Recently I’ve been doing an experiment to check the effectiveness of KSM(Kernel Same-page Merging) on containers
I followed through the instructions of this tutorial
I successfully built the ksm_preload tool and enabling it in the /etc/rc.local (I’m using ubuntu container) in the container
and then I tried $ sudo ./ksm-wrapper lxc start container1 to launch multiple containers and check /sys/kernel/mm/ksm, but only full_scans has increased, the other remained unchange.
there’s a guy claimed in this thread he’s successfully done that but the result isn’t quite satisfying.
so I’m wondering if there’s any step I did wrong or missed ,
if anyone had experience doing this before please let me know
You’d probably need to run the LXD daemon under your ksm_wrapper rather than the client lxc tool as that client tool just talks over LXD’s network API and doesn’t spawn the container itself.
thanks I’ll try it.
If I’m gonna restart LXD daemon should I use /etc/init.d/lxd restart or service stop/start lxd ?
it seems the first one only stop lxd.service and I can still use lxc command(maybe via lxd.socket).
or there’s a better way to start the daemon ?
Probably best to stop all the systemd units and then manually run “lxd --debug --group lxd” in a terminal, you can wrap that one with your ksm script.
Trying to wrap /etc/init.d/lxd with your script won’t work because just like “lxc”, the init scripts call “systemctl” which then talks to systemd over dbus, so the script isn’t itself the one spawning the process.
/etc/init.d/lxd will talk to the systemctl command which then talks over DBUS to the systemd daemon that then spawns the processes for you.
Your wrapper uses LD_PRELOAD which means that only its children can be affected by whatever it does. As in this case, LXD will be a child of systemd (pid1) not of systemctl, the wrapper will be useless.
I am the “guy” mentioned in the OP thread above. As @hahattan demonstrated above, the memory savings using KSM are not significant. From my memory of the original test, I ran a bunch of use cases and ended up saving about 150MB of RAM over 50 containers. Given the amount of work required to get KSM running and the modifications required for containers, I realized my efforts were better spent in other areas of system tuning.
