ The job identifier is 1271.
Sep 27 16:09:12 debk3s sh[4391]: + /usr/bin/systemctl is-enabled --quiet nm-cloud-setup.service
Sep 27 16:09:12 debk3s (modprobe)[4393]: k3s.service: Executable /sbin/modprobe missing, skipping: No such file or directory
Sep 27 16:09:12 debk3s (modprobe)[4394]: k3s.service: Executable /sbin/modprobe missing, skipping: No such file or directory
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Starting k3s v1.30.5+k3s1 (9b586704)"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Configuring sqlite3 database connection pooling: maxIdleConns=2, maxOpenConns=0, connMaxLifetime=0s"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Configuring database table schema and indexes, this may take a moment..."
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Database tables and indexes are up to date"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Kine available at unix://kine.sock"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Reconciling bootstrap data between datastore and disk"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Running kube-apiserver --advertise-port=6443 --allow-privileged=true --anonymous-auth=false --api-audiences=https://kubernetes.default.svc.cluster.local,k3s --authorization-mode=Node,RBAC --bind-address=127.0.0.1 --cert-dir=/var/lib/rancher/k3s/server/tls/temporary-certs --client-ca-file=/var/lib/rancher/k3s/server/tls/client-ca.crt --egress-selector-config-file=/var/lib/rancher/k3s/server/etc/egress-selector-config.yaml --enable-admission-plugins=NodeRestriction --enable-aggregator-routing=true --enable-bootstrap-token-auth=true --etcd-servers=unix://kine.sock --kubelet-certificate-authority=/var/lib/rancher/k3s/server/tls/server-ca.crt --kubelet-client-certificate=/var/lib/rancher/k3s/server/tls/client-kube-apiserver.crt --kubelet-client-key=/var/lib/rancher/k3s/server/tls/client-kube-apiserver.key --kubelet-preferred-address-types=InternalIP,ExternalIP,Hostname --profiling=false --proxy-client-cert-file=/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt --proxy-client-key-file=/var/lib/rancher/k3s/server/tls/client-auth-proxy.key --requestheader-allowed-names=system:auth-proxy --requestheader-client-ca-file=/var/lib/rancher/k3s/server/tls/request-header-ca.crt --requestheader-extra-headers-prefix=X-Remote-Extra- --requestheader-group-headers=X-Remote-Group --requestheader-username-headers=X-Remote-User --secure-port=6444 --service-account-issuer=https://kubernetes.default.svc.cluster.local --service-account-key-file=/var/lib/rancher/k3s/server/tls/service.key --service-account-signing-key-file=/var/lib/rancher/k3s/server/tls/service.current.key --service-cluster-ip-range=10.43.0.0/16 --service-node-port-range=30000-32767 --storage-backend=etcd3 --tls-cert-file=/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt --tls-cipher-suites=TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305,TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305 --tls-private-key-file=/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Running kube-scheduler --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --bind-address=127.0.0.1 --kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --leader-elect=false --profiling=false --secure-port=10259"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Waiting for API server to become available"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Running kube-controller-manager --allocate-node-cidrs=true --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --bind-address=127.0.0.1 --cluster-cidr=10.42.0.0/16 --cluster-signing-kube-apiserver-client-cert-file=/var/lib/rancher/k3s/server/tls/client-ca.nochain.crt --cluster-signing-kube-apiserver-client-key-file=/var/lib/rancher/k3s/server/tls/client-ca.key --cluster-signing-kubelet-client-cert-file=/var/lib/rancher/k3s/server/tls/client-ca.nochain.crt --cluster-signing-kubelet-client-key-file=/var/lib/rancher/k3s/server/tls/client-ca.key --cluster-signing-kubelet-serving-cert-file=/var/lib/rancher/k3s/server/tls/server-ca.nochain.crt --cluster-signing-kubelet-serving-key-file=/var/lib/rancher/k3s/server/tls/server-ca.key --cluster-signing-legacy-unknown-cert-file=/var/lib/rancher/k3s/server/tls/server-ca.nochain.crt --cluster-signing-legacy-unknown-key-file=/var/lib/rancher/k3s/server/tls/server-ca.key --configure-cloud-routes=false --controllers=*,tokencleaner,-service,-route,-cloud-node-lifecycle --kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --leader-elect=false --profiling=false --root-ca-file=/var/lib/rancher/k3s/server/tls/server-ca.crt --secure-port=10257 --service-account-private-key-file=/var/lib/rancher/k3s/server/tls/service.current.key --service-cluster-ip-range=10.43.0.0/16 --use-service-account-credentials=true"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.388375    4438 options.go:221] external host was not specified, using 10.174.47.117
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Running cloud-controller-manager --allocate-node-cidrs=true --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --bind-address=127.0.0.1 --cloud-config=/var/lib/rancher/k3s/server/etc/cloud-config.yaml --cloud-provider=k3s --cluster-cidr=10.42.0.0/16 --configure-cloud-routes=false --controllers=*,-route --feature-gates=CloudDualStackNodeIPs=true --kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --leader-elect=false --leader-elect-resource-name=k3s-cloud-controller-manager --node-status-update-frequency=1m0s --profiling=false"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.389010    4438 server.go:156] Version: v1.30.5+k3s1
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.389042    4438 server.go:158] "Golang settings" GOGC="" GOMAXPROCS="" GOTRACEBACK=""
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Server node token is available at /var/lib/rancher/k3s/server/token"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="To join server node to cluster: k3s server -s https://10.174.47.117:6443 -t ${SERVER_NODE_TOKEN}"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Agent node token is available at /var/lib/rancher/k3s/server/agent-token"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="To join agent node to cluster: k3s agent -s https://10.174.47.117:6443 -t ${AGENT_NODE_TOKEN}"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Wrote kubeconfig /etc/rancher/k3s/k3s.yaml"
Sep 27 16:09:20 debk3s k3s[4438]: time="2024-09-27T16:09:20Z" level=info msg="Run: k3s kubectl"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.398889    4438 shared_informer.go:313] Waiting for caches to sync for node_authorizer
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.402670    4438 shared_informer.go:313] Waiting for caches to sync for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.406282    4438 plugins.go:157] Loaded 12 mutating admission controller(s) successfully in the following order: NamespaceLifecycle,LimitRanger,ServiceAccount,NodeRestriction,TaintNodesByCondition,Priority,DefaultTolerationSeconds,DefaultStorageClass,StorageObjectInUseProtection,RuntimeClass,DefaultIngressClass,MutatingAdmissionWebhook.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.406299    4438 plugins.go:160] Loaded 13 validating admission controller(s) successfully in the following order: LimitRanger,ServiceAccount,PodSecurity,Priority,PersistentVolumeClaimResize,RuntimeClass,CertificateApproval,CertificateSigning,ClusterTrustBundleAttest,CertificateSubjectRestriction,ValidatingAdmissionPolicy,ValidatingAdmissionWebhook,ResourceQuota.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.406515    4438 instance.go:299] Using reconciler: lease
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.422379    4438 handler.go:286] Adding GroupVersion apiextensions.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.422405    4438 genericapiserver.go:733] Skipping API apiextensions.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.469392    4438 handler.go:286] Adding GroupVersion  v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.469581    4438 instance.go:696] API group "internal.apiserver.k8s.io" is not enabled, skipping.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.504779    4438 instance.go:696] API group "storagemigration.k8s.io" is not enabled, skipping.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.539878    4438 instance.go:696] API group "resource.k8s.io" is not enabled, skipping.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.549373    4438 handler.go:286] Adding GroupVersion authentication.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.549397    4438 genericapiserver.go:733] Skipping API authentication.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.549404    4438 genericapiserver.go:733] Skipping API authentication.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.549875    4438 handler.go:286] Adding GroupVersion authorization.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.549886    4438 genericapiserver.go:733] Skipping API authorization.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.550668    4438 handler.go:286] Adding GroupVersion autoscaling v2 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.551392    4438 handler.go:286] Adding GroupVersion autoscaling v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.551403    4438 genericapiserver.go:733] Skipping API autoscaling/v2beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.551410    4438 genericapiserver.go:733] Skipping API autoscaling/v2beta2 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.552705    4438 handler.go:286] Adding GroupVersion batch v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.552719    4438 genericapiserver.go:733] Skipping API batch/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.553402    4438 handler.go:286] Adding GroupVersion certificates.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.553475    4438 genericapiserver.go:733] Skipping API certificates.