Fix networking with firewalld
1. Introduction
I usually install firewalld on my hosts, and it interferes with the networking of the LXD containers. If we create a test container, we will notice that the network in the container is not working:
lxc launch images:ubuntu/22.04 u22
lxc ls
lxc exec u22 -- ip addr
The container did not get an IP, as it normally should.
However, if you stop firewalld and restart the container, everything works fine.
systemctl status firewalld
systemctl stop firewalld
lxc restart u22
lxc ls
lxc exec u22 -- ping 8.8.8.8
systemctl start firewalld
By the way, IP forwarding should already be enabled in the kernel of the host:
sysctl net.ipv4.ip_forward cat /proc/sys/net/ipv4/ip_forwardIf it is not, enable it like this:
echo 'net.ipv4.ip_forward = 1' >> /etc/sysctl.conf sysctl -p
So the problem is that the firewall is not configured properly. Let’s fix it.
2. Allow DHCP requests
firewall-cmd --zone=internal --list-all
firewall-cmd --permanent --zone=internal --add-interface=lxdbr0
firewall-cmd --permanent --zone=internal \
--remove-service={dhcpv6-client,mdns,samba-client,ssh}
firewall-cmd --permanent --zone=internal --add-service=dhcp
firewall-cmd --reload
By adding the interface lxdbr0 to the zone internal and allowing DHCP requests on this zone, the containers are able to get an automatic IP from lxdbr0.
lxc restart u22
lxc ls
3. Fix forwarding in firewalld
Ping is still not working:
Let’s move the external interface (eth0 in my case) to the zone external, and enable forwarding between the zones internal and external:
firewall-cmd --permanent --zone=external --add-interface=eth0
firewall-cmd --zone=external --list-all
firewall-cmd --permanent --new-policy=forward-internal
firewall-cmd --permanent --policy=forward-internal --add-ingress-zone=internal
firewall-cmd --permanent --policy=forward-internal --add-egress-zone=external
firewall-cmd --permanent --policy=forward-internal --set-target=ACCEPT
firewall-cmd --list-all-policies
WARNING
By default, the external inteface (eth0in this case) is associated implicitly to the zonepublic. If you use an SSH port different from the default one (for example2201), you have to add this port to theexternalzone too, along with theeth0interface, otherwise you may lock yourself out of the server. For example like this:firewall-cmd --permanent --zone=external --add-port=2201/tcp firewall-cmd --permanent --zone=public --remove-port=2201/tcp firewall-cmd --reload
4. Fix the FORWARD chain
If the ping is still not working, usually the problem is the default policy of iptables. If you try iptables-save | head and see something like this: :FORWARD DROP [4:2508], it means that the default policy for the FORWARD chain is DROP.
You can make the default policy ACCEPT, like this: iptables -P FORWARD ACCEPT. However, the next time that the server will be rebooted, or firewalld restarted, you may loose this configuration.
A better way is to add a direct (explicit) rule with firewall-cmd, like this:
firewall-cmd --permanent --direct --add-rule \
ipv4 filter FORWARD 0 -j ACCEPT
firewall-cmd --direct --get-all-rules
This will enable (ACCEPT) forwarding for all the interfaces, the current ones and the ones that will be created in the future. If this is not what you want, you can use more specific rules, like these:
firewall-cmd --permanent --direct --remove-rule \
ipv4 filter -i lxdbr0 FORWARD 0 -j ACCEPT
ipv4 filter -o lxdbr0 FORWARD 0 -j ACCEPT
NOTE
I would expect thefirewalldpolicy that we defined on the previous step to take care of enabling the necessary forwarding rules automatically, but apparently it doesn’t do that.
5. Cleanup
Let’s test again and then remove the test container:
lxc stop u22
lxc rm u22
lxc ls
