Hi folks,
I have done a lxdp2c conversion of a VM to LXC. Upon completion I can successfully bring up the container. However, the services are stopped (freeradius for example).
I have to then manually start from the LXD host.
The converted container is on Ubuntu16.04 and is sat on an Ubuntu 18.04 host
user@lxd01:~$ lxc exec rad2 systemctl status freeradius
● freeradius.service - LSB: Radius Daemon
Loaded: loaded (/etc/init.d/freeradius; bad; vendor preset: enabled)
Active: inactive (dead)
Docs: man:systemd-sysv-generator(8)
Aug 27 15:05:19 rad2 systemd[1]: Stopped LSB: Radius Daemon.
user@lxd01:~$ lxc exec rad2 systemctl start freeradius
Job for freeradius.service canceled.
user@lxd01:~$ lxc exec rad2 service freeradius start
Active: active (running) since Tue 2019-08-27 15:12:45 BST; 6s ago
Process: 391 ExecStart=/etc/init.d/freeradius start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/freeradius.service
└─401 /usr/sbin/freeradius
Aug 27 15:12:44 rad2 systemd[1]: Starting LSB: Radius Daemon...
Aug 27 15:12:44 rad2 freeradius[391]: * Starting FreeRADIUS daemon freeradius
Aug 27 15:12:45 rad2 freeradius[391]: ...done.
Aug 27 15:12:45 rad2 systemd[1]: Started LSB: Radius Daemon.
I suspect there is something funky going on with systemd. Has anyone seen this before?