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.553484    4438 genericapiserver.go:733] Skipping API certificates.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.553914    4438 handler.go:286] Adding GroupVersion coordination.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.553925    4438 genericapiserver.go:733] Skipping API coordination.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.553984    4438 genericapiserver.go:733] Skipping API discovery.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.554429    4438 handler.go:286] Adding GroupVersion discovery.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.556276    4438 handler.go:286] Adding GroupVersion networking.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.556297    4438 genericapiserver.go:733] Skipping API networking.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.556306    4438 genericapiserver.go:733] Skipping API networking.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.557778    4438 handler.go:286] Adding GroupVersion node.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.557797    4438 genericapiserver.go:733] Skipping API node.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.557806    4438 genericapiserver.go:733] Skipping API node.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.558746    4438 handler.go:286] Adding GroupVersion policy v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.559145    4438 genericapiserver.go:733] Skipping API policy/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.573828    4438 handler.go:286] Adding GroupVersion rbac.authorization.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.573850    4438 genericapiserver.go:733] Skipping API rbac.authorization.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.573858    4438 genericapiserver.go:733] Skipping API rbac.authorization.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.574284    4438 handler.go:286] Adding GroupVersion scheduling.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.574299    4438 genericapiserver.go:733] Skipping API scheduling.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.574306    4438 genericapiserver.go:733] Skipping API scheduling.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.575961    4438 handler.go:286] Adding GroupVersion storage.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.575982    4438 genericapiserver.go:733] Skipping API storage.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.575991    4438 genericapiserver.go:733] Skipping API storage.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.576823    4438 handler.go:286] Adding GroupVersion flowcontrol.apiserver.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.577880    4438 handler.go:286] Adding GroupVersion flowcontrol.apiserver.k8s.io v1beta3 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.577896    4438 genericapiserver.go:733] Skipping API flowcontrol.apiserver.k8s.io/v1beta2 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.577916    4438 genericapiserver.go:733] Skipping API flowcontrol.apiserver.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.581143    4438 handler.go:286] Adding GroupVersion apps v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.581168    4438 genericapiserver.go:733] Skipping API apps/v1beta2 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.581175    4438 genericapiserver.go:733] Skipping API apps/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.582555    4438 handler.go:286] Adding GroupVersion admissionregistration.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.582577    4438 genericapiserver.go:733] Skipping API admissionregistration.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.582585    4438 genericapiserver.go:733] Skipping API admissionregistration.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.583233    4438 handler.go:286] Adding GroupVersion events.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.583246    4438 genericapiserver.go:733] Skipping API events.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.586326    4438 handler.go:286] Adding GroupVersion apiregistration.k8s.io v1 to ResourceManager
Sep 27 16:09:20 debk3s k3s[4438]: W0927 16:09:20.586355    4438 genericapiserver.go:733] Skipping API apiregistration.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941368    4438 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941368    4438 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941606    4438 dynamic_serving_content.go:132] "Starting controller" name="serving-cert::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941762    4438 secure_serving.go:213] Serving securely on 127.0.0.1:6444
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941810    4438 tlsconfig.go:240] "Starting DynamicServingCertificateController"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941861    4438 controller.go:78] Starting OpenAPI AggregationController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941899    4438 aggregator.go:163] waiting for initial CRD sync...
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941977    4438 controller.go:116] Starting legacy_token_tracking_controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.941987    4438 shared_informer.go:313] Waiting for caches to sync for configmaps
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942087    4438 customresource_discovery_controller.go:289] Starting DiscoveryController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942128    4438 available_controller.go:423] Starting AvailableConditionController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942135    4438 cache.go:32] Waiting for caches to sync for AvailableConditionController controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942150    4438 controller.go:80] Starting OpenAPI V3 AggregationController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942354    4438 dynamic_serving_content.go:132] "Starting controller" name="aggregator-proxy-cert::/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt::/var/lib/rancher/k3s/server/tls/client-auth-proxy.key"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942433    4438 system_namespaces_controller.go:67] Starting system namespaces controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942472    4438 apf_controller.go:374] Starting API Priority and Fairness config controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942728    4438 cluster_authentication_trust_controller.go:440] Starting cluster_authentication_trust_controller controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942737    4438 shared_informer.go:313] Waiting for caches to sync for cluster_authentication_trust_controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942788    4438 apiservice_controller.go:97] Starting APIServiceRegistrationController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942797    4438 cache.go:32] Waiting for caches to sync for APIServiceRegistrationController controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942828    4438 gc_controller.go:78] Starting apiserver lease garbage collector
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942876    4438 crdregistration_controller.go:111] Starting crd-autoregister controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942886    4438 shared_informer.go:313] Waiting for caches to sync for crd-autoregister
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.942944    4438 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943004    4438 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943087    4438 controller.go:139] Starting OpenAPI controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943121    4438 controller.go:87] Starting OpenAPI V3 controller
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943140    4438 naming_controller.go:291] Starting NamingConditionController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943163    4438 establishing_controller.go:76] Starting EstablishingController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943903    4438 nonstructuralschema_controller.go:192] Starting NonStructuralSchemaConditionController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943925    4438 apiapproval_controller.go:186] Starting KubernetesAPIApprovalPolicyConformantConditionController
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.943942    4438 crd_finalizer.go:266] Starting CRDFinalizer
Sep 27 16:09:20 debk3s k3s[4438]: I0927 16:09:20.998929    4438 shared_informer.go:320] Caches are synced for node_authorizer
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.003389    4438 shared_informer.go:320] Caches are synced for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.003536    4438 policy_source.go:224] refreshing policies
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.042970    4438 shared_informer.go:320] Caches are synced for crd-autoregister
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043016    4438 cache.go:39] Caches are synced for AvailableConditionController controller
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043188    4438 cache.go:39] Caches are synced for APIServiceRegistrationController controller
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043446    4438 shared_informer.go:320] Caches are synced for configmaps
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043458    4438 apf_controller.go:379] Running API Priority and Fairness config worker
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043469    4438 apf_controller.go:382] Running API Priority and Fairness periodic rebalancing process
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043502    4438 handler.go:286] Adding GroupVersion k3s.cattle.io v1 to ResourceManager
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043542    4438 handler.go:286] Adding GroupVersion helm.cattle.io v1 to ResourceManager
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043549    4438 aggregator.go:165] initial CRD sync complete...
