Setting up remote lxd & copy over a local container
Continuing the discussion from Backup the container and install it on another server:
  • I want to move a container from my local host (lxd 3.11 from snap) to a new remote cloud server (running lxd 3.0.3-0ubuntu1~18.04.1).
  • The local host has a dynamic ip, the remote host lives on a hetzner cloudserver and has a static ip. For now, this only has to work once, so I don’t think the dynamic IP of my local host is much of a problem.
Now based on the linked Topic I assume there are 3 steps involved on my local lxd host
1. basic settings
lxc config set core.https_address [local-public-ip]
lxc config set core.trust_password SOME-PASSWORD
2. adding the remote
lxc remote add [remote-name] [remote-public-ip]
2. copy my local container to the remote
lxc copy CONTAINER_NAME/SNAPSHOT_NAME target:CONTAINER_NAME
now with the first action I am running into an error where I have used the public ip addresse I found in my router’s settings (which is a dynamoc ip I assume)
lxc config set core.https_address [xx.yyy.zzz.xx]
Error: cannot listen on https socket: listen tcp [xx.yyy.zzz.xx]:8443: bind: cannot assign requested address
can’t make much of that error. Can someone help?
solved this bit. It did not work due to this problem. After dis-/enableing the lxd snap I can set the IP address.
however I am facing a connection problem with the remote IP now
lxc remote add hetzner [xx.yyy.zzz.xxx]
Generating a client certificate. This may take a minute...
Error: Get https://[xx.yyy.zzz.xxx]:8443: Unable to connect to: [xx.yyy.zzz.xxx]:8443
Can you do a quick test and telnet from the source host towards the IP / port of the destination server?
You might want to check firewall or routing towards your destination server.
I haven’t used telnet before much and it’s long ago, so I hope this is correct
telnet [95.yyy.zzz.149] 8443
Trying [95.yyy.zzz.149]...
telnet: Unable to connect to remote host: Connection refused
getting the same “Unable to connect to remote host: Connection refused” error, when I use the blank IP without specifying any port (telnet [95.yyy.zzz.149])
I assume you are not adding the [ and ] ?
I would double check on the destination host if you have any rules that might be blocking.
First check that indeed LXD is listening on the correct IP / interface:
sudo netstat -ltpn | grep lxd
Check any firewall rules that might be blocking:
sudo iptables -S
sudo iptables -t nat -S
turns back empty
~# sudo iptables -S
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-A INPUT -i lxdbr0 -p tcp -m tcp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -o lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -i lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p tcp -m tcp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
root@ubuntu-2gb-hel1-1:~#
root@ubuntu-2gb-hel1-1:~# iptables -t nat -S
-P PREROUTING ACCEPT
-P INPUT ACCEPT
-P OUTPUT ACCEPT
-P POSTROUTING ACCEPT
-A POSTROUTING -s 10.58.20.0/24 ! -d 10.58.20.0/24 -m comment --comment "generated for LXD network lxdbr0" -j MASQUERADE
iptables -t nat -S
-P INPUT ACCEPT
-P OUTPUT ACCEPT
ufw is disabled
So it seems that LXD is not listening on the interface, can you try to restart the lxd snap with sudo snap restart lxd and run sudo netstat -ltpn | grep lxd to see if it is now listening?
If not can you share lxc config show.
its not the snap lxd on the remote server. so I did a systemctl restart lxd
after which nothing has changed in regards to
now
~# lxc config show
config: {}
and (as we are at it)
:~# lxc profile show default
config: {}
    nictype: bridged
    parent: lxdbr0
    pool: default
- /1.0/containers/[my-container]
should I run the commands …
…on the remote as well?
Should be only necessary on the remote where you are trying to copy your local container to.
well, that’s exactly where I haven’t done it yet because it sounded as if you had to process this on the local server). Will try that and report back once done. thx thus far
after I have applied the
on my remote server, I got an error on the lxc copy
lxc copy [container]/[snapshot] [remote-host]:[container-name]
Error: Failed container creation: Error transferring container data: Unable to connect to: 78.xxx.yyy.76:8443
78.xxx.yyy.76 is my local hosts public IP which I had set with the core.https:address command earlier
EDIT:
on my local host
tcp6       0      0 :::34207                :::*                    LISTEN      29941/lxd
so this wants to talk to IPv6?
