Hi there!
I am more or less new to lxd/lxc and facing the follwing problem:
I installed snapd and tried to install the vlc snap.
after installation I tried to run the snap but got some permission error:
vlc --help
cannot perform operation: mount --make-rshared /snap: Permission denied
Any hints how to solve this, so that i can run snaps inside the lxd container?
Thx Benjamin.
turtle0x1
(Turtle0x1)
September 13, 2022, 11:19pm
2
I got it to work but its hacky as anything, hopefully someone can come along and correct with better instructions;
Grab the x11 profile from simos blog
Edit the x11 profile and change “PASocket1” listen to /home/ubuntu/pulse-native
lxc launch ubuntu: vlc -p default -p x11
lxc exec snap vlc
snap install vlc
su ubuntu
vlc
I didn’t test audio.
The apt version of VLC didn’t work any better (but the likes of firefox still worked fine with X11 profile).
In the case of VLC, if your using the SNAP, you might be better of just installing it on the host.
Okay thank for the reply!
Hmm I am already running a similar profile (Kodi is already working audio- and videowise)
Here is the config of the container:
lxc config show --expanded kodicont1
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20220118)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20220118"
image.type: squashfs
image.version: "20.04"
limits.cpu: "8"
limits.memory: 4GB
raw.lxc: lxc.mount.auto=proc:rw sys:rw cgroup:rw:force
security.privileged: "true"
volatile.base_image: 44650bc10c092105a5695a240307f518b9f5a6f3a6c8094f340d663331191e48
volatile.eth0.host_name: vethab552b6f
volatile.eth0.hwaddr: 00:16:3e:d5:e2:50
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: fa8ea563-cba4-4dbf-bb38-8733b5e3849b
allusb:
mode: "666"
type: usb
controlC0:
gid: "29"
path: /dev/snd/controlC0
type: unix-char
uid: "0"
controlC1:
gid: "29"
path: /dev/snd/controlC1
type: unix-char
uid: "0"
network: lxdbr0
event0:
major: "13"
minor: "64"
mode: "0666"
path: /dev/input/event0
required: "false"
source: /dev/input/event0
type: unix-char
event1:
major: "13"
minor: "65"
mode: "0666"
path: /dev/input/event1
required: "false"
source: /dev/input/event1
type: unix-char
event2:
major: "13"
minor: "66"
mode: "0666"
path: /dev/input/event2
required: "false"
source: /dev/input/event2
type: unix-char
event3:
major: "13"
minor: "67"
mode: "0666"
path: /dev/input/event3
required: "false"
source: /dev/input/event3
type: unix-char
event4:
major: "13"
minor: "68"
mode: "0666"
path: /dev/input/event4
required: "false"
source: /dev/input/event4
type: unix-char
event5:
major: "13"
minor: "69"
mode: "0666"
path: /dev/input/event5
required: "false"
source: /dev/input/event5
type: unix-char
event6:
major: "13"
minor: "70"
mode: "0666"
path: /dev/input/event6
required: "false"
source: /dev/input/event6
type: unix-char
event7:
major: "13"
minor: "71"
mode: "0666"
path: /dev/input/event7
required: "false"
source: /dev/input/event7
type: unix-char
event8:
major: "13"
minor: "72"
mode: "0666"
path: /dev/input/event8
required: "false"
source: /dev/input/event8
type: unix-char
event9:
major: "13"
minor: "73"
mode: "0666"
path: /dev/input/event9
required: "false"
source: /dev/input/event9
type: unix-char
event10:
major: "13"
minor: "74"
mode: "0666"
path: /dev/input/event10
required: "false"
source: /dev/input/event10
type: unix-char
event11:
major: "13"
minor: "75"
mode: "0666"
path: /dev/input/event11
required: "false"
source: /dev/input/event11
type: unix-char
event12:
major: "13"
minor: "76"
mode: "0666"
path: /dev/input/event12
required: "false"
source: /dev/input/event12
type: unix-char
event13:
major: "13"
minor: "77"
mode: "0666"
path: /dev/input/event13
required: "false"