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043556    4438 autoregister_controller.go:141] Starting autoregister controller
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043562    4438 cache.go:32] Waiting for caches to sync for autoregister controller
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.043568    4438 cache.go:39] Caches are synced for autoregister controller
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.044632    4438 shared_informer.go:320] Caches are synced for cluster_authentication_trust_controller
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.077869    4438 handler_discovery.go:447] Starting ResourceDiscoveryManager
Sep 27 16:09:21 debk3s k3s[4438]: E0927 16:09:21.086523    4438 controller.go:102] Error removing old endpoints from kubernetes service: no API server IP addresses were listed in storage, refusing to erase all endpoints for the kubernetes Service
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.096532    4438 controller.go:615] quota admission added evaluator for: leases.coordination.k8s.io
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Password verified locally for node debk3s"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="certificate CN=debk3s signed by CN=k3s-server-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:09:21 +0000 UTC"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="certificate CN=system:node:debk3s,O=system:nodes signed by CN=k3s-client-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:09:21 +0000 UTC"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=warning msg="Host resolv.conf includes loopback or multicast nameservers - kubelet will use autogenerated resolv.conf with nameserver 8.8.8.8"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Module overlay was already loaded"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Module nf_conntrack was already loaded"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=warning msg="Failed to load kernel module br_netfilter with modprobe"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=warning msg="Failed to load kernel module iptable_nat with modprobe"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=warning msg="Failed to load kernel module iptable_filter with modprobe"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Set sysctl 'net/bridge/bridge-nf-call-iptables' to 1"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=error msg="Failed to set sysctl: open /proc/sys/net/bridge/bridge-nf-call-iptables: no such file or directory"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Set sysctl 'net/netfilter/nf_conntrack_max' to 131072"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=error msg="Failed to set sysctl: open /proc/sys/net/netfilter/nf_conntrack_max: permission denied"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Logging containerd to /var/lib/rancher/k3s/agent/containerd/containerd.log"
Sep 27 16:09:21 debk3s k3s[4438]: time="2024-09-27T16:09:21Z" level=info msg="Running containerd -c /var/lib/rancher/k3s/agent/etc/containerd/config.toml -a /run/k3s/containerd/containerd.sock --state /run/k3s/containerd --root /var/lib/rancher/k3s/agent/containerd"
Sep 27 16:09:21 debk3s k3s[4438]: I0927 16:09:21.960920    4438 storage_scheduling.go:111] all system priority classes are created successfully or already exist.
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Kube API server is now running"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="ETCD server is now running"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="k3s is up and running"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Waiting for cloud-controller-manager privileges to become available"
Sep 27 16:09:22 debk3s systemd[1]: Started k3s.service - Lightweight Kubernetes.
░░ Subject: A start job for unit k3s.service has finished successfully
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit k3s.service has finished successfully.
░░ The job identifier is 1328.
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Creating k3s-supervisor event broadcaster"
Sep 27 16:09:22 debk3s k3s[4438]: W0927 16:09:22.400231    4438 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Applying CRD addons.k3s.cattle.io"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Applying CRD etcdsnapshotfiles.k3s.cattle.io"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Applying CRD helmcharts.helm.cattle.io"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Applying CRD helmchartconfigs.helm.cattle.io"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-25.0.3+up25.0.0.tgz"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-crd-25.0.3+up25.0.0.tgz"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/rolebindings.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/local-storage.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/aggregated-metrics-reader.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-reader.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-deployment.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-service.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/resource-reader.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/runtimes.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/traefik.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/ccm.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/coredns.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-delegator.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-apiservice.yaml"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Tunnel server egress proxy mode: agent"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Starting dynamiclistener CN filter node controller"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Starting k3s.cattle.io/v1, Kind=Addon controller"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Creating deploy event broadcaster"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.609398    4438 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.636391    4438 controller.go:615] quota admission added evaluator for: rolebindings.rbac.authorization.k8s.io
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.637991    4438 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="AppliedManifest" message="Applied manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.639712    4438 controller.go:615] quota admission added evaluator for: addons.k3s.cattle.io
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.646663    4438 event.go:389] "Event occurred" object="kube-system/coredns" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/coredns.yaml\""
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="containerd is now running"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.695079    4438 controller.go:615] quota admission added evaluator for: deployments.apps
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Creating k3s-cert-monitor event broadcaster"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Connecting to proxy" url="wss://127.0.0.1:6443/v1-k3s/connect"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Running kubelet --address=0.0.0.0 --allowed-unsafe-sysctls=net.ipv4.ip_forward,net.ipv6.conf.all.forwarding --anonymous-auth=false --authentication-token-webhook=true --authorization-mode=Webhook --cgroup-driver=systemd --client-ca-file=/var/lib/rancher/k3s/agent/client-ca.crt --cloud-provider=external --cluster-dns=10.43.0.10 --cluster-domain=cluster.local --container-runtime-endpoint=unix:///run/k3s/containerd/containerd.sock --containerd=/run/k3s/containerd/containerd.sock --eviction-hard=imagefs.available<5%,nodefs.available<5% --eviction-minimum-reclaim=imagefs.available=10%,nodefs.available=10% --fail-swap-on=false --feature-gates=CloudDualStackNodeIPs=true --healthz-bind-address=127.0.0.1 --hostname-override=debk3s --kubeconfig=/var/lib/rancher/k3s/agent/kubelet.kubeconfig --node-ip=10.174.47.117,fd42:f085:b67c:18d1:216:3eff:fee7:36c3 --node-labels= --pod-manifest-path=/var/lib/rancher/k3s/agent/pod-manifests --read-only-port=0 --resolv-conf=/var/lib/rancher/k3s/agent/etc/resolv.conf --serialize-image-pulls=false --tls-cert-file=/var/lib/rancher/k3s/agent/serving-kubelet.crt --tls-private-key-file=/var/lib/rancher/k3s/agent/serving-kubelet.key"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Handling backend connection request [debk3s]"
Sep 27 16:09:22 debk3s k3s[4438]: Flag --containerd has been deprecated, This is a cadvisor flag that was mistakenly registered with the Kubelet. Due to legacy concerns, it will follow the standard CLI deprecation timeline before being removed.
