(S3) storage bucket, add valid cert?
Hi, how does one add valid ssl certs to incus(minio)? Generally, I don’t seem to be able to find much info around storage buckets feature of incus.
When serving the S3 API, Incus uses the same certificate that it does for its own API.
So you can either feed that certificate directly to your clients (you can get it with incus info) or you can configure your server or cluster to use a valid SSL certificate instead.
