I am trying to set a static IP address on a container so it is visible on the rest of the local network. I can ping it from the network, just cant access the apache it works page.
On the LXD host I run
lxc network set lxdbr0 ipv4.routes 192.168.1.98/32
Inside the alpine container I run
ip -4 addr add dev eth0 192.168.1.98/32
Is this correct way to do it?
Is this the same for public IP addresses?
What am I missing?