Sep 27 16:09:22 debk3s k3s[4438]: W0927 16:09:22.707585    4438 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:22 debk3s k3s[4438]: W0927 16:09:22.707809    4438 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Remotedialer connected to proxy" url="wss://127.0.0.1:6443/v1-k3s/connect"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.709338    4438 server.go:479] "Kubelet version" kubeletVersion="v1.30.5+k3s1"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.709359    4438 server.go:481] "Golang settings" GOGC="" GOMAXPROCS="" GOTRACEBACK=""
Sep 27 16:09:22 debk3s k3s[4438]: W0927 16:09:22.709404    4438 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:22 debk3s k3s[4438]: W0927 16:09:22.709499    4438 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.714192    4438 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/agent/client-ca.crt"
Sep 27 16:09:22 debk3s k3s[4438]: W0927 16:09:22.719461    4438 fs.go:216] stat failed on /dev/sdb2 with error: no such file or directory
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.732177    4438 event.go:389] "Event occurred" object="kube-system/coredns" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="AppliedManifest" message="Applied manifest at \"/var/lib/rancher/k3s/server/manifests/coredns.yaml\""
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Creating helm-controller event broadcaster"
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=info msg="Starting /v1, Kind=Node controller"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.743903    4438 server.go:737] "--cgroups-per-qos enabled, but --cgroup-root was not specified.  defaulting to /"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.744021    4438 server.go:805] "NoSwap is set due to memorySwapBehavior not specified" memorySwapBehavior="" FailSwapOn=false
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.744496    4438 container_manager_linux.go:265] "Container manager verified user specified cgroup-root exists" cgroupRoot=[]
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.744590    4438 container_manager_linux.go:270] "Creating Container Manager object based on Node Config" nodeConfig={"NodeName":"debk3s","RuntimeCgroupsName":"","SystemCgroupsName":"","KubeletCgroupsName":"","KubeletOOMScoreAdj":-999,"ContainerRuntime":"","CgroupsPerQOS":true,"CgroupRoot":"/","CgroupDriver":"systemd","KubeletRootDir":"/var/lib/kubelet","ProtectKernelDefaults":false,"KubeReservedCgroupName":"","SystemReservedCgroupName":"","ReservedSystemCPUs":{},"EnforceNodeAllocatable":{"pods":{}},"KubeReserved":null,"SystemReserved":null,"HardEvictionThresholds":[{"Signal":"imagefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null},{"Signal":"nodefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null}],"QOSReserved":{},"CPUManagerPolicy":"none","CPUManagerPolicyOptions":null,"TopologyManagerScope":"container","CPUManagerReconcilePeriod":10000000000,"ExperimentalMemoryManagerPolicy":"None","ExperimentalMemoryManagerReservedMemory":null,"PodPidsLimit":-1,"EnforceCPULimits":true,"CPUCFSQuotaPeriod":100000000,"TopologyManagerPolicy":"none","TopologyManagerPolicyOptions":null}
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746038    4438 topology_manager.go:138] "Creating topology manager with none policy"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746067    4438 container_manager_linux.go:301] "Creating device plugin manager"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746122    4438 state_mem.go:36] "Initialized new in-memory state store"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746273    4438 kubelet.go:401] "Attempting to sync node with API server"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746291    4438 kubelet.go:302] "Adding static pod path" path="/var/lib/rancher/k3s/agent/pod-manifests"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746317    4438 kubelet.go:313] "Adding apiserver pod source"
Sep 27 16:09:22 debk3s k3s[4438]: I0927 16:09:22.746337    4438 apiserver.go:42] "Waiting for node sync before watching apiserver pods"
Sep 27 16:09:22 debk3s k3s[4438]: Error: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory
Sep 27 16:09:22 debk3s k3s[4438]: time="2024-09-27T16:09:22Z" level=error msg="kubelet exited: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory"
Sep 27 16:09:22 debk3s systemd[1]: k3s.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit k3s.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Sep 27 16:09:22 debk3s systemd[1]: k3s.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit k3s.service has entered the 'failed' state with result 'exit-code'.
Sep 27 16:09:22 debk3s systemd[1]: k3s.service: Consumed 4.574s CPU time.
░░ Subject: Resources consumed by unit runtime
░░ The unit k3s.service completed and consumed the indicated resources.
Sep 27 16:09:28 debk3s systemd[1]: k3s.service: Scheduled restart job, restart counter is at 18.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit k3s.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Sep 27 16:09:28 debk3s systemd[1]: Stopped k3s.service - Lightweight Kubernetes.
░░ Subject: A stop job for unit k3s.service has finished
░░ A stop job for unit k3s.service has finished.
░░ The job identifier is 1385 and the job result is done.
Sep 27 16:09:28 debk3s systemd[1]: k3s.service: Consumed 4.574s CPU time.
Sep 27 16:09:28 debk3s systemd[1]: Starting k3s.service - Lightweight Kubernetes...
░░ Subject: A start job for unit k3s.service has begun execution
░░ A start job for unit k3s.service has begun execution.
░░ The job identifier is 1385.
Sep 27 16:09:28 debk3s sh[4469]: + /usr/bin/systemctl is-enabled --quiet nm-cloud-setup.service
Sep 27 16:09:28 debk3s (modprobe)[4471]: k3s.service: Executable /sbin/modprobe missing, skipping: No such file or directory
░░ Subject: Process /sbin/modprobe could not be executed
░░ The process /sbin/modprobe could not be executed and failed.
░░ The error number returned by this process is 2.
Sep 27 16:09:28 debk3s (modprobe)[4472]: k3s.service: Executable /sbin/modprobe missing, skipping: No such file or directory
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Starting k3s v1.30.5+k3s1 (9b586704)"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Configuring sqlite3 database connection pooling: maxIdleConns=2, maxOpenConns=0, connMaxLifetime=0s"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Configuring database table schema and indexes, this may take a moment..."
