Had a question about running Tailscale in LXD VMs. I see the following piece of advice on the tailscale website - https://tailscale.com/kb/1130/lxc-unprivileged/
Had a couple of questions about this
a. Do I still need to do “lxc.cgroup2.devices.allow: c 10:200 rwm” and “lxc.mount.entry: /dev/net/tun dev/net/tun none bind,create=file” if I am running an LXD VM as opposed to a container?
b. All the advice I see online is in the proxmox context and asks me to modify /etc/pve/lxc/112.conf. I am using lxd directly (via its api). What should I be doing to apply the above configuation, which part needs to be on the host and which part needs to be in the guest LXD vm?
