I’ve recently migrated from Linux Mint to Manjaro.
In Mint, all of my containers were working flawlessly.
Since my development workflow was established, I wanted to migrate to a
rolling release distro. Also because of Arch being so involved with it’s installation,
I decided to go with Manjaro.
LXD Version: 4.1
Installed with Snap
What works…
I’m able to launch containers, and share folders between host and container.
My permission seems to be correct, since I’m able to write files to the shared folders.
Giving my containers access to the host Xserver however has been a challenge…
After reading through the “GUI Apps in LXD (Archlinux Host)” thread I’ve learned two possible solutions, one to disable the access control on my XServer with the xhost command, or to include a correctly configured .Xauthority file in my container.
I’m able to successfully do either of them, however things are still not working quite right.
Example:
$ xclock
Warning: Unable to load any usable ISO8859 font
Warning: Missing charsets in String to FontSet conversion
AND
$ glxgears
libGL error: MESA-LOADER: failed to retrieve device information
libGL error: Version 4 or later of flush extension not found
libGL error: failed to load driver: i915
libGL error: failed to open drm device: No such file or directory
libGL error: failed to load driver: iris
6212 frames in 5.0 seconds = 1242.326 FPS
I did not have these issues on Mint… I’m a little puzzled on why it’s so different with Manjaro…
Is there a better way to accomplish this?
This is the profile I’m using for trouble shooting.
nvidia.runtime: "true"
nvidia.driver.capabilities: graphics, compute, display, utility, video
environment.DISPLAY: :0
raw.idmap: |
uid 1000 1000
gid 1000 1000
security.idmap.isolated: "true"
user.user-data: |
#cloud-config
package_upgrade: true
packages:
- x11-apps
- mesa-utils
description: Enables X forwarding to host
pool: zfs-pool
gpu:
pci: "0000:01:00.0"
type: gpu
nictype: bridged
parent: lxdbr0
X0:
bind: container
connect: unix:@/tmp/.X11-unix/X0
listen: unix:@/tmp/.X11-unix/X0
security.gid: "1000"
security.uid: "1000"
type: proxy
Thank you for your time.