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Database tables and indexes are up to date"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Kine available at unix://kine.sock"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Reconciling bootstrap data between datastore and disk"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Running kube-apiserver --advertise-port=6443 --allow-privileged=true --anonymous-auth=false --api-audiences=https://kubernetes.default.svc.cluster.local,k3s --authorization-mode=Node,RBAC --bind-address=127.0.0.1 --cert-dir=/var/lib/rancher/k3s/server/tls/temporary-certs --client-ca-file=/var/lib/rancher/k3s/server/tls/client-ca.crt --egress-selector-config-file=/var/lib/rancher/k3s/server/etc/egress-selector-config.yaml --enable-admission-plugins=NodeRestriction --enable-aggregator-routing=true --enable-bootstrap-token-auth=true --etcd-servers=unix://kine.sock --kubelet-certificate-authority=/var/lib/rancher/k3s/server/tls/server-ca.crt --kubelet-client-certificate=/var/lib/rancher/k3s/server/tls/client-kube-apiserver.crt --kubelet-client-key=/var/lib/rancher/k3s/server/tls/client-kube-apiserver.key --kubelet-preferred-address-types=InternalIP,ExternalIP,Hostname --profiling=false --proxy-client-cert-file=/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt --proxy-client-key-file=/var/lib/rancher/k3s/server/tls/client-auth-proxy.key --requestheader-allowed-names=system:auth-proxy --requestheader-client-ca-file=/var/lib/rancher/k3s/server/tls/request-header-ca.crt --requestheader-extra-headers-prefix=X-Remote-Extra- --requestheader-group-headers=X-Remote-Group --requestheader-username-headers=X-Remote-User --secure-port=6444 --service-account-issuer=https://kubernetes.default.svc.cluster.local --service-account-key-file=/var/lib/rancher/k3s/server/tls/service.key --service-account-signing-key-file=/var/lib/rancher/k3s/server/tls/service.current.key --service-cluster-ip-range=10.43.0.0/16 --service-node-port-range=30000-32767 --storage-backend=etcd3 --tls-cert-file=/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt --tls-cipher-suites=TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305,TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305 --tls-private-key-file=/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Running kube-scheduler --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --bind-address=127.0.0.1 --kubeconfig=/var/lib/rancher/k3s/server/cred/scheduler.kubeconfig --leader-elect=false --profiling=false --secure-port=10259"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Waiting for API server to become available"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Running kube-controller-manager --allocate-node-cidrs=true --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --bind-address=127.0.0.1 --cluster-cidr=10.42.0.0/16 --cluster-signing-kube-apiserver-client-cert-file=/var/lib/rancher/k3s/server/tls/client-ca.nochain.crt --cluster-signing-kube-apiserver-client-key-file=/var/lib/rancher/k3s/server/tls/client-ca.key --cluster-signing-kubelet-client-cert-file=/var/lib/rancher/k3s/server/tls/client-ca.nochain.crt --cluster-signing-kubelet-client-key-file=/var/lib/rancher/k3s/server/tls/client-ca.key --cluster-signing-kubelet-serving-cert-file=/var/lib/rancher/k3s/server/tls/server-ca.nochain.crt --cluster-signing-kubelet-serving-key-file=/var/lib/rancher/k3s/server/tls/server-ca.key --cluster-signing-legacy-unknown-cert-file=/var/lib/rancher/k3s/server/tls/server-ca.nochain.crt --cluster-signing-legacy-unknown-key-file=/var/lib/rancher/k3s/server/tls/server-ca.key --configure-cloud-routes=false --controllers=*,tokencleaner,-service,-route,-cloud-node-lifecycle --kubeconfig=/var/lib/rancher/k3s/server/cred/controller.kubeconfig --leader-elect=false --profiling=false --root-ca-file=/var/lib/rancher/k3s/server/tls/server-ca.crt --secure-port=10257 --service-account-private-key-file=/var/lib/rancher/k3s/server/tls/service.current.key --service-cluster-ip-range=10.43.0.0/16 --use-service-account-credentials=true"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.356493    4473 options.go:221] external host was not specified, using 10.174.47.117
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Running cloud-controller-manager --allocate-node-cidrs=true --authentication-kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --authorization-kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --bind-address=127.0.0.1 --cloud-config=/var/lib/rancher/k3s/server/etc/cloud-config.yaml --cloud-provider=k3s --cluster-cidr=10.42.0.0/16 --configure-cloud-routes=false --controllers=*,-route --feature-gates=CloudDualStackNodeIPs=true --kubeconfig=/var/lib/rancher/k3s/server/cred/cloud-controller.kubeconfig --leader-elect=false --leader-elect-resource-name=k3s-cloud-controller-manager --node-status-update-frequency=1m0s --profiling=false"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.357089    4473 server.go:156] Version: v1.30.5+k3s1
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.357112    4473 server.go:158] "Golang settings" GOGC="" GOMAXPROCS="" GOTRACEBACK=""
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Server node token is available at /var/lib/rancher/k3s/server/token"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="To join server node to cluster: k3s server -s https://10.174.47.117:6443 -t ${SERVER_NODE_TOKEN}"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Agent node token is available at /var/lib/rancher/k3s/server/agent-token"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="To join agent node to cluster: k3s agent -s https://10.174.47.117:6443 -t ${AGENT_NODE_TOKEN}"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Wrote kubeconfig /etc/rancher/k3s/k3s.yaml"
Sep 27 16:09:28 debk3s k3s[4473]: time="2024-09-27T16:09:28Z" level=info msg="Run: k3s kubectl"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.373755    4473 shared_informer.go:313] Waiting for caches to sync for node_authorizer
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.379237    4473 shared_informer.go:313] Waiting for caches to sync for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.382749    4473 plugins.go:157] Loaded 12 mutating admission controller(s) successfully in the following order: NamespaceLifecycle,LimitRanger,ServiceAccount,NodeRestriction,TaintNodesByCondition,Priority,DefaultTolerationSeconds,DefaultStorageClass,StorageObjectInUseProtection,RuntimeClass,DefaultIngressClass,MutatingAdmissionWebhook.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.382766    4473 plugins.go:160] Loaded 13 validating admission controller(s) successfully in the following order: LimitRanger,ServiceAccount,PodSecurity,Priority,PersistentVolumeClaimResize,RuntimeClass,CertificateApproval,CertificateSigning,ClusterTrustBundleAttest,CertificateSubjectRestriction,ValidatingAdmissionPolicy,ValidatingAdmissionWebhook,ResourceQuota.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.382952    4473 instance.go:299] Using reconciler: lease
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.389180    4473 handler.go:286] Adding GroupVersion apiextensions.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.389199    4473 genericapiserver.go:733] Skipping API apiextensions.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.441035    4473 handler.go:286] Adding GroupVersion  v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.441240    4473 instance.go:696] API group "internal.apiserver.k8s.io" is not enabled, skipping.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.479905    4473 instance.go:696] API group "storagemigration.k8s.io" is not enabled, skipping.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.515418    4473 instance.go:696] API group "resource.k8s.io" is not enabled, skipping.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.525246    4473 handler.go:286] Adding GroupVersion authentication.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.525273    4473 genericapiserver.go:733] Skipping API authentication.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.525280    4473 genericapiserver.go:733] Skipping API authentication.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.525665    4473 handler.go:286] Adding GroupVersion authorization.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.525675    4473 genericapiserver.go:733] Skipping API authorization.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.526443    4473 handler.go:286] Adding GroupVersion autoscaling v2 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.527093    4473 handler.go:286] Adding GroupVersion autoscaling v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.527103    4473 genericapiserver.go:733] Skipping API autoscaling/v2beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.527110    4473 genericapiserver.go:733] Skipping API autoscaling/v2beta2 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.528478    4473 handler.go:286] Adding GroupVersion batch v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.528495    4473 genericapiserver.go:733] Skipping API batch/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.529220    4473 handler.go:286] Adding GroupVersion certificates.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.529232    4473 genericapiserver.go:733] Skipping API certificates.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.529240    4473 genericapiserver.go:733] Skipping API certificates.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.529731    4473 handler.go:286] Adding GroupVersion coordination.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.529742    4473 genericapiserver.go:733] Skipping API coordination.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.529788    4473 genericapiserver.go:733] Skipping API discovery.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.530268    4473 handler.go:286] Adding GroupVersion discovery.