Hello
What do you think about setting separate ZFS datasets for each binary package server in the VMs? I’m running Gentoo on the host. I want to compile packages for my machines, one computer with SELinux and one computer with Apparmor. Does it make any difference that the host computer doesn’t have enabled Apparmor and SELinux if I will fetch binaries from ZFS datasets?
Thanks!
