Hi, I’m new to lxc and incus. I installed incus on debian bookworm and also the incus web ui - and it works great; Great project! During installation I chose incus to have a managed bridge from the dedicated servers enps0f0 to the eth0 bridge provided by incus.
I purchased an additional ipv4 (172.x.x.x )(necessary) from the server provider, created a virtual machine on debian bookworm, instlled ssh, etc, and setup a network forward from the ipv4 to the ipv4 that incus chose to assign to the VM (10.x.x.x). Now I can ssh in to the vm.
I need to install a hosting system which requires an ipv4 and which installs via a bash/shell script which reboots the vm many times as it moves the VM to devuan daedalus (thus removing systemd in the process) - and the script fails at some point leaving no openssh-server operational on the vm, so I can no longer ssh in to manage it.
My questions are:
can an incus vm run without systemd ? (it seems like incus-agent needs systemd to run, and the vm needs incus-agent to run properly and to be managed.). If this is the problem would you suggest this fix:
incus-init-scripts/etc/init.d/incus-containers at main · MoltenArmor/incus-init-scripts · GitHub -
the script which I am trying to get working on the vm normally requires /etc/network/interfaces to have eth0 set for ipv4 (inet). On the vm there is no /etc/network/, no /etc/netplan/ etc … so, is there a way to “spoof” this required “eth0” for networking? (It seems as if the incus bridge is on eth0!). If I created a /etc/network/interfaces file on the vm and put eth0 inet static ,etc. - would that conflict with what incus is doing, or would that be OK?
Here are the results of those commands run on the main dedicated server on which I installed incus (not on the vm):
root@server1:~# netstat -lnp | grep 67
udp 0 0 0.0.0.0:67 0.0.0.0:* 8680/dnsmasq
unix 2 [ ACC ] STREAM LISTENING 19635 1676/python3 /var/run/fail2ban/fail2ban.sock
unix 2 [ ACC ] STREAM LISTENING 20742 2676/[lxc monitor] @/var/lib/incus/containers/container1/command
root@server1:~# netstat -lnp | grep 53
tcp 0 0 10.37.153.1:53 0.0.0.0:* LISTEN 8680/dnsmasq
tcp6 0 0 fe80::216:3eff:fe96::53 :::* LISTEN 8680/dnsmasq
tcp6 0 0 fd42:ec31:3b10:7918::53 :::* LISTEN 8680/dnsmasq
udp 0 0 10.37.153.1:53 0.0.0.0:* 8680/dnsmasq
udp 0 0 main.server.ip-v4:123 0.0.0.0:* 1706/ntpd
udp 0 0 10.37.153.1:123 0.0.0.0:* 1706/ntpd
udp6 0 0 fd42:ec31:3b10:7918::53 :::* 8680/dnsmasq
udp6 0 0 fe80::216:3eff:fe96::53 :::* 8680/dnsmasq
root@server1:~#
Are there any obvious problems here? Thanks for your help/advice.
“incus config show” on the dedicated running the master incus returns:
root@server1:~# incus config show
acme.agree_tos: “true”
acme.email: server1@example.com
core.https_address: ‘[::]:8443’
When try to use the Incus Web UI terminal for the VM when the VM fails to allow reconnection in ssh, I get this error: Error
The connection was closed abnormally, e.g., without sending or receiving a Close control frame
Best,
Ed