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.531589    4473 handler.go:286] Adding GroupVersion networking.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.531600    4473 genericapiserver.go:733] Skipping API networking.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.531607    4473 genericapiserver.go:733] Skipping API networking.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.532008    4473 handler.go:286] Adding GroupVersion node.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.532020    4473 genericapiserver.go:733] Skipping API node.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.532028    4473 genericapiserver.go:733] Skipping API node.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.532978    4473 handler.go:286] Adding GroupVersion policy v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.532994    4473 genericapiserver.go:733] Skipping API policy/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.550306    4473 handler.go:286] Adding GroupVersion rbac.authorization.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.550336    4473 genericapiserver.go:733] Skipping API rbac.authorization.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.550345    4473 genericapiserver.go:733] Skipping API rbac.authorization.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.550818    4473 handler.go:286] Adding GroupVersion scheduling.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.550836    4473 genericapiserver.go:733] Skipping API scheduling.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.550843    4473 genericapiserver.go:733] Skipping API scheduling.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.552438    4473 handler.go:286] Adding GroupVersion storage.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.552457    4473 genericapiserver.go:733] Skipping API storage.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.552464    4473 genericapiserver.go:733] Skipping API storage.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.553215    4473 handler.go:286] Adding GroupVersion flowcontrol.apiserver.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.553901    4473 handler.go:286] Adding GroupVersion flowcontrol.apiserver.k8s.io v1beta3 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.553912    4473 genericapiserver.go:733] Skipping API flowcontrol.apiserver.k8s.io/v1beta2 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.553917    4473 genericapiserver.go:733] Skipping API flowcontrol.apiserver.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.556311    4473 handler.go:286] Adding GroupVersion apps v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.556332    4473 genericapiserver.go:733] Skipping API apps/v1beta2 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.556338    4473 genericapiserver.go:733] Skipping API apps/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.557677    4473 handler.go:286] Adding GroupVersion admissionregistration.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.557690    4473 genericapiserver.go:733] Skipping API admissionregistration.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.557696    4473 genericapiserver.go:733] Skipping API admissionregistration.k8s.io/v1alpha1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.558163    4473 handler.go:286] Adding GroupVersion events.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.558173    4473 genericapiserver.go:733] Skipping API events.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.560786    4473 handler.go:286] Adding GroupVersion apiregistration.k8s.io v1 to ResourceManager
Sep 27 16:09:28 debk3s k3s[4473]: W0927 16:09:28.560806    4473 genericapiserver.go:733] Skipping API apiregistration.k8s.io/v1beta1 because it has no resources.
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.914866    4473 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.914947    4473 dynamic_serving_content.go:132] "Starting controller" name="serving-cert::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.crt::/var/lib/rancher/k3s/server/tls/serving-kube-apiserver.key"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.914866    4473 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915417    4473 secure_serving.go:213] Serving securely on 127.0.0.1:6444
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915460    4473 tlsconfig.go:240] "Starting DynamicServingCertificateController"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915549    4473 controller.go:80] Starting OpenAPI V3 AggregationController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915577    4473 system_namespaces_controller.go:67] Starting system namespaces controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915590    4473 apf_controller.go:374] Starting API Priority and Fairness config controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915690    4473 cluster_authentication_trust_controller.go:440] Starting cluster_authentication_trust_controller controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915700    4473 shared_informer.go:313] Waiting for caches to sync for cluster_authentication_trust_controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915844    4473 gc_controller.go:78] Starting apiserver lease garbage collector
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915864    4473 aggregator.go:163] waiting for initial CRD sync...
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915942    4473 available_controller.go:423] Starting AvailableConditionController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915952    4473 cache.go:32] Waiting for caches to sync for AvailableConditionController controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.915992    4473 apiservice_controller.go:97] Starting APIServiceRegistrationController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916000    4473 cache.go:32] Waiting for caches to sync for APIServiceRegistrationController controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916016    4473 controller.go:78] Starting OpenAPI AggregationController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916019    4473 crdregistration_controller.go:111] Starting crd-autoregister controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916028    4473 shared_informer.go:313] Waiting for caches to sync for crd-autoregister
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916023    4473 controller.go:116] Starting legacy_token_tracking_controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916047    4473 shared_informer.go:313] Waiting for caches to sync for configmaps
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916067    4473 dynamic_cafile_content.go:157] "Starting controller" name="client-ca-bundle::/var/lib/rancher/k3s/server/tls/client-ca.crt"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916147    4473 dynamic_cafile_content.go:157] "Starting controller" name="request-header::/var/lib/rancher/k3s/server/tls/request-header-ca.crt"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916196    4473 customresource_discovery_controller.go:289] Starting DiscoveryController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916235    4473 controller.go:139] Starting OpenAPI controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916259    4473 controller.go:87] Starting OpenAPI V3 controller
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916278    4473 naming_controller.go:291] Starting NamingConditionController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916295    4473 establishing_controller.go:76] Starting EstablishingController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916316    4473 nonstructuralschema_controller.go:192] Starting NonStructuralSchemaConditionController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916335    4473 apiapproval_controller.go:186] Starting KubernetesAPIApprovalPolicyConformantConditionController
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916353    4473 crd_finalizer.go:266] Starting CRDFinalizer
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.916411    4473 dynamic_serving_content.go:132] "Starting controller" name="aggregator-proxy-cert::/var/lib/rancher/k3s/server/tls/client-auth-proxy.crt::/var/lib/rancher/k3s/server/tls/client-auth-proxy.key"
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.975298    4473 shared_informer.go:320] Caches are synced for node_authorizer
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.980263    4473 shared_informer.go:320] Caches are synced for *generic.policySource[*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicy,*k8s.io/api/admissionregistration/v1.ValidatingAdmissionPolicyBinding,k8s.io/apiserver/pkg/admission/plugin/policy/validating.Validator]
Sep 27 16:09:28 debk3s k3s[4473]: I0927 16:09:28.980304    4473 policy_source.go:224] refreshing policies
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.016501    4473 shared_informer.go:320] Caches are synced for configmaps
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.016724    4473 shared_informer.go:320] Caches are synced for crd-autoregister
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.016533    4473 cache.go:39] Caches are synced for APIServiceRegistrationController controller
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.017249    4473 handler.go:286] Adding GroupVersion k3s.cattle.io v1 to ResourceManager
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.017298    4473 handler.go:286] Adding GroupVersion helm.cattle.io v1 to ResourceManager
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.020092    4473 cache.go:39] Caches are synced for AvailableConditionController controller
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.020617    4473 shared_informer.go:320] Caches are synced for cluster_authentication_trust_controller
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.026775    4473 aggregator.go:165] initial CRD sync complete...
