Setting network.ovn.ca_cert, network.ovn.client_cert, network.ovn.client_key
How should one set the network.ovn.ca_cert, network.ovn.client_cert, network.ovn.client_key?
I have a functioning OVN network on three machines, communicating over SSL:
root@incus-1:~# ovn-nbctl \
    -p /etc/ovn/ovn-incus-key.pem \
    -c /etc/ovn/ovn-incus.pem \
    -C /etc/ovn/ca.pem \
    --db ssl:10.170.3.32:6641,ssl:10.170.3.52:6641,ssl:10.170.3.40:6641 \
    ls-add foo
root@incus-2:~# ovn-nbctl \
    ls-list
16b25547-788f-4be6-b9b3-b4ec3cd1168e (foo)
I have formed a cluster with latest Incus LTS 6.0.2, created an uplink network. If I try to create an OVN network on top of it, it complains about missing certs which is OK:
root@incus-1:~# incus network create default --type=ovn network=uplink
Error: Failed loading network: Failed to connect to OVN: OVN is configured to use SSL but no client certificate was found
But if I try to set certs I receive an error too:
root@incus-1:~# incus config set \
    network.ovn.ca_cert=/etc/ovn/ca.pem \
    network.ovn.client_cert=/etc/ovn/ovn-incus.pem \
    network.ovn.client_key=/etc/ovn/ovn-incus-key.pem
Error: failed to notify peer 10.170.3.52:8443: tls: failed to find any PEM data in certificate input
If I simply create symlinks matching the default values (and pointing to exactly same certs):
root@incus-1:~# ls -l /etc/ovn/{ovn-central.crt,cert_host,key_host}
lrwxrwxrwx 1 root root 13 Nov 27 19:27 /etc/ovn/cert_host -> ovn-incus.pem
lrwxrwxrwx 1 root root 17 Nov 27 19:27 /etc/ovn/key_host -> ovn-incus-key.pem
lrwxrwxrwx 1 root root  6 Nov 27 19:27 /etc/ovn/ovn-central.crt -> ca.pem
then after restarting Incus I can create the network. But even after that I still cannot change OVN certs:
I’m almost certain I’m doing something stupidly wrong, but… but what?
Using the latest LTS from Zabbly repo on Ubuntu 24.04 with latest updates.
Thanks.
It needs to be set to the content of those files, not to the path.
incus config set \
    network.ovn.ca_cert="$(cat /etc/ovn/ca.pem)" \
    network.ovn.client_cert="$(cat /etc/ovn/ovn-incus.pem)" \
    network.ovn.client_key="$(cat /etc/ovn/ovn-incus-key.pem)"
