I am trying to run Bind9 in a container, but when I try to setup port forwarding it says port is in use, so I edited /etc/systemd/resolved.conf to look like this
From within the instance, i can do nslookup mydomain.ai 10.0.0.20 and it works, if I try to do that remotely to the public IP address of the LXD server. Note. port forwarding is setup for port 53. So i am thinking I am still getting a conflict.
$ nslookup mydomain.ai 123.123.123.123
;; connection timed out; no servers could be reached`
Hmm, I’d probably use tcpdump to see what’s going on, make sure the traffic actually hits the container and if so, with what address, port and protocol.
If run this on host nslookup mydomain.ai 10.0.0.20 with private IP, it goes to container.
tcpdump -i eth0
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
16:56:24.320070 IP _gateway.58182 > dns.lxd.domain: 8629+ A? mydomain.com. (34)
16:56:24.320229 IP dns.lxd.domain > _gateway.58182: 8629* 1/0/0 A 65.21.175.111 (50)
16:56:24.320809 IP _gateway.45070 > dns.lxd.domain: 30429+ AAAA? mydomain.com. (34)
16:56:24.320885 IP dns.lxd.domain > _gateway.45070: 30429* 0/1/0 (80)
16:56:24.321216 IP dns.lxd.47380 > _gateway.domain: 37560+ [1au] PTR? 20.0.0.10.in-addr.arpa. (51)
16:56:24.321370 IP _gateway.domain > dns.lxd.47380: 37560* 1/0/1 PTR dns.lxd. (72)
16:56:24.321778 IP dns.lxd.49843 > _gateway.domain: 8092+ [1au] PTR? 1.0.0.10.in-addr.arpa. (50)
16:56:24.329301 IP _gateway.domain > dns.lxd.49843: 8092 NXDomain 0/0/1 (50)
16:56:24.329405 IP dns.lxd.49843 > _gateway.domain: 8092+ PTR? 1.0.0.10.in-addr.arpa. (39)
16:56:24.337940 IP _gateway.domain > dns.lxd.49843: 8092 NXDomain 0/0/0 (39)
16:56:29.487757 ARP, Request who-has _gateway tell dns.lxd, length 28
16:56:29.487758 ARP, Request who-has dns.lxd tell _gateway, length 28
16:56:29.487802 ARP, Reply dns.lxd is-at 00:16:3e:d0:88:de (oui Unknown), length 28
16:56:29.487810 ARP, Reply _gateway is-at 00:16:3e:13:5d:ce (oui Unknown), length 28
If i send the same command but with the public IP from host or any other computer, nothing.
On the host, i undid the configuration what I did at the start so it uses systemd-resolve again. If i run this command to see ports 53, but i am not getting any errors, I added the proxy fine.
"Error: Error occurred when starting proxy device: Error: Failed to listen on 0.0.0.0:53: listen tcp 0.0.0.0:53: bind: address already in use
Try lxc info --show-log dns for more info
Thanks Tom, that is what i started out with, but because I could not get it working I reverted the settings back, now i learnt how to use TCPdump, maybe its worth another go. Thanks for taking the time out to help.
Retested, same thing. i have to set a static IP address and nat proxy for the container to start.
The systemd-resolve lines have disappeared but still getting a conflict I think.
Again seems to work fine when using the private network address, just the problem when using the public address, which is suppose to forward it to container, but nothing reaches it (i assume because TCP dump showed nothing at all).
Interesting re macvlan, i cant use macvlan just yet as i configured a bridge to use a different subnet of IPv4 addresses, and this time round macvlan doesnt work.
First thing I do is ping google.com to make sure it’s working.
I am going to reformat the server again (#11) and install debian to try and get a routed network setup, it took me days to get bridged working with the extra subnet.
Can somebody just confirm if I can run bind9 with port 53 inside a container or not using the standard lxd bridge, been stuck on this for two days now. thanks. All other stuff proxy ports work out of the box,.
I’ve been running production DNS servers inside of LXD containers for years, it’s never been a problem. Recently resolved indeed causes conflicts out of the box so the DNS server fails to start until you bind it to a specific interface/address but it otherwise all works just fine.
What do you mean exactly "bind it to a specific interface/address " are you refering the BIND server configuration or the port forwarding , which i already tried both.
I see, so nslookup worked with the 10.x.x.x. address because that was UDP and the port forward did not work because of the UDP, that makes sense. Thank you very much, I will try again.