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.026806    4473 autoregister_controller.go:141] Starting autoregister controller
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.026814    4473 cache.go:32] Waiting for caches to sync for autoregister controller
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.026825    4473 cache.go:39] Caches are synced for autoregister controller
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.016672    4473 apf_controller.go:379] Running API Priority and Fairness config worker
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.026970    4473 apf_controller.go:382] Running API Priority and Fairness periodic rebalancing process
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.026996    4473 handler_discovery.go:447] Starting ResourceDiscoveryManager
Sep 27 16:09:29 debk3s k3s[4473]: E0927 16:09:29.033833    4473 controller.go:102] Error removing old endpoints from kubernetes service: no API server IP addresses were listed in storage, refusing to erase all endpoints for the kubernetes Service
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.037018    4473 controller.go:615] quota admission added evaluator for: leases.coordination.k8s.io
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Password verified locally for node debk3s"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="certificate CN=debk3s signed by CN=k3s-server-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:09:29 +0000 UTC"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="certificate CN=system:node:debk3s,O=system:nodes signed by CN=k3s-client-ca@1727453222: notBefore=2024-09-27 16:07:02 +0000 UTC notAfter=2025-09-27 16:09:29 +0000 UTC"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=warning msg="Host resolv.conf includes loopback or multicast nameservers - kubelet will use autogenerated resolv.conf with nameserver 8.8.8.8"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Module overlay was already loaded"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Module nf_conntrack was already loaded"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=warning msg="Failed to load kernel module br_netfilter with modprobe"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=warning msg="Failed to load kernel module iptable_nat with modprobe"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=warning msg="Failed to load kernel module iptable_filter with modprobe"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Set sysctl 'net/bridge/bridge-nf-call-iptables' to 1"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=error msg="Failed to set sysctl: open /proc/sys/net/bridge/bridge-nf-call-iptables: no such file or directory"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Set sysctl 'net/netfilter/nf_conntrack_max' to 131072"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=error msg="Failed to set sysctl: open /proc/sys/net/netfilter/nf_conntrack_max: permission denied"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Logging containerd to /var/lib/rancher/k3s/agent/containerd/containerd.log"
Sep 27 16:09:29 debk3s k3s[4473]: time="2024-09-27T16:09:29Z" level=info msg="Running containerd -c /var/lib/rancher/k3s/agent/etc/containerd/config.toml -a /run/k3s/containerd/containerd.sock --state /run/k3s/containerd --root /var/lib/rancher/k3s/agent/containerd"
Sep 27 16:09:29 debk3s k3s[4473]: I0927 16:09:29.939148    4473 storage_scheduling.go:111] all system priority classes are created successfully or already exist.
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Waiting for cloud-controller-manager privileges to become available"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Kube API server is now running"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="ETCD server is now running"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="k3s is up and running"
Sep 27 16:09:30 debk3s systemd[1]: Started k3s.service - Lightweight Kubernetes.
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Creating k3s-supervisor event broadcaster"
Sep 27 16:09:30 debk3s k3s[4473]: W0927 16:09:30.392541    4473 feature_gate.go:246] Setting GA feature gate CloudDualStackNodeIPs=true. It will be removed in a future release.
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Applying CRD addons.k3s.cattle.io"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Applying CRD etcdsnapshotfiles.k3s.cattle.io"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Applying CRD helmcharts.helm.cattle.io"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Applying CRD helmchartconfigs.helm.cattle.io"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-25.0.3+up25.0.0.tgz"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing static file: /var/lib/rancher/k3s/server/static/charts/traefik-crd-25.0.3+up25.0.0.tgz"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/ccm.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-delegator.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-deployment.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-server-service.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/resource-reader.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/rolebindings.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/runtimes.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/coredns.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/local-storage.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/aggregated-metrics-reader.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/auth-reader.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/metrics-server/metrics-apiservice.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Writing manifest: /var/lib/rancher/k3s/server/manifests/traefik.yaml"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Tunnel server egress proxy mode: agent"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Starting dynamiclistener CN filter node controller"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Starting k3s.cattle.io/v1, Kind=Addon controller"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Creating deploy event broadcaster"
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.612881    4473 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.673108    4473 controller.go:615] quota admission added evaluator for: rolebindings.rbac.authorization.k8s.io
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.675054    4473 event.go:389] "Event occurred" object="kube-system/ccm" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="AppliedManifest" message="Applied manifest at \"/var/lib/rancher/k3s/server/manifests/ccm.yaml\""
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.677590    4473 controller.go:615] quota admission added evaluator for: addons.k3s.cattle.io
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.688314    4473 event.go:389] "Event occurred" object="kube-system/coredns" fieldPath="" kind="Addon" apiVersion="k3s.cattle.io/v1" type="Normal" reason="ApplyingManifest" message="Applying manifest at \"/var/lib/rancher/k3s/server/manifests/coredns.yaml\""
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.711282    4473 serving.go:387] Generated self-signed cert in-memory
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Creating helm-controller event broadcaster"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Starting /v1, Kind=Node controller"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Waiting for control-plane node debk3s startup: nodes \"debk3s\" not found"
Sep 27 16:09:30 debk3s k3s[4473]: time="2024-09-27T16:09:30Z" level=info msg="Cluster dns configmap already exists"
Sep 27 16:09:30 debk3s k3s[4473]: I0927 16:09:30.738226    4473 controller.go:615] quota admission added evaluator for: deployments.apps
kubectl get -A all
E0927 16:48:56.232410   15283 memcache.go:265] couldn't get current server API group list: Get "https://127.0.0.1:6443/api?timeout=32s": dial tcp 127.0.0.1:6443: connect: connection refused
E0927 16:48:56.232616   15283 memcache.go:265] couldn't get current server API group list: Get "https://127.0.0.1:6443/api?timeout=32s": dial tcp 127.0.0.1:6443: connect: connection refused
E0927 16:48:56.233836   15283 memcache.go:265] couldn't get current server API group list: Get "https://127.0.0.1:6443/api?timeout=32s": dial tcp 127.0.0.1:6443: connect: connection refused
E0927 16:48:56.233995   15283 memcache.go:265] couldn't get current server API group list: Get "https://127.0.0.1:6443/api?timeout=32s": dial tcp 127.0.0.1:6443: connect: connection refused
E0927 16:48:56.235238   15283 memcache.go:265] couldn't get current server API group list: Get "https://127.0.0.1:6443/api?timeout=32s": dial tcp 127.0.0.1:6443: connect: connection refused
The connection to the server 127.0.0.1:6443 was refused - did you specify the right host or port?