source: /dev/input/event13
type: unix-char
event14:
major: "13"
minor: "78"
mode: "0666"
path: /dev/input/event14
required: "false"
source: /dev/input/event14
type: unix-char
event15:
major: "13"
minor: "79"
mode: "0666"
path: /dev/input/event15
required: "false"
source: /dev/input/event15
type: unix-char
event16:
major: "13"
minor: "80"
mode: "0666"
path: /dev/input/event16
required: "false"
source: /dev/input/event16
type: unix-char
event17:
major: "13"
minor: "81"
mode: "0666"
path: /dev/input/event17
required: "false"
source: /dev/input/event17
type: unix-char
event18:
major: "13"
minor: "82"
mode: "0666"
path: /dev/input/event18
required: "false"
source: /dev/input/event18
type: unix-char
event19:
major: "13"
minor: "83"
mode: "0666"
path: /dev/input/event19
required: "false"
source: /dev/input/event19
type: unix-char
event20:
major: "13"
minor: "84"
mode: "0666"
path: /dev/input/event20
required: "false"
source: /dev/input/event20
type: unix-char
gpu:
type: gpu
hdiraw0:
mode: "0666"
path: /dev/hdiraw0
required: "false"
source: /dev/hdiraw0
type: unix-char
hdiraw1:
mode: "0666"
path: /dev/hdiraw1
required: "false"
type: unix-char
hwC0D0:
gid: "29"
path: /dev/snd/hwC0D0
type: unix-char
uid: "0"
hwC0D2:
gid: "29"
path: /dev/snd/hwC0D2
type: unix-char
uid: "0"
inp2:
gid: "107"
type: unix-char
uid: "0"
inp5:
gid: "107"
type: unix-char
uid: "0"
inp6:
gid: "107"
type: unix-char
uid: "0"
inp7:
gid: "107"
type: unix-char
uid: "0"
inp11:
gid: "107"
path: /dev/input/mice
type: unix-char
uid: "0"
inp16:
gid: "107"
type: unix-char
uid: "0"
inpa:
gid: "107"
type: unix-char
uid: "0"
inpb:
gid: "107"
type: unix-char
uid: "0"
keyboard:
productid: "8000"
type: usb
vendorid: 0c40
mediadir:
path: /home/ubuntu/media/
source: /media/media/
mice:
mode: "0666"
required: "false"
source: /dev/input/mice
type: unix-char
mouse:
mode: "0666"
path: /dev/input/mouse0
required: "false"
source: /dev/input/mouse0
type: unix-char
myport8080:
connect: tcp:127.0.0.1:8080
listen: tcp:0.0.0.0:8080
type: proxy
pcmC0D0c:
gid: "29"
path: /dev/snd/pcmC0D0c
type: unix-char
uid: "0"
pcmC0D0p:
gid: "29"
path: /dev/snd/pcmC0D0p
type: unix-char
uid: "0"
pcmC0D3p:
gid: "29"
path: /dev/snd/pcmC0D3p
type: unix-char
uid: "0"
pcmC0D7p:
gid: "29"
path: /dev/snd/pcmC0D7p
type: unix-char
uid: "0"
pcmC0D8p:
gid: "29"
path: /dev/snd/pcmC0D8p
type: unix-char
uid: "0"
pcmC0D9p:
gid: "29"
path: /dev/snd/pcmC0D9p
type: unix-char
uid: "0"
pcmC0D10p:
gid: "29"
path: /dev/snd/pcmC0D10p
type: unix-char
uid: "0"
pcmC1D0c:
gid: "29"
path: /dev/snd/pcmC1D0c
type: unix-char
uid: "0"
pcmC1D0p:
gid: "29"
path: /dev/snd/pcmC1D0p
type: unix-char
uid: "0"
rcv:
gid: "126"
mode: "0660"
productid: "8000"
type: unix-hotplug
uid: "0"
vendorid: 0c40
pool: lxcpool
seq:
gid: "29"
path: /dev/snd/seq
type: unix-char
uid: "0"
snd1:
gid: "29"
type: unix-char
uid: "0"
snd2:
gid: "29"
type: unix-char
uid: "0"
snd3:
gid: "29"
type: unix-char
uid: "0"
snd4:
gid: "29"
type: unix-char
uid: "0"
snd5:
gid: "29"
type: unix-char
uid: "0"
snd7:
gid: "29"
type: unix-char
uid: "0"
snd9:
gid: "29"
type: unix-char
uid: "0"
snd11:
gid: "29"
type: unix-char
uid: "0"
snd12:
gid: "29"
type: unix-char
uid: "0"
snd13:
gid: "29"
type: unix-char
uid: "0"
snd14:
gid: "29"
path: /dev/snd/seq
type: unix-char
uid: "0"
snd15:
gid: "29"
path: /dev/snd/timer
type: unix-char
uid: "0"
timer:
gid: "29"
type: unix-char
uid: "0"
tty7:
gid: "5"
mode: "620"
path: /dev/tty7
source: /dev/tty7
type: unix-char
uid: "0"
udev_data:
path: /home/ubuntu/udev/data
source: /run/udev/data
- cpu4-memory4
Thing is that all snaps complain about the permissions…And I need to install also other snaps where there is no apt installation available…
