Running dpdk-testpmd in an LXC container
Here’s the translation of your message:
I want to run DPDK in an LXC container, but unfortunately, it doesn’t detect the physical DPDK interfaces.
I have an Intel ICE network card, and I want it to be detected in the LXC container so I can run testpmd.
I was able to do this in a Docker container, but not in LXC.
The DPDK driver I am using is vfio-pci.
Has anyone managed to set this up and can help?
The error I get when running dpdk-testpmd in LXC:
root@dpdk-c3-1:~# dpdk-testpmd
EAL: Detected CPU lcores: 44
EAL: Detected NUMA nodes: 2
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: No available 1048576 kB hugepages reported
EAL: Cannot open VFIO container /dev/vfio/vfio, error 2 (No such file or directory)
EAL: VFIO support could not be initialized
EAL: Requested device 0000:82:00.1 cannot be used
TELEMETRY: No legacy callbacks, legacy socket not created
testpmd: No probed ethernet devices
testpmd: create a new mbuf pool <mb_pool_0>: n=491456, size=2176, socket=0
testpmd: preferred mempool ops selected: ring_mp_mc
testpmd: create a new mbuf pool <mb_pool_1>: n=491456, size=2176, socket=1
Done
No commandline core given, start packet forwarding
io packet forwarding - ports=0 - cores=0 - streams=0 - NUMA support enabled, MP allocation mode: native
  io packet forwarding packets/burst=32
  nb forwarding cores=1 - nb forwarding ports=0
Press enter to exit
On the host, it works correctly:
root@jammy:~# dpdk-testpmd
EAL: VFIO support initialized
EAL: Using IOMMU type 8 (No-IOMMU)
EAL: Probe PCI driver: net_ice (8086:1592) device: 0000:82:00.1 (socket 1)
ice_load_pkg_type(): Active package is: 1.3.36.0, ICE OS Default Package (single VLAN mode)
Warning! port-topology=paired and odd forward ports number, the last port will pair with itself.
Configuring Port 0 (socket 1)
ice_set_rx_function(): Using AVX2 Vector Rx (port 0).
Port 0: B4:96:91:91:7B:D9
Checking link statuses...
Done
io packet forwarding - ports=1 - cores=1 - streams=1 - NUMA support enabled, MP allocation mode: native
Logical Core 1 (socket 0) forwards packets on 1 streams:
  RX P=0/Q=0 (socket 1) -> TX P=0/Q=0 (socket 1) peer=02:00:00:00:00:00
  nb forwarding cores=1 - nb forwarding ports=1
  port 0: RX queue number: 1 Tx queue number: 1
    Rx offloads=0x0 Tx offloads=0x10000
    RX queue: 0
      RX desc=1024 - RX free threshold=32
      RX threshold registers: pthresh=0 hthresh=0  wthresh=0
      RX Offloads=0x0
    TX queue: 0
      TX desc=1024 - TX free threshold=32
      TX threshold registers: pthresh=32 hthresh=0  wthresh=0
      TX offloads=0x10000 - TX RS bit threshold=32
Press enter to exit
After running the command lxc config device add dpdk-c3-1 dev-vfio disk source=/dev/vfio path=/dev/vfio,
the VFIO error changes to the following:
EAL: Cannot open VFIO container /dev/vfio/vfio, error 1 (Operation not permitted)
The settings in /etc/lxc/default.conf are as follows:
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:xx:xx:xx
lxc.privileged = 1
lxc.apparmor.profile = unconfined
lxc.cgroup.devices.allow = c 10:196 rwm
lxc.cgroup.devices.allow = c 226:* rwm
# Mount /dev/vfio
lxc.mount.entry = /dev/vfio dev/vfio none bind,optional,create=dir 0 0
# Mount /sys
lxc.mount.entry = /sys sys none rw,bind 0 0
lxc.mount.entry = /sys/bus/pci/drivers/ice /sys/bus/pci/drivers/ice none bind,optional,create=dir
Is there anyone who can help?
Hi.
I didn’t think so. This forum does not provide support for LXD.
You might want to consider migrating your LXD projects to Incus.
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
