I’ve a problem with a sandboxed systemd service
[Unit]
After=network.target
Description=gitea
[Service]
Environment="GITEA_WORK_DIR=/var/lib/gitea"
Environment="HOME=/var/lib/gitea"
Environment="LOCALE_ARCHIVE=/nix/store/jbyaw0r48gxslxczwnjw5371rqj03gn8-glibc-locales-2.30/lib/locale/locale-archive"
Environment="PATH=/nix/store/404wfnlg9dvlzphd955zlqfclsaa31aj-gitea-1.11.8-bin/bin:/nix/store/xp5fj0915bkd0yidns2bkg8n7m9nfp8h-git-2.25.4/bin:/nix/store/x0jla3hpxrwz76hy9yckg1iyc9hns81k-coreutils-8.31/bin:/nix/store/97vambzyvpvrd9wgrrw7i7svi0s8vny5-findutils-4.7.0/bin:/nix/store/b0vjq4r4sp9z4l2gbkc5dyyw5qfgyi3r-gnugrep-3.4/bin:/nix/store/p34p7ysy84579lndk7rbrz6zsfr03y71-gnused-4.8/bin:/nix/store/vac1gmzh1xmk3s7w9pbjvirxqsg1npn0-systemd-243.7/bin:/nix/store/404wfnlg9dvlzphd955zlqfclsaa31aj-gitea-1.11.8-bin/sbin:/nix/store/xp5fj0915bkd0yidns2bkg8n7m9nfp8h-git-2.25.4/sbin:/nix/store/x0jla3hpxrwz76hy9yckg1iyc9hns81k-coreutils-8.31/sbin:/nix/store/97vambzyvpvrd9wgrrw7i7svi0s8vny5-findutils-4.7.0/sbin:/nix/store/b0vjq4r4sp9z4l2gbkc5dyyw5qfgyi3r-gnugrep-3.4/sbin:/nix/store/p34p7ysy84579lndk7rbrz6zsfr03y71-gnused-4.8/sbin:/nix/store/vac1gmzh1xmk3s7w9pbjvirxqsg1npn0-systemd-243.7/sbin"
Environment="TZDIR=/nix/store/8cz89zavyrm2bdrgkx4l66s5c7nx12dr-tzdata-2019c/share/zoneinfo"
Environment="USER=gitea"
CapabilityBoundingSet=
ExecStart=/nix/store/404wfnlg9dvlzphd955zlqfclsaa31aj-gitea-1.11.8-bin/bin/gitea web
ExecStartPre=/nix/store/4225kh8v54fdymwcmm6hzjy90m7q2kzf-unit-script-gitea-pre-start
Group=gitea
LockPersonality=true
MemoryDenyWriteExecute=true
NoNewPrivileges=true
PrivateDevices=true
PrivateMounts=true
PrivateUsers=true
ProtectControlGroups=true
ProtectHome=true
ProtectKernelModules=true
ProtectKernelTunables=true
ReadWritePaths=/var/lib/gitea
Restart=always
RestrictAddressFamilies=AF_UNIX AF_INET AF_INET6
RestrictRealtime=true
SystemCallArchitectures=native
SystemCallFilter=~@clock @cpu-emulation @debug @keyring @memlock @module @mount @obsolete @raw-io @reboot @resources @setuid @swap
Type=simple
User=gitea
WorkingDirectory=/var/lib/gitea
Which is unable to start inside a lxd container
Aug 04 13:52:40 nixos systemd[14745]: gitea.service: Executing: /nix/store/404wfnlg9dvlzphd955zlqfclsaa31aj-gitea-1.11.8-bin/bin/gitea web
Aug 04 13:52:40 nixos systemd[1]: gitea.service: Failed to read oom_kill field of memory.events cgroup attribute: No such file or directory
Aug 04 13:52:40 nixos systemd[1]: gitea.service: Child 14745 belongs to gitea.service.
Aug 04 13:52:40 nixos systemd[1]: gitea.service: Main process exited, code=dumped, status=31/SYS
Aug 04 13:52:40 nixos systemd[1]: gitea.service: Failed with result 'core-dump'.
I’m a little bit unsure if this is a systemd problem or something is missing in my container.
asbachb@ubuntu-8gb-nbg1-1:~$ lxc config show nixos-gitea -e
raw.lxc: |-
lxc.init.cmd = /sbin/init
lxc.mount.entry = proc mnt/proc proc create=dir 0 0
lxc.apparmor.profile = unconfined
volatile.base_image: d5e2a0b1ddb4c5bc36ced85dd3472dabf4e58e9b3a9aa03de22839e333d3cd34
volatile.eth0.host_name: veth71c87c04
volatile.eth0.hwaddr: 00:16:3e:73:df:0a
volatile.idmap.base: "0"
credentials:
path: /etc/nixos/credentials
pool: storage1
source: nixos-credentials
nictype: bridged
parent: lxdbr0
nixpkgs:
path: /tmp/nixpkgs
pool: storage1
source: nixos-nixpkgs
pool: storage1
- nixos
- with-credentials
- with-nixpkgs