sudo systemctl status k3s.service
● k3s.service - Lightweight Kubernetes
     Loaded: loaded (/etc/systemd/system/k3s.service; enabled; preset: enabled)
     Active: active (running) since Fri 2024-09-27 16:50:06 UTC; 415ms ago
       Docs: https://k3s.io
    Process: 15591 ExecStartPre=/bin/sh -xc ! /usr/bin/systemctl is-enabled --quiet nm-cloud-setup.service 2>/dev/null (code=exited, status=0/SUCCESS)
    Process: 15593 ExecStartPre=/sbin/modprobe br_netfilter (code=exited, status=0/SUCCESS)
    Process: 15594 ExecStartPre=/sbin/modprobe overlay (code=exited, status=0/SUCCESS)
   Main PID: 15595 (k3s-server)
      Tasks: 4
     Memory: 346.8M
        CPU: 4.807s
     CGroup: /system.slice/k3s.service
             └─15595 "[k3s-server]"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816539   15595 container_manager_linux.go:270] "Creating Container Manager object based on Node Config" nodeConfig={"NodeName":"debk3s","RuntimeCgroupsName":"","SystemCgroupsName":"","KubeletCgroupsName":"","KubeletOOMScoreAdj":-999,"ContainerRuntime":"","CgroupsPerQOS":true,"CgroupRoot":"/","CgroupDriver":"systemd","KubeletRootDir":"/var/lib/kubelet","ProtectKernelDefaults":false,"KubeReservedCgroupName":"","SystemReservedCgroupName":"","ReservedSystemCPUs":{},"EnforceNodeAllocatable":{"pods":{}},"KubeReserved":null,"SystemReserved":null,"HardEvictionThresholds":[{"Signal":"imagefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null},{"Signal":"nodefs.available","Operator":"LessThan","Value":{"Quantity":null,"Percentage":0.05},"GracePeriod":0,"MinReclaim":null}],"QOSReserved":{},"CPUManagerPolicy":"none","CPUManagerPolicyOptions":null,"TopologyManagerScope":"container","CPUManagerReconcilePeriod":10000000000,"ExperimentalMemoryManagerPolicy":"None","ExperimentalMemoryManagerReservedMemory":null,"PodPidsLimit":-1,"EnforceCPULimits":true,"CPUCFSQuotaPeriod":100000000,"TopologyManagerPolicy":"none","TopologyManagerPolicyOptions":null}
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816804   15595 topology_manager.go:138] "Creating topology manager with none policy"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816819   15595 container_manager_linux.go:301] "Creating device plugin manager"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816865   15595 state_mem.go:36] "Initialized new in-memory state store"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816956   15595 kubelet.go:401] "Attempting to sync node with API server"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816970   15595 kubelet.go:302] "Adding static pod path" path="/var/lib/rancher/k3s/agent/pod-manifests"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.816994   15595 kubelet.go:313] "Adding apiserver pod source"
Sep 27 16:50:06 debk3s k3s[15595]: I0927 16:50:06.817007   15595 apiserver.go:42] "Waiting for node sync before watching apiserver pods"
Sep 27 16:50:06 debk3s k3s[15595]: Error: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory
Sep 27 16:50:06 debk3s k3s[15595]: time="2024-09-27T16:50:06Z" level=error msg="kubelet exited: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory"
What is the correct way to do this?
Thank you.
This page has the requirements for K3S, Requirements | K3s. If you do not use the special networking, then it should install fine in both system containers and virtual machines. In the case of virtual machines, you need to specify the amount of cores, RAM and disk space as the defaults are not enough for K3s.
This page, Configuration Options | K3s, talks about the installation/configuration of K3S. I do not see your installation command in the list of the documentation.
When I use incus top, I can see that the K3S are using too much CPU time. The system logs in the containers show lines like Error: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory. If you do not find any reference in the documentation that run K3S in a container, I suggest to use an Incus VM instead.
It was installed without any problems on Qemu/KVM.
There were no problems with the requirements and installation. The only problem was that it had to be a container instead of a VM. Thank you, the problem is solved.
Hi
Could you tell if you could resolve the issue with Error: failed to run Kubelet: failed to create kubelet: open /dev/kmsg: no such file or directory? I’m running incus in WSL2 and trying to launch k3s cluster inside incus containers but with no success at the moment
Within Incus, I installed it on a virtual machine, not a container.
Ok, thanks.
I assume it’s not possible to run k3s in containers. I found some old topics with the same problem on lxc with no working solution.
Probably vms is the only option besides bare metal.
Here’s a solution to running k3s in systemd-nspawn, so, I guess a similar approach would work with LXC
I don’t know wht there is no /dev/kmsg inside the container. But I’ve found the solution.
We can just mount host /dev/kmsg with
incus config device add <container_name> kmsg unix-char path=/dev/kmsg
Or even simpler - create a symlink to /dev/console
ln -s /dev/console /dev/kmsg
Both ways does the trick.
Here are the steps I followed to install k3s on 6 Incus containers:
for i in debian13-k3s-{1..6}; do  incus launch images:debian/13 $i ; done
for i in debian13-k3s-{1..6}; do  incus exec $i -- apt -y install curl iptables ; done
for i in debian13-k3s-{1..6}; do  incus config device add $i kmsg unix-char path=/dev/kmsg; done
for i in debian13-k3s-{1..6}; do  incus config device add $i loop0 unix-block path=/dev/loop0; done
The last command stops a repeated warning in the log about not being able to find /dev/loop0: your installation may use a different loop device.
I designated debian13-k3s-1 as the server; the others are agents.
For the server:
incus exec debian13-k3s-1 -- /bin/bash
curl -sfL https://get.k3s.io | INSTALL_K3S_EXEC="--kubelet-arg feature-gates=KubeletInUserNamespace=true --token 12345" sh -s -
exit
For each agent:
incus exec debian13-k3s-2 -- /bin/bash
curl -sfL https://get.k3s.io | INSTALL_K3S_EXEC="agent --kubelet-arg feature-gates=KubeletInUserNamespace=true" K3S_URL=https://debian13-k3s-1:6443 K3S_TOKEN=12345 sh -
exit
Without the --kubelet-arg option, k3s will fail to start.
Repeat the above 3 commands for debian13-k3s-3 through debian13-k3s-6
I copied /etc/rancher/k3s/k3s.yaml from the server to the host and changed the server IP address from 127.0.0.1 to IP address of the server, and am currently working through the kubernetes tutorial.
The following error appears in the log roughly every 5 minutes:
alex14641 [~] $ incus exec debian13-k3s-5 -- systemctl status k3s-agent | tail -1
Mar 30 17:23:13 debian13-k3s-5 k3s[195]: E0330 17:23:13.710449     195 container_manager_linux.go:511] "Failed to ensure process in container with oom score" err="failed to apply oom score -999 to PID 195: write /proc/195/oom_score_adj: permission denied"
This can be fixed by running the following command on the host as root:
for i in `pgrep -f '/usr/local/bin/k3s (server|agent)'`; do echo -999 > /proc/$i/oom_score_adj; done
