I had to ctrl-c
a lxc export container-name
command because I didn’t du
my host disk before starting it, and it was gonna fill it entirely. Now I wonder if there are some remaining files from this operating that should be removed manually.
What is the safe way to do this?
I am not very sure that rm /var/snap/lxd/common/lxd/backups/container-name/backup0
would be the way to go but maybe it would be fine. No backups had been operated previously, so I guess it is the corresponding file.
I use a snap
install on Debian Stretch.
Thanks for any help, I am learning.
