Run openwrt inside lxd
Hi
I’m trying to run openwrt inside lxd.
There has been work made here:
https://github.com/melato/openwrt-lxd
It almost works.
The problem is that there are missing devices in /dev, which is empty.
The lxd documentation is not clear. It says it creates a /dev empty tmpfs then it configures several devices, including zero, random, full, etc…
the problem is that the container has nothing in /dev except pts and shm
How come /dev is empty? Isn’t it supposed to be created by lxc?
Another problem I have, is that I tried to add some lines into the container configuration. It works once, and when I stop the container, the configuration is reset. Is it normal?
Here is the configuration I have:
  image.architecture: x86_64
  image.description: openwrt 17.01.4 x86_64 (dhcp) (20180329_21:23)
  image.name: openwrt-17.01.4-x86_64-dhcp-20180329_21:23
  image.os: openwrt
  image.release: 17.01.4
  image.variant: dhcp
  security.privileged: "true"
  volatile.base_image: c88d4b2b56e0241c7f64dbcd995ff0cff2aabe9162360b11199d8b564a8f2ee5
  volatile.eth0.hwaddr: 00:16:3e:af:cd:5c
  volatile.idmap.base: "0"
  volatile.idmap.next: '[]'
devices: {}
thanks
LXD will indeed setup /dev for you, the fact that it’s empty suggests that your image either over-mounted it with another layer of tmpfs/devtmpfs, or somehow cleaned it up at boot time, possibly hoping to re-populate it cleanly, only to fail because it’s inside a container.
Thanks for your response.
it seems indeed that there are 2 mounts on /dev :
# mount
tank/lxd/containers/openwrt on / type zfs (rw,relatime,xattr,noacl)
none on /dev type tmpfs (rw,relatime,size=492k,mode=755)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
proc on /proc/sys/net type proc (rw,nosuid,nodev,noexec,relatime)
proc on /proc/sys type proc (ro,nosuid,nodev,noexec,relatime)
proc on /proc/sysrq-trigger type proc (ro,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
sysfs on /sys/devices/virtual/net type sysfs (rw,relatime)
sysfs on /sys/devices/virtual/net type sysfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
udev on /dev/fuse type devtmpfs (rw,nosuid,relatime,size=4032220k,nr_inodes=1008055,mode=755)
udev on /dev/net/tun type devtmpfs (rw,nosuid,relatime,size=4032220k,nr_inodes=1008055,mode=755)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/lxd type tmpfs (rw,relatime,size=100k,mode=755)
tmpfs on /dev/.lxd-mounts type tmpfs (rw,relatime,size=100k,mode=711)
lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=666,max=1024)
devpts on /dev/ptmx type devpts (rw,relatime,gid=5,mode=620,ptmxmode=666,max=1024)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,nosuid,relatime,size=512k,mode=755)
looks like it is /sbin/init that did this mount. For some reason, it can’t polpulate it.
When I do the mknods by hand, and launch /sbin/init from the shell, everything works.
Would you know how I could prevent this mount? or at least umount the second layer?
umount -l /dev should let you remove that second layer.
I just found out that openwrt doesn’t start with /sbin/init (which is busybox init), but with /etc/preinit.
Now I can’t find where is the lxc.init_cmd configuration documented.
with lxc launch, I have error messages.
error: Unknown configuration key: lxc.init.cmd
error: Unknown configuration key: lxc.init_cmd
how is lxc low level configuration managed from lxd? and where is it documented?
On liblxc version starting from 2.1 it’s called lxc.init.cmd and you can set it with:
lxc config set <container-name> raw.lxc lxc.init.cmd=/sbin/init
I have published my own scripts which builds lxd images from openwrt rootfs tar balls. The images can be used in unprivileged containers which I think is an advantage.
The scripts build a patched version of procd which doesn’t remount /dev and other file systems to allow it to run in unprivileged mode.
Two architectures are supported, x86_64 and i686. Currently 17.04.1 is supported. Snapshot is not fully supported since an older version of procd is used in the created image.
Usage: ./build.sh [-a|--arch <x86_64|i686>] [-v|--version <version>] [-p|--packages <packages>] [-f|--files] [--help]
https://github.com/mikma/lxd-openwrt
Cool, I’m sure it’ll be quite useful to some of our users!
