Second container-interface does not have routing
I’ve got a problem bringing the second interface of a container online.
The host has 2 nic’s:
2: enp32s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether d4:85:64:38:df:ef brd ff:ff:ff:ff:ff:ff
    inet xx.xx.48.66/24 brd xx.xx.48.255 scope global enp32s0
3: enp34s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether d4:85:64:38:df:f0 brd ff:ff:ff:ff:ff:ff
    inet 192.168.89.66/24 brd 192.168.89.255 scope global enp34s0
# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         xx.xx.48.1     0.0.0.0         UG    0      0        0 enp32s0
xx.xx.48.0     0.0.0.0         255.255.255.0   U     0      0        0 enp32s0
xx.xx.48.67    0.0.0.0         255.255.255.255 UH    0      0        0 vethf14ae14b
192.168.0.0     192.168.89.44   255.255.255.0   UG    0      0        0 enp34s0
192.168.89.0    0.0.0.0         255.255.255.0   U     0      0        0 enp34s0
192.168.89.67   0.0.0.0         255.255.255.255 UH    0      0        0 vethdd65dfc7
container with this setup:
  volatile.eth1.host_name: vethf14ae14b
  volatile.eth1.hwaddr: 00:16:3e:01:3d:5d
  volatile.eth1.name: eth1
  volatile.eth2.host_name: vethdd65dfc7
  volatile.eth2.hwaddr: 00:16:3e:58:ec:8b
  volatile.eth2.name: eth2
  eth1:
    ipv4.address: xx.xx.48.67
    nictype: routed
    parent: enp32s0
  eth2:
    ipv4.address: 192.168.89.67
    ipv4.gateway: none
    ipv4.host_address: 169.254.0.2
    ipv6.gateway: none
    nictype: routed
    parent: enp34s0
Resulting in this at the container (looks OK)
34: eth1@if35: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:01:3d:5d brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet xx.xx.48.67/32 scope global eth1
36: eth2@if37: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:58:ec:8b brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 192.168.89.67/32 scope global eth2
However the 192.168-interface is not reachable, only the container can ping the 192.168.-address on the host. (the host can’t ping the container)
# route -n
0.0.0.0         169.254.0.1     0.0.0.0         UG    0      0        0 eth1
169.254.0.1     0.0.0.0         255.255.255.255 UH    0      0        0 eth1
On the host there are 2 extra NIC’s after starting the container (looks OK)
35: vethf14ae14b@if34: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 62:94:27:99:13:75 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 169.254.0.1/32 scope global vethf14ae14b
37: vethdd65dfc7@if36: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 7e:5a:c4:c4:0a:41 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 169.254.0.2/32 scope global vethdd65dfc7
On the host the default profile does not have any network-setting.
    pool: default
config: {}
project: default
There is however this in the nft-rules:
# nft list ruleset
table inet incus {
        chain prert.web7.eth1 {
                type filter hook prerouting priority raw; policy accept;
                iif "vethf14ae14b" fib saddr . iif oif missing drop
        chain prert.web7.eth2 {
                iif "vethdd65dfc7" fib saddr . iif oif missing drop
Fixed it by adding routes on the container after startup with a systemd-file:
# Extra routes for second interface
[Unit]
Description=Add routes 192-network
[Service]
After=network-online.target
Type=oneshot
RemainAfterExit=yes
User=root
ExecStart=route add -host 169.254.0.2 eth2
ExecStart=route add -net 192.168.89.0/24 gw 169.254.0.2 eth2
ExecStart=route add -net 192.168.0.0/24 gw 169.254.0.2 eth2
[Install]
WantedBy=multi-user.target
P.S.
I looked at the Incus-profiles to see a way this is added with every container that I start, but didn’t find a solution
