I’ve been too stubborn to ask for help but I’m literally pulling my hair out at this point… so any help would be greatly appreciated here:
I was excited by one of the later releases offering support for VRF’s, but soon found a lot of limitations in the routed NIC approach due to the need to specify static IP’s per instance.
I have since put together a script that I’ve tried 50+ variations of to no avail (posted below). This script automatically creates a unique VRF on the host, a new incus project and network bridge, and then attempts to tie that bridge to the host specific VRF with a VETH pair.
Ideal outcome:
I’m hoping for a solution that ultimately allows me to create multiple incus projects that are tied to isolated VRF’s on the host - and for newly created instances in those projects to behave exactly how the default incus project would (containers get auto-assigned IPv4’s, have internet access, and DNS capabilities).
Please let me know if you see any glaring issues in the script below. Earlier versions would give me errors about networks not being found for the project even when they showed up in the config for those projects.
#!/bin/bash
set -e
=== Inputs ===
PROJECT=“$1”
TABLE_ID=“$2”
EXT_IFACE=“eth0”
=== Derived Vars ===
BRIDGE=“br-${PROJECT}”
VRF_DEV=“vrf-${PROJECT:0:8}”
VETH_VRF=“v${TABLE_ID}-vrf”
VETH_HOST=“v${TABLE_ID}-host”
OCTET1=$((TABLE_ID % 223 + 10))
OCTET2=$((TABLE_ID % 254 + 1))
BRIDGE_SUBNET=“10.${OCTET1}.${OCTET2}.1/24”
BRIDGE_NET=“10.${OCTET1}.${OCTET2}.0/24”
if [ -z “$PROJECT” ] || [ -z “$TABLE_ID” ]; then
echo “Usage: $0 ”
exit 1
fi
echo “[+] Creating Incus project: $PROJECT”
incus project create “$PROJECT” 2>/dev/null || true
echo “[+] Configuring project network restrictions”
incus project set “$PROJECT” restricted.networks.access “$BRIDGE”
incus project set “$PROJECT” restricted.devices.nic managed
incus project set “$PROJECT” restricted true
echo “[+] Switching to project: $PROJECT”
incus project switch “$PROJECT”
echo “[+] Creating Incus bridge: $BRIDGE”
incus network create “$BRIDGE” \
ipv4.address=“$BRIDGE_SUBNET” \
ipv4.nat=false \
ipv6.address=none 2>/dev/null || true
echo “[+] Creating Linux VRF device: $VRF_DEV (table $TABLE_ID)”
ip link show “$VRF_DEV” &>/dev/null || ip link add “$VRF_DEV” type vrf table “$TABLE_ID”
ip link set “$VRF_DEV” up
echo “[+] Binding bridge $BRIDGE to VRF $VRF_DEV”
ip link set “$BRIDGE” master “$VRF_DEV” || true
echo “[+] Creating veth pair: $VETH_VRF ↔ $VETH_HOST”
ip link show “$VETH_VRF” &>/dev/null || ip link add “$VETH_VRF” type veth peer name “$VETH_HOST”
echo “[+] Configuring VRF interface”
ip link set “$VETH_VRF” master “$VRF_DEV” || true
ip link set “$VETH_VRF” up
ip addr add “10.${OCTET1}.254.1/30” dev “$VETH_VRF” 2>/dev/null || true
echo “[+] Configuring host interface”
ip link set “$VETH_HOST” up
ip addr add “10.${OCTET1}.254.2/30” dev “$VETH_HOST” 2>/dev/null || true
echo “[+] Setting default route in VRF table $TABLE_ID”
ip route add default via “10.${OCTET1}.254.2” dev “$VETH_VRF” table “$TABLE_ID” 2>/dev/null || true
echo “[+] Setting up NAT for outbound traffic”
iptables -t nat -C POSTROUTING -s “$BRIDGE_NET” -o “$EXT_IFACE” -j MASQUERADE 2>/dev/null || \
iptables -t nat -A POSTROUTING -s “$BRIDGE_NET” -o “$EXT_IFACE” -j MASQUERADE
echo “[+] Setting up connection tracking for VRF”
iptables -t raw -C PREROUTING -i “$VETH_HOST” -j CT --zone “$TABLE_ID” 2>/dev/null || \
iptables -t raw -A PREROUTING -i “$VETH_HOST” -j CT --zone “$TABLE_ID”
echo “[+] Attaching $BRIDGE to default profile”
incus profile device add default eth0 nic network=“$BRIDGE”
echo “[✓] Project ‘$PROJECT’ is set up with bridge ‘$BRIDGE’, VRF ‘$VRF_DEV’, and subnet $BRIDGE_NET”
