I needed a quick and dirty way to run things in container instead of polluting my system with random dependencies. Vagrant, virtualenv and friends require too much boilerplate to be quick, so here it is:
~/p/gitless$ ~/lxd-runin.sh
Creating gitless
Starting gitless
Device gitless-shared added to gitless
root@gitless:~/gitless# exit
techtonik@SONiC:~/p/gitless$ ~/lxd-runin.sh
Container gitless already exists
Save as lxd-runin.sh and enjoy:
$ cat lxd-runin.sh
#!/usr/bin/env bash
# name of current dir
NAME=$(basename $PWD)
# https://unix.stackexchange.com/questions/432816/grab-id-of-os-from-etc-os-release/498788#498788
ID=$(grep -oP '(?<=^ID=).+' /etc/os-release | tr -d '"')
VERSION=$(grep -oP '(?<=^VERSION_ID=).+' /etc/os-release | tr -d '"')
OSTORUN="$ID:$VERSION"
if lxc info $NAME &> /dev/null
then
echo "Container $NAME already exists"
else
lxc launch $OSTORUN $NAME
lxc config device add $NAME $NAME-shared disk source=$PWD path=/root/$NAME
fi
# https://stackoverflow.com/questions/7120426/how-to-invoke-bash-run-commands-inside-the-new-shell
lxc exec $NAME -- /bin/sh -c "cd $NAME; bash"
There is one problem though:
root@gitless:~/gitless# ls -la
total 78
drwxr-xr-x 5 nobody nogroup 4096 Feb 5 04:53 .
drwx------ 5 root root 7 Feb 5 15:15 ..
-rw-r--r-- 1 nobody nogroup 1032 Dec 2 05:49 .appveyor.yml
drwxr-xr-x 8 nobody nogroup 4096 Feb 5 04:34 .git
-rw-r--r-- 1 nobody nogroup 325 Dec 2 05:49 .gitignore
-rw-r--r-- 1 nobody nogroup 205 Dec 2 05:49 .pylint.rc
-rwxr-xr-x 1 nobody nogroup 264 Dec 2 05:49 .travis.sh
-rw-r--r-- 1 nobody nogroup 782 Feb 5 04:34 .travis.yml
-rw-r--r-- 1 nobody nogroup 1068 Dec 2 05:49 LICENSE.md
-rw-r--r-- 1 nobody nogroup 46 Dec 2 05:49 MANIFEST.in
-rw-r--r-- 1 nobody nogroup 4590 Dec 2 05:49 README.md
drwxr-xr-x 4 nobody nogroup 4096 Dec 2 05:49 gitless
-rwxr-xr-x 1 nobody nogroup 247 Dec 2 05:49 gl.py
-rw-r--r-- 1 nobody nogroup 385 Dec 2 05:49 gl.spec
-rw-r--r-- 1 nobody nogroup 120 Dec 2 05:49 requirements.txt
-rwxr-xr-x 1 nobody nogroup 2613 Dec 2 05:49 setup.py
drwxr-xr-x 2 nobody nogroup 4096 Dec 2 05:49 snap
-rw-r--r-- 1 nobody nogroup 107 Dec 2 05:49 tox.ini
-rw-r--r-- 1 nobody nogroup 60 Feb 5 04:53 xxx.py
root@gitless:~/gitless# echo 1 > xxx
bash: xxx: Permission denied
If you explain how to fix that without sacrificing on security - it will be appreciated. In references that I read about mappings there is always this hanging tail of “security implications” that follows. If you can explain how to make proper mapping and why it is secure - that will be the most helpful.
